This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
UDP Adapters
This section describes how to configure and use the UDP adapters.spring-doc.cn
Outbound UDP Adapters (XML Configuration)
The following example configures a UDP outbound channel adapter:spring-doc.cn
<int-ip:udp-outbound-channel-adapter id="udpOut"
    host="somehost"
    port="11111"
    multicast="false"
    socket-customizer="udpCustomizer"
    channel="exampleChannel"/>
When setting multicast to true, you should also provide the multicast address in the host attribute.
UDP is an efficient but unreliable protocol. Spring Integration adds two attributes to improve reliability: check-length and acknowledge. When check-length is set to true, the adapter precedes the message data with a length field (four bytes in network byte order). This enables the receiving side to verify the length of the packet received. If a receiving system uses a buffer that is too short to contain the packet, the packet can be truncated. The length header provides a mechanism to detect this.spring-doc.cn
Starting with version 4.3, you can set the port to 0, in which case the operating system chooses the port. The chosen port can be discovered by invoking getPort() after the adapter is started and isListening() returns true.spring-doc.cn
Starting with version 5.3.3, you can add a SocketCustomizer bean to modify the DatagramSocket after it is created (for example, call setTrafficClass(0x10)).spring-doc.cn
The following example shows an outbound channel adapter that adds length checking to the datagram packets:spring-doc.cn
    host="somehost"
    port="11111"
    multicast="false"
    check-length="true"
The recipient of the packet must also be configured to expect a length to precede the actual data. For a Spring Integration UDP inbound channel adapter, set its check-length attribute.
The second reliability improvement allows an application-level acknowledgment protocol to be used. The receiver must send an acknowledgment to the sender within a specified time.spring-doc.cn
The following example shows an outbound channel adapter that adds length checking to the datagram packets and waits for an acknowledgment:spring-doc.cn
    host="somehost"
    port="11111"
    multicast="false"
    check-length="true"
    acknowledge="true"
    ack-host="thishost"
    ack-port="22222"
    ack-timeout="10000"
Setting acknowledge to true implies that the recipient of the packet can interpret the header added to the packet containing acknowledgment data (host and port). Most likely, the recipient is a Spring Integration inbound channel adapter.
When multicast is true, an additional attribute (min-acks-for-success) specifies how many acknowledgments must be received within the ack-timeout.
Starting with version 4.3, you can set the ackPort to 0, in which case the operating system chooses the port.spring-doc.cn
Outbound UDP Adapters (Java Configuration)
The following example shows how to configure an outbound UDP adapter with Java:spring-doc.cn
@ServiceActivator(inputChannel = "udpOut")
public UnicastSendingMessageHandler handler() {
    return new UnicastSendingMessageHandler("localhost", 11111);
(or MulticastSendingChannelAdapter for multicast).spring-doc.cn
Outbound UDP Adapters (Java DSL Configuration)
The following example shows how to configure an outbound UDP adapter with the Java DSL:spring-doc.cn
public IntegrationFlow udpOutFlow() {
    return f -> f.handle(Udp.outboundAdapter("localhost", 1234)
                    .configureSocket(socket -> socket.setTrafficClass(0x10)))
                .get();
Inbound UDP Adapters (XML Configuration)
The following example shows how to configure a basic unicast inbound udp channel adapter.spring-doc.cn
<int-ip:udp-inbound-channel-adapter id="udpReceiver"
    channel="udpOutChannel"
    port="11111"
    receive-buffer-size="500"
    multicast="false"
    check-length="true"/>
The following example shows how to configure a basic multicast inbound udp channel adapter:spring-doc.cn
    port="11111"
    multicast="true"
    multicast-address="225.6.7.8"
By default, reverse DNS lookups are not performed on inbound packets: in environments where DNS is not configured (e.g. Docker containers), this can cause connection delays. To convert IP addresses to host names for use in message headers, the default behavior can be overridden by setting the lookup-host attribute to true.spring-doc.cn
Starting with version 5.3.3, you can add a SocketCustomizer bean to modify the DatagramSocket after it is created. It is called for the receiving socket and any sockets created for sending acks.spring-doc.cn
Inbound UDP Adapters (Java Configuration)
The following example shows how to configure an inbound UDP adapter with Java:spring-doc.cn
public UnicastReceivingChannelAdapter udpIn() {
    UnicastReceivingChannelAdapter adapter = new UnicastReceivingChannelAdapter(11111);
    adapter.setOutputChannelName("udpChannel");
    return adapter;
The following example shows how to configure an inbound UDP adapter with the Java DSL:spring-doc.cn
Inbound UDP Adapters (Java DSL Configuration)
public IntegrationFlow udpIn() {
    return IntegrationFlow.from(Udp.inboundAdapter(11111))
            .channel("udpChannel")
            .get();
Server Listening Events
Starting with version 5.0.2, a UdpServerListeningEvent is emitted when an inbound adapter is started and has begun listening. This is useful when the adapter is configured to listen on port 0, meaning that the operating system chooses the port. It can also be used instead of polling isListening(), if you need to wait before starting some other process that will connect to the socket.spring-doc.cn
Advanced Outbound Configuration
The <int-ip:udp-outbound-channel-adapter> (UnicastSendingMessageHandler) has destination-expression and socket-expression options.spring-doc.cn
You can use the destination-expression as a runtime alternative to the hardcoded host-port pair to determine the destination address for the outgoing datagram packet against a requestMessage (with the root object for the evaluation context). The expression must evaluate to an URI, a String in the URI style (see RFC-2396), or a SocketAddress. You can also use the inbound IpHeaders.PACKET_ADDRESS header for this expression. In the framework, the DatagramPacketMessageMapper populates this header when we receive datagrams in the UnicastReceivingChannelAdapter and convert them to messages. The header value is exactly the result of DatagramPacket.getSocketAddress() of the incoming datagram.spring-doc.cn
With the socket-expression, the outbound channel adapter can use (for example) an inbound channel adapter socket to send datagrams through the same port which they were received. It is useful in a scenario where our application works as a UDP server and clients operate behind network address translation (NAT). This expression must evaluate to a DatagramSocket. The requestMessage is used as the root object for the evaluation context. You cannot use the socket-expression parameter with the multicast and acknowledge parameters. The following example shows how to configure a UDP inbound channel adapter with a transformer that converts to upper case and uses a socket:spring-doc.cn
<int-ip:udp-inbound-channel-adapter id="inbound" port="0" channel="in" />
<int:channel id="in" />
<int:transformer expression="new String(payload).toUpperCase()"
                       input-channel="in" output-channel="out"/>
<int:channel id="out" />
<int-ip:udp-outbound-channel-adapter id="outbound"
                        socket-expression="@inbound.socket"
                        destination-expression="headers['ip_packetAddress']"
                        channel="out" />
The following example shows the equivalent configuration with the Java DSL:spring-doc.cn
public IntegrationFlow udpEchoUpcaseServer() {
    return IntegrationFlow.from(Udp.inboundAdapter(11111).id("udpIn"))
            .<byte[], String>transform(p -> new String(p).toUpperCase())
            .handle(Udp.outboundAdapter("headers['ip_packetAddress']")
                    .socketExpression("@udpIn.socket"))
            .get();
