This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Message Routers
Spring Integration natively provides specialized router types, including:
HeaderValueRouter
PayloadTypeRouter
ExceptionTypeRouter
RecipientListRouter
XPathRouter
As with many other DSL IntegrationFlowBuilder
EIP methods, the route()
method can apply any AbstractMessageRouter
implementation or, for convenience, a String
as a SpEL expression or a ref
-method
pair.
In addition, you can configure route()
with a lambda and use a lambda for a Consumer<RouterSpec<MethodInvokingRouter>>
The fluent API also provides AbstractMappingMessageRouter
options such as channelMapping(String key, String channelName)
pairs, as the following example shows:
public IntegrationFlow routeFlowByLambda() {
return IntegrationFlow.from("routerInput")
.<Integer, Boolean>route(p -> p % 2 == 0,
m -> m.suffix("Channel")
.channelMapping(true, "even")
.channelMapping(false, "odd")
.get();
The following example shows a simple expression-based router:
public IntegrationFlow routeFlowByExpression() {
.route("headers['destChannel']")
.get();
The routeToRecipients()
method takes a Consumer<RecipientListRouterSpec>
public IntegrationFlow recipientListFlow() {
return IntegrationFlow.from("recipientListInput")
.<String, String>transform(p -> p.replaceFirst("Payload", ""))
.routeToRecipients(r -> r
.recipient("thing1-channel", "'thing1' == payload")
.recipientMessageSelector("thing2-channel", m ->
m.getHeaders().containsKey("recipient")
&& (boolean) m.getHeaders().get("recipient"))
.recipientFlow("'thing1' == payload or 'thing2' == payload or 'thing3' == payload",
f -> f.<String, String>transform(String::toUpperCase)
.channel(c -> c.queue("recipientListSubFlow1Result")))
.recipientFlow((String p) -> p.startsWith("thing3"),
f -> f.transform("Hello "::concat)
.channel(c -> c.queue("recipientListSubFlow2Result")))
.recipientFlow(new FunctionExpression<Message<?>>(m ->
"thing3".equals(m.getPayload())),
f -> f.channel(c -> c.queue("recipientListSubFlow3Result")))
.defaultOutputToParentFlow())
.get();
The .defaultOutputToParentFlow()
of the .routeToRecipients()
definition lets you set the router’s defaultOutput
as a gateway to continue a process for the unmatched messages in the main flow.
Also see Lambdas And Message<?>
Arguments.
