This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
What’s New?
For those who are already familiar with Spring Integration, this chapter provides a brief overview of the new features of version 6.3.spring-doc.cn
If you are interested in the changes and features that were introduced in earlier versions, see the Change History.spring-doc.cn
What’s New in Spring Integration 6.3?
If you are interested in more details, see the Issue Tracker tickets that were resolved as part of the 6.3 development process.spring-doc.cn
In general the project has been moved to the latest dependency versions.spring-doc.cn
New Components
General Changes
The MessageHistory header is now mutable, append-only container. And all the subsequent tracks don’t create new message - only their entry is added to existing message history header. See Message History Chapter for more information.spring-doc.cn
All the MessageChannel implementations based on the UnicastingDispatcher now can be configured with a Predicate<Exception> failoverStrategy for dynamic decision for the failover on the exception thrown from the current MessageHandler. See Message Channel Configuration for more information.spring-doc.cn
Security Support Changes
The spring-integration-security module is completely removed (being deprecated previously) in favor of API from spring-security-messaging module. See Security in Spring Integration for more information.spring-doc.cn
MQTT Support Changes
The fine-grained configuration based on MqttSubscription API is exposed on the Mqttv5PahoMessageDrivenChannelAdapter. See MQTT Support for more information.spring-doc.cn
Testing Support Changes
The MockIntegrationContext.substituteTriggerFor() API has been introduced. See Testing Support for more information.spring-doc.cn
JMS Support Changes
The ChannelPublishingJmsMessageListener can now be supplied with a RetryTemplate and RecoveryCallback<Message<?>> for retries on the downstream send operations. See Message Driven Channel Adapter for more information.spring-doc.cn
