This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Alternative Mechanism for Publisher Confirms and Returns
When the connection factory is configured for publisher confirms and returns, the sections above discuss the configuration of message channels to receive the confirms and returns asynchronously. Starting with version 5.4, there is an additional mechanism which is generally easier to use.
In this case, do not configure a confirm-correlation-expression
or the confirm and return channels.
Instead, add a CorrelationData
instance in the AmqpHeaders.PUBLISH_CONFIRM_CORRELATION
header; you can then wait for the result(s) later, by checking the state of the future in the CorrelationData
instances for which you have sent messages.
The returnedMessage
field will always be populated (if a message is returned) before the future is completed.
CorrelationData corr = new CorrelationData("someId"); // <--- Unique "id" is required for returns
someFlow.getInputChannel().send(MessageBuilder.withPayload("test")
.setHeader("rk", "someKeyThatWontRoute")
.setHeader(AmqpHeaders.PUBLISH_CONFIRM_CORRELATION, corr)
.build());
try {
Confirm Confirm = corr.getFuture().get(10, TimeUnit.SECONDS);
Message returned = corr.getReturnedMessage();
if (returned !- null) {
// message could not be routed
catch { ... }
To improve performance, you may wish to send multiple messages and wait for the confirmations later, rather than one-at-a-time.
The returned message is the raw message after conversion; you can sub-class a CorrelationData
with whatever additional data you need.
