This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Inbound Endpoint Acknowledge Mode
By default, the inbound endpoints use the AUTO
acknowledge mode, which means the container automatically acknowledges the message when the downstream integration flow completes (or a message is handed off to another thread by using a QueueChannel
or ExecutorChannel
Setting the mode to NONE
configures the consumer such that acknowledgments are not used at all (the broker automatically acknowledges the message as soon as it is sent).
Setting the mode to MANUAL
lets user code acknowledge the message at some other point during processing.
To support this, with this mode, the endpoints provide the Channel
and deliveryTag
in the amqp_channel
and amqp_deliveryTag
headers, respectively.
You can perform any valid Rabbit command on the Channel
but, generally, only basicAck
and basicNack
(or basicReject
) are used.
In order to not interfere with the operation of the container, you should not retain a reference to the channel and use it only in the context of the current message.
Since the Channel is a reference to a “live” object, it cannot be serialized and is lost if a message is persisted.
The following example shows how you might use MANUAL
acknowledgement:
@ServiceActivator(inputChannel = "foo", outputChannel = "bar")
public Object handle(@Payload String payload, @Header(AmqpHeaders.CHANNEL) Channel channel,
@Header(AmqpHeaders.DELIVERY_TAG) Long deliveryTag) throws Exception {
// Do some processing
if (allOK) {
channel.basicAck(deliveryTag, false);
// perhaps do some more processing
else {
channel.basicNack(deliveryTag, false, true);
return someResultForDownStreamProcessing;
