This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Integration 6.5.0! |
Outbound Channel Adapter
The following example shows the available properties for an AMQP outbound channel adapter:
Java DSL
Java
XML
public IntegrationFlow amqpOutbound(AmqpTemplate amqpTemplate,
MessageChannel amqpOutboundChannel) {
return IntegrationFlow.from(amqpOutboundChannel)
.handle(Amqp.outboundAdapter(amqpTemplate)
.routingKey("queue1")) // default exchange - route to queue 'queue1'
.get();
@ServiceActivator(inputChannel = "amqpOutboundChannel")
public AmqpOutboundEndpoint amqpOutbound(AmqpTemplate amqpTemplate) {
AmqpOutboundEndpoint outbound = new AmqpOutboundEndpoint(amqpTemplate);
outbound.setRoutingKey("queue1"); // default exchange - route to queue 'queue1'
return outbound;
public MessageChannel amqpOutboundChannel() {
return new DirectChannel();
<int-amqp:outbound-channel-adapter id="outboundAmqp" (1)
channel="outboundChannel" (2)
amqp-template="myAmqpTemplate" (3)
exchange-name="" (4)
exchange-name-expression="" (5)
order="1" (6)
routing-key="" (7)
routing-key-expression="" (8)
default-delivery-mode"" (9)
confirm-correlation-expression="" (10)
confirm-ack-channel="" (11)
confirm-nack-channel="" (12)
confirm-timeout="" (13)
wait-for-confirm="" (14)
return-channel="" (15)
error-message-strategy="" (16)
header-mapper="" (17)
mapped-request-headers="" (18)
lazy-connect="true" (19)
multi-send="false"/> (20)
1 | The unique ID for this adapter. Optional. |
2 | Message channel to which messages should be sent to have them converted and published to an AMQP exchange. Required. |
3 | Bean reference to the configured AMQP template.
Optional (defaults to amqpTemplate ). |
4 | The name of the AMQP exchange to which messages are sent. If not provided, messages are sent to the default, no-name exchange. Mutually exclusive with 'exchange-name-expression'. Optional. |
5 | A SpEL expression that is evaluated to determine the name of the AMQP exchange to which messages are sent, with the message as the root object. If not provided, messages are sent to the default, no-name exchange. Mutually exclusive with 'exchange-name'. Optional. |
6 | The order for this consumer when multiple consumers are registered, thereby enabling load-balancing and failover.
Optional (defaults to Ordered.LOWEST_PRECEDENCE [=Integer.MAX_VALUE] ). |
7 | The fixed routing-key to use when sending messages.
By default, this is an empty String .
Mutually exclusive with 'routing-key-expression'.
Optional. |
8 | A SpEL expression that is evaluated to determine the routing key to use when sending messages, with the message as the root object (for example, 'payload.key').
Mutually exclusive with 'routing-key'.
Optional. |
9 | The default delivery mode for messages: PERSISTENT or NON_PERSISTENT .
Overridden if the header-mapper sets the delivery mode.
If the Spring Integration message header amqp_deliveryMode is present, the DefaultHeaderMapper sets the value.
If this attribute is not supplied and the header mapper does not set it, the default depends on the underlying Spring AMQP MessagePropertiesConverter used by the RabbitTemplate .
If that is not customized at all, the default is PERSISTENT .
Optional. |
10 | An expression that defines correlation data.
When provided, this configures the underlying AMQP template to receive publisher confirmations.
Requires a dedicated RabbitTemplate and a CachingConnectionFactory with the publisherConfirms property set to true .
When a publisher confirmation is received and correlation data is supplied, it is written to either the confirm-ack-channel or the confirm-nack-channel , depending on the confirmation type.
The payload of the confirmation is the correlation data, as defined by this expression.
The message has an 'amqp_publishConfirm' header set to true (ack ) or false (nack ).
Examples: headers['myCorrelationData'] and payload .
Version 4.1 introduced the amqp_publishConfirmNackCause message header.
It contains the cause of a 'nack' for a publisher confirmation.
Starting with version 4.2, if the expression resolves to a Message<?> instance (such as #this ), the message emitted on the ack /nack channel is based on that message, with the additional header(s) added.
Previously, a new message was created with the correlation data as its payload, regardless of type.
Also see Alternative Mechanism for Publisher Confirms and Returns.
Optional. |
11 | The channel to which positive (ack ) publisher confirms are sent.
The payload is the correlation data defined by the confirm-correlation-expression .
If the expression is #root or #this , the message is built from the original message, with the amqp_publishConfirm header set to true .
Optional (the default is nullChannel ). |
12 | The channel to which negative (nack ) publisher confirmations are sent.
The payload is the correlation data defined by the confirm-correlation-expression (if there is no ErrorMessageStrategy configured).
If the expression is #root or #this , the message is built from the original message, with the amqp_publishConfirm header set to false .
When there is an ErrorMessageStrategy , the message is an ErrorMessage with a NackedAmqpMessageException payload.
13 | When set, the adapter will synthesize a negative acknowledgment (nack) if a publisher confirm is not received within this time in milliseconds. Pending confirms are checked every 50% of this value, so the actual time a nack is sent will be between 1x and 1.5x this value. Also see Alternative Mechanism for Publisher Confirms and Returns. Default none (nacks will not be generated). |
14 | When set to true, the calling thread will block, waiting for a publisher confirmation.
This requires a RabbitTemplate configured for confirms as well as a confirm-correlation-expression .
The thread will block for up to confirm-timeout (or 5 seconds by default).
If a timeout occurs, a MessageTimeoutException will be thrown.
If returns are enabled and a message is returned, or any other exception occurs while awaiting the confirmation, a MessageHandlingException will be thrown, with an appropriate message. |
15 | The channel to which returned messages are sent.
When provided, the underlying AMQP template is configured to return undeliverable messages to the adapter.
When there is no ErrorMessageStrategy configured, the message is constructed from the data received from AMQP, with the following additional headers: amqp_returnReplyCode , amqp_returnReplyText , amqp_returnExchange , amqp_returnRoutingKey .
When there is an ErrorMessageStrategy , the message is an ErrorMessage with a ReturnedAmqpMessageException payload.
Optional. |
16 | A reference to an ErrorMessageStrategy implementation used to build ErrorMessage instances when sending returned or negatively acknowledged messages. |
17 | A reference to an AmqpHeaderMapper to use when sending AMQP Messages.
By default, only standard AMQP properties (such as contentType ) are copied to the Spring Integration MessageHeaders .
Any user-defined headers is not copied to the message by the default`DefaultAmqpHeaderMapper`.
Not allowed if 'request-header-names' is provided.
Optional. |
18 | Comma-separated list of names of AMQP Headers to be mapped from the MessageHeaders to the AMQP Message.
Not allowed if the 'header-mapper' reference is provided.
The values in this list can also be simple patterns to be matched against the header names (e.g. "*" or "thing1*, thing2" or "*thing1" ). |
19 | When set to false , the endpoint attempts to connect to the broker during application context initialization.
This allows “fail fast” detection of bad configuration but also causes initialization to fail if the broker is down.
When true (the default), the connection is established (if it does not already exist because some other component established it) when the first message is sent. |
20 | When set to true , payloads of type Iterable<Message<?>> will be sent as discrete messages on the same channel within the scope of a single RabbitTemplate invocation.
Requires a RabbitTemplate .
When wait-for-confirms is true, RabbitTemplate.waitForConfirmsOrDie() is invoked after the messages have been sent.
With a transactional template, the sends will be performed in either a new transaction or one that has already been started (if present). |
return-channel
Using a |
