This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0!spring-doc.cn
Routers and the Spring Expression Language (SpEL)
Sometimes, the routing logic may be simple, and writing a separate class for it and configuring it as a bean may seem like overkill. As of Spring Integration 2.0, we offer an alternative that lets you use SpEL to implement simple computations that previously required a custom POJO router.spring-doc.cn
For more information about the Spring Expression Language, see the relevant chapter in the Spring Framework Reference Guide.
Generally, a SpEL expression is evaluated and its result is mapped to a channel, as the following example shows:spring-doc.cn
<int:router input-channel="inChannel" expression="payload.paymentType">
    <int:mapping value="CASH" channel="cashPaymentChannel"/>
    <int:mapping value="CREDIT" channel="authorizePaymentChannel"/>
    <int:mapping value="DEBIT" channel="authorizePaymentChannel"/>
</int:router>
The following example shows the equivalent router configured in Java:spring-doc.cn
@Router(inputChannel = "routingChannel")
public ExpressionEvaluatingRouter router() {
    ExpressionEvaluatingRouter router = new ExpressionEvaluatingRouter("payload.paymentType");
    router.setChannelMapping("CASH", "cashPaymentChannel");
    router.setChannelMapping("CREDIT", "authorizePaymentChannel");
    router.setChannelMapping("DEBIT", "authorizePaymentChannel");
    return router;
The following example shows the equivalent router configured in the Java DSL:spring-doc.cn
public IntegrationFlow routerFlow() {
    return IntegrationFlow.from("routingChannel")
        .route("payload.paymentType", r -> r
            .channelMapping("CASH", "cashPaymentChannel")
            .channelMapping("CREDIT", "authorizePaymentChannel")
            .channelMapping("DEBIT", "authorizePaymentChannel"))
        .get();
To simplify things even more, the SpEL expression may evaluate to a channel name, as the following expression shows:spring-doc.cn
<int:router input-channel="inChannel" expression="payload + 'Channel'"/>
In the preceding configuration, the result channel is computed by the SpEL expression, which concatenates the value of the payload with the literal String, 'Channel'.spring-doc.cn
Another virtue of SpEL for configuring routers is that an expression can return a Collection, effectively making every <router> a recipient list router. Whenever the expression returns multiple channel values, the message is forwarded to each channel. The following example shows such an expression:spring-doc.cn
<int:router input-channel="inChannel" expression="headers.channels"/>
In the above configuration, if the message includes a header with a name of 'channels' and the value of that header is a List of channel names, the message is sent to each channel in the list. You may also find collection projection and collection selection expressions useful when you need to select multiple channels. For further information, see:spring-doc.cn
