This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
SFTP Outbound Gateway
The SFTP outbound gateway provides a limited set of commands that let you interact with a remote SFTP server:spring-doc.cn
Using the ls Command
ls lists remote files and supports the following options:spring-doc.cn
  • -1: Retrieve a list of filenames. The default is to retrieve a list of FileInfo objectsspring-doc.cn
  • -a: Include all files (including those starting with '.')spring-doc.cn
  • -f: Do not sort the listspring-doc.cn
  • -dirs: Include directories (excluded by default)spring-doc.cn
  • -links: Include symbolic links (excluded by default)spring-doc.cn
  • -R: List the remote directory recursivelyspring-doc.cn
In addition, filename filtering is provided in the same manner as the inbound-channel-adapter.spring-doc.cn
The message payload resulting from an ls operation is a list of file names or a list of FileInfo objects (depending on whether you usr the -1 switch). These objects provide information such as modified time, permissions, and others.spring-doc.cn
The remote directory that the ls command acted on is provided in the file_remoteDirectory header.spring-doc.cn
When using the recursive option (-R), the fileName includes any subdirectory elements and represents the relative path to the file (relative to the remote directory). If you use the -dirs option, each recursive directory is also returned as an element in the list. In this case, we recommend that you not use the -1 option, because you would not be able to distinguish files from directories, which you can do when you use FileInfo objects.spring-doc.cn
If remote path to list starts with a / symbol, it is treated by SFTP as an absolute path; without - as a relative path in the current user home.spring-doc.cn
Using nlst Command
Version 5 introduced support for the nlst command.spring-doc.cn
nlst lists remote file names and supports only one option:spring-doc.cn
The message payload resulting from an nlst operation is a list of file names.spring-doc.cn
The file_remoteDirectory header holds the remote directory on which the nlst command acted.spring-doc.cn
The SFTP protocol does not provide the ability to list names. This command is the equivalent of the ls command with the -1 option and is added here for convenience.spring-doc.cn
Using the get Command
get retrieves a remote file and supports the following options:spring-doc.cn
  • -P: Preserve the timestamp of the remote file.spring-doc.cn
  • -stream: Retrieve the remote file as a stream.spring-doc.cn
  • -D: Delete the remote file after successful transfer. The remote file is not deleted if the transfer is ignored, because the FileExistsMode is IGNORE and the local file already exists.spring-doc.cn
The file_remoteDirectory header holds the remote directory, and the file_remoteFile header holds the filename.spring-doc.cn
The message payload resulting from a get operation is a File object representing the retrieved file. If you use the -stream option, the payload is an InputStream rather than a File. For text files, a common use case is to combine this operation with a file splitter or a stream transformer. When consuming remote files as streams, you are responsible for closing the Session after the stream is consumed. For convenience, the Session is provided in the closeableResource header, and IntegrationMessageHeaderAccessor offers convenience method:spring-doc.cn
Closeable closeable = new IntegrationMessageHeaderAccessor(message).getCloseableResource();
if (closeable != null) {
    closeable.close();
Framework components, such as the File Splitter and Stream Transformer, automatically close the session after the data is transferred.spring-doc.cn
The following example shows how to consume a file as a stream:spring-doc.cn
<int-sftp:outbound-gateway session-factory="ftpSessionFactory"
                            request-channel="inboundGetStream"
                            command="get"
                            command-options="-stream"
                            expression="payload"
                            remote-directory="ftpTarget"
                            reply-channel="stream" />
<int-file:splitter input-channel="stream" output-channel="lines" />
If you consume the input stream in a custom component, you must close the Session. You can either do that in your custom code or route a copy of the message to a service-activator and use SpEL, as the following example shows:
<int:service-activator input-channel="closeSession"
    expression="headers['closeableResource'].close()" />
Using the mget Command
mget retrieves multiple remote files based on a pattern and supports the following options:spring-doc.cn
  • -P: Preserve the timestamps of the remote files.spring-doc.cn
  • -R: Retrieve the entire directory tree recursively.spring-doc.cn
  • -x: Throw an exception if no files match the pattern (otherwise, an empty list is returned).spring-doc.cn
  • -D: Delete each remote file after successful transfer. If the transfer is ignored, the remote file is not deleted, because the FileExistsMode is IGNORE and the local file already exists.spring-doc.cn
The message payload resulting from an mget operation is a List<File> object (that is, a List of File objects, each representing a retrieved file).spring-doc.cn
Starting with version 5.0, if the FileExistsMode is IGNORE, the payload of the output message no longer contain files that were not fetched due to the file already existing. Previously, the array contained all files, including those that already existed.
The expression you use determine the remote path should produce a result that ends with * for example myfiles/* fetches the complete tree under myfiles.spring-doc.cn
Starting with version 5.0, you can use a recursive MGET, combined with the FileExistsMode.REPLACE_IF_MODIFIED mode, to periodically synchronize an entire remote directory tree locally. This mode sets the local file’s last modified timestamp to the remote file’s timestamp, regardless of the -P (preserve timestamp) option.spring-doc.cn
Notes for when using recursion (-R)
The pattern is ignored and * is assumed. By default, the entire remote tree is retrieved. However, you can filter files in the tree by providing a FileListFilter. You can also filter directories in the tree this way. A FileListFilter can be provided by reference or by filename-pattern or filename-regex attributes. For example, filename-regex="(subDir|.*1.txt)" retrieves all files ending with 1.txt in the remote directory and the subdirectory subDir. However, we describe an alternative available after this note.spring-doc.cn
If you filter a subdirectory, no additional traversal of that subdirectory is performed.spring-doc.cn
The -dirs option is not allowed (the recursive mget uses the recursive ls to obtain the directory tree and the directories themselves cannot be included in the list).spring-doc.cn
Typically, you would use the #remoteDirectory variable in the local-directory-expression so that the remote directory structure is retained locally.spring-doc.cn
The persistent file list filters now have a boolean property forRecursion. Setting this property to true, also sets alwaysAcceptDirectories, which means that the recursive operation on the outbound gateways (ls and mget) will now always traverse the full directory tree each time. This is to solve a problem where changes deep in the directory tree were not detected. In addition, forRecursion=true causes the full path to files to be used as the metadata store keys; this solves a problem where the filter did not work properly if a file with the same name appears multiple times in different directories. IMPORTANT: This means that existing keys in a persistent metadata store will not be found for files beneath the top level directory. For this reason, the property is false by default; this may change in a future release.spring-doc.cn
Starting with version 5.0, you can configure the SftpSimplePatternFileListFilter and SftpRegexPatternFileListFilter to always pass directories by setting the alwaysAcceptDirectorties to true. Doing so allows recursion for a simple pattern, as the following examples show:spring-doc.cn
<bean id="starDotTxtFilter"
            class="org.springframework.integration.sftp.filters.SftpSimplePatternFileListFilter">
    <constructor-arg value="*.txt" />
    <property name="alwaysAcceptDirectories" value="true" />
</bean>
<bean id="dotStarDotTxtFilter"
            class="org.springframework.integration.sftp.filters.SftpRegexPatternFileListFilter">
    <constructor-arg value="^.*\.txt$" />
</bean>
You can provide one of these filters by using the filter property on the gateway.spring-doc.cn
Using the put Command
put sends a file to the remote server. The payload of the message can be a java.io.File, a byte[], or a String. A remote-filename-generator (or expression) is used to name the remote file. Other available attributes include remote-directory, temporary-remote-directory and their *-expression equivalents: use-temporary-file-name and auto-create-directory. See the schema documentation for more information.spring-doc.cn
The message payload resulting from a put operation is a String that contains the full path of the file on the server after transfer.spring-doc.cn
Version 4.3 introduced the chmod attribute, which changes the remote file permissions after upload. You can use the conventional Unix octal format (for example, 600 allows read-write for the file owner only). When configuring the adapter using java, you can use setChmod(0600).spring-doc.cn
Using the mput Command
mput sends multiple files to the server and supports the following option:spring-doc.cn
  • -R: Recursive — send all files (possibly filtered) in the directory and subdirectoriesspring-doc.cn
The message payload must be a java.io.File (or String) that represents a local directory. Since version 5.1, a collection of File or String is also supported.spring-doc.cn
The same attributes as the put command are supported. In addition, you can filter files in the local directory with one of mput-pattern, mput-regex, mput-filter, or mput-filter-expression. The filter works with recursion, as long as the subdirectories themselves pass the filter. Subdirectories that do not pass the filter are not recursed.spring-doc.cn
The message payload resulting from an mput operation is a List<String> object (that is, a List of remote file paths resulting from the transfer).spring-doc.cn
Version 4.3 introduced the chmod attribute, which lets you change the remote file permissions after upload. You can use the conventional Unix octal format (for example, 600 allows read-write for the file owner only). When configuring the adapter with Java, you can use setChmodOctal("600") or setChmod(0600).spring-doc.cn
Using the rm Command
The rm command has no options.spring-doc.cn
If the remove operation was successful, the resulting message payload is Boolean.TRUE. Otherwise, the message payload is Boolean.FALSE. The file_remoteDirectory header holds the remote directory, and the file_remoteFile header holds the file name.spring-doc.cn
Using the mv Command
The mv command has no options.spring-doc.cn
The expression attribute defines the “from” path, and the rename-expression attribute defines the “to” path. By default, the rename-expression is headers['file_renameTo']. This expression must not evaluate to null or an empty String. If necessary, any remote directories needed are created. The payload of the result message is Boolean.TRUE. The file_remoteDirectory header holds the original remote directory, and the file_remoteFile header holds the filename. The file_renameTo header holds the new path.spring-doc.cn
Starting with version 5.5.6, the remoteDirectoryExpression can be used in the mv command for convenience. If the “from” file is not a full file path, the result of remoteDirectoryExpression is used as the remote directory. The same applies for the “to” file, for example, if the task is just to rename a remote file in some directory.spring-doc.cn
Additional Command Information
The get and mget commands support the local-filename-generator-expression attribute. It defines a SpEL expression to generate the names of local files during the transfer. The root object of the evaluation context is the request message. The remoteFileName variable is also available. It is particularly useful for mget (for example: local-filename-generator-expression="#remoteFileName.toUpperCase() + headers.foo").spring-doc.cn
The get and mget commands support the local-directory-expression attribute. It defines a SpEL expression to generate the names of local directories during the transfer. The root object of the evaluation context is the request message. The remoteDirectory variable is also available. It is particularly useful for mget (for example: local-directory-expression="'/tmp/local/' + #remoteDirectory.toUpperCase() + headers.myheader"). This attribute is mutually exclusive with the local-directory attribute.spring-doc.cn
For all commands, the 'expression' property of the gateway holds the path on which the command acts. For the mget command, the expression might evaluate to *, meaning to retrieve all files, somedirectory/*, and other values that end with *.spring-doc.cn
The following example shows a gateway configured for an ls command:spring-doc.cn
<int-ftp:outbound-gateway id="gateway1"
        request-channel="inbound1"
        command="ls"
        command-options="-1"
        reply-channel="toSplitter"/>
The payload of the message sent to the toSplitter channel is a list of String objects, each of which contains the name of a file. If you omitted command-options="-1", the payload would be a list of FileInfo objects. You can provide options as a space-delimited list (for example, command-options="-1 -dirs -links").spring-doc.cn
Starting with version 4.2, the GET, MGET, PUT, and MPUT commands support a FileExistsMode property (mode when using the namespace support). This affects the behavior when the local file exists (GET and MGET) or the remote file exists (PUT and MPUT). The supported modes are REPLACE, APPEND, FAIL, and IGNORE. For backwards compatibility, the default mode for PUT and MPUT operations is REPLACE. For GET and MGET operations, the default is FAIL.spring-doc.cn
Configuring with Java Configuration
The following Spring Boot application shows an example of how to configure the outbound gateway with Java:spring-doc.cn
@SpringBootApplication
public class SftpJavaApplication {
        new SpringApplicationBuilder(SftpJavaApplication.class)
            .web(false)
            .run(args);
    @ServiceActivator(inputChannel = "sftpChannel")
    public MessageHandler handler() {
        return new SftpOutboundGateway(ftpSessionFactory(), "ls", "'my_remote_dir/'");
Configuring with the Java DSL
The following Spring Boot application shows an example of how to configure the outbound gateway with the Java DSL:spring-doc.cn
            .web(false)
            .run(args);
    public SessionFactory<SftpClient.DirEntry> sftpSessionFactory() {
        DefaultSftpSessionFactory sf = new DefaultSftpSessionFactory();
        sf.setHost("localhost");
        sf.setPort(port);
        sf.setUsername("foo");
        sf.setPassword("foo");
        factory.setTestSession(true);
        return new CachingSessionFactory<>(sf);
    public QueueChannelSpec remoteFileOutputChannel() {
        return MessageChannels.queue();
    public IntegrationFlow sftpMGetFlow() {
        return IntegrationFlow.from("sftpMgetInputChannel")
            .handle(Sftp.outboundGateway(sftpSessionFactory(),
                            AbstractRemoteFileOutboundGateway.Command.MGET, "payload")
                    .options(AbstractRemoteFileOutboundGateway.Option.RECURSIVE)
                    .regexFileNameFilter("(subSftpSource|.*1.txt)")
                    .localDirectoryExpression("'myDir/' + #remoteDirectory")
                    .localFilenameExpression("#remoteFileName.replaceFirst('sftpSource', 'localTarget')"))
            .channel("remoteFileOutputChannel")
            .get();
Outbound Gateway Partial Success (mget and mput)
When performing operations on multiple files (by using mget and mput) an exception can occur some time after one or more files have been transferred. In this case (starting with version 4.2), a PartialSuccessException is thrown. As well as the usual MessagingException properties (failedMessage and cause), this exception has two additional properties:spring-doc.cn
  • partialResults: The successful transfer results.spring-doc.cn
  • derivedInput: The list of files generated from the request message (such as local files to transfer for an mput).spring-doc.cn
These attributes let you determine which files were successfully transferred and which were not.spring-doc.cn
In the case of a recursive mput, the PartialSuccessException may have nested PartialSuccessException instances.spring-doc.cn
Consider the following directory structure:spring-doc.cn
root/
|- file1.txt
|- subdir/
   | - file2.txt
   | - file3.txt
|- zoo.txt
If the exception occurs on file3.txt, the PartialSuccessException thrown by the gateway has derivedInput of file1.txt, subdir, and zoo.txt and partialResults of file1.txt. Its cause is another PartialSuccessException with derivedInput of file2.txt and file3.txt and partialResults of file2.txt.spring-doc.cn
