This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Changes between 5.4 and 5.5
File Aggregator
A FileSplitter.FileMaker
-based implementation of CorrelationStrategy
, ReleaseStrategy
and MessageGroupProcessor
as a FileAggregator
component was introduced.
See File Aggregator for more information.
MQTT v5 Support
The Mqttv5PahoMessageDrivenChannelAdapter
and Mqttv5PahoMessageHandler
(including respective MqttHeaderMapper
) were introduced to support MQTT v5 protocol communication.
See MQTT v5 Support for more information.
General Changes
All the persistent MessageGroupStore
implementation provide a streamMessagesForGroup(Object groupId)
contract based on the target database streaming API.
See Message Store for more information.
The integrationGlobalProperties
bean (if declared) must be now an instance of org.springframework.integration.context.IntegrationProperties
instead of java.util.Properties
, which support is deprecated for backward compatibility.
The spring.integration.channels.error.requireSubscribers=true
global property is added to indicate that the global default errorChannel
must be configured with the requireSubscribers
option (or not).
The spring.integration.channels.error.ignoreFailures=true
must ignore (or not) dispatching errors and pass the message to the next handler.
See Global Properties for more information.
An AbstractPollingEndpoint
(source polling channel adapter and polling consumer) treats maxMessagesPerPoll == 0
as to skip calling the source.
It can be changed to different value later on, e.g. via a Control Bus.
See Polling Consumer for more information.
The ConsumerEndpointFactoryBean
now accept a reactiveCustomizer
Function
to any input channel as reactive stream source and use a ReactiveStreamsConsumer
underneath.
This is covered as a ConsumerEndpointSpec.reactive()
option in Java DSL and as a @Reactive
nested annotation for the messaging annotations.
See Reactive Streams Support for more information.
The groupTimeoutExpression
for a correlation message handler (an Aggregator
and Resequencer
) can now be evaluated to a java.util.Date
for some fine-grained scheduling use-cases.
Also the BiFunction groupConditionSupplier
option is added to the AbstractCorrelatingMessageHandler
to supply a MessageGroup
condition against a message to be added to the group.
See Aggregator for more information.
The MessageGroup
abstraction can be supplied with a condition
to evaluate later on to make a decision for the group.
See Message Group Condition for more information.
Integration Flows Composition
The new IntegrationFlows.from(IntegrationFlow)
factory method has been added to allow starting the current IntegrationFlow
from the output of an existing flow.
In addition, the IntegrationFlowDefinition
has added a to(IntegrationFlow)
terminal operator to continue the current flow at the input channel of some other flow.
See Integration Flows Composition for more information.
AMQP Changes
The AmqpInboundChannelAdapter
and AmqpInboundGateway
(and the respective Java DSL builders) now support an org.springframework.amqp.rabbit.retry.MessageRecoverer
as an AMQP-specific alternative to the general purpose RecoveryCallback
See AMQP Support for more information.
Redis Changes
The ReactiveRedisStreamMessageProducer
has now setters for all the StreamReceiver.StreamReceiverOptionsBuilder
options, including an onErrorResume
function.
See Redis Support for more information.
HTTP Changes
The HttpRequestExecutingMessageHandler
doesn’t fallback to the application/x-java-serialized-object
content type any more and lets the RestTemplate
make the final decision for the request body conversion based on the HttpMessageConverter
provided.
It also has now an extractResponseBody
flag (which is true
by default) to return just the response body, or to return the whole ResponseEntity
as the reply message payload, independently of the provided expectedResponseType
Same option is presented for the WebFluxRequestExecutingMessageHandler
, too.
See HTTP Support for more information.
File/FTP/SFTP Changes
The persistent file list filters now have a boolean property forRecursion
Setting this property to true
, also sets alwaysAcceptDirectories
, which means that the recursive operation on the outbound gateways (ls
and mget
) will now always traverse the full directory tree each time.
This is to solve a problem where changes deep in the directory tree were not detected.
In addition, forRecursion=true
causes the full path to files to be used as the metadata store keys; this solves a problem where the filter did not work properly if a file with the same name appears multiple times in different directories.
IMPORTANT: This means that existing keys in a persistent metadata store will not be found for files beneath the top level directory.
For this reason, the property is false
by default; this may change in a future release.
The FileInboundChannelAdapterSpec
has now a convenient recursive(boolean)
option instead of requiring an explicit reference to the RecursiveDirectoryScanner
The remoteDirectoryExpression
can now be used in the mv
command for convenience.
MongoDb Changes
The MongoDbMessageSourceSpec
was added into MongoDd Java DSL.
An update
option is now exposed on both the MongoDbMessageSource
and ReactiveMongoDbMessageSource
implementations.
See MongoDb Support for more information.
WebSockets Changes
The WebSocket channel adapters based on ServerWebSocketContainer
can now be registered and removed at runtime.
See WebSockets Support for more information.
JPA Changes
The JpaOutboundGateway
now supports an Iterable
message payload for a PersistMode.DELETE
See Outbound Channel Adapter for more information.
Gateway Changes
Previously, when using XML configuration, @Gateway.payloadExpression
was ignored for no-argument methods.
There is one possible breaking change - if the method is annotated with @Payload
as well as @Gateway
(with a different expression) previously, the @Payload
would be applied, now the @Gateway.payloadExpression
is applied.
See Gateway Configuration with Annotations and XML and Invoking No-Argument Methods for more information.
