This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Using RemoteFileTemplate
Starting with Spring Integration 3.0, a new abstraction is provided over the FtpSession
object.
The template provides methods to send, retrieve (as an InputStream
), remove, and rename files.
In addition, an execute
method is provided allowing the caller to execute multiple operations on the session.
In all cases, the template takes care of reliably closing the session.
For more information, see the
Javadoc for RemoteFileTemplate
There is a subclass for FTP: FtpRemoteFileTemplate
Version 4.1 added additional methods, including getClientInstance()
, which provides access to the underlying FTPClient
and thus gives you access to low-level APIs.
Not all FTP servers properly implement the STAT <path>
command.
Some return a positive result for a non-existent path.
The NLST
command reliably returns the name when the path is a file, and it exists.
However, this does not support checking that an empty directory exists since NLST
always returns an empty list when the path is a directory.
Since the template does not know whether the path represents a directory, it has to perform additional checks when the path does not appear to exist (when using NLST
This adds overhead, requiring several requests to the server.
Starting with version 4.1.9, the FtpRemoteFileTemplate
provides the FtpRemoteFileTemplate.ExistsMode
property, which has the following options:
STAT
: Perform theSTAT
FTP command (FTPClient.getStatus(path)
) to check the path existence. This is the default and requires that your FTP server properly support theSTAT
command (with a path). -
NLST
: Perform theNLST
FTP command —FTPClient.listName(path)
. Use this if you are testing for a path that is a full path to a file. It does not work for empty directories. -
NLST_AND_DIRS
: Perform theNLST
command first and, if it returns no files, fall back to a technique that temporarily switches the working directory by usingFTPClient.changeWorkingDirectory(path)
. SeeFtpSession.exists()
for more information.
Since we know that the FileExistsMode.FAIL
case is always only looking for a file (and not a directory), we safely use NLST
mode for the FtpMessageHandler
and FtpOutboundGateway
components.
For any other cases, the FtpRemoteFileTemplate
can be extended to implement custom logic in the overridden exist()
method.
Starting with version 5.0, the new RemoteFileOperations.invoke(OperationsCallback<F, T> action)
method is available.
This method lets several RemoteFileOperations
calls be called in the scope of the same, thread-bounded, Session
This is useful when you need to perform several high-level operations of the RemoteFileTemplate
as one unit of work.
For example, AbstractRemoteFileOutboundGateway
uses it with the mput
command implementation, where we perform a put
operation for each file in the provided directory and recursively for its sub-directories.
See the Javadoc for more information.
