Jackson JSON
Spring offers support for the Jackson JSON library.spring-doc.cn
JSON Views
Spring MVC provides built-in support for Jackson’s Serialization Views, which allow rendering only a subset of all fields in an Object. To use it with @ResponseBody or ResponseEntity controller methods, you can use Jackson’s @JsonView annotation to activate a serialization view class, as the following example shows:spring-doc.cn
@RestController
public class UserController {
	@GetMapping("/user")
	@JsonView(User.WithoutPasswordView.class)
	public User getUser() {
		return new User("eric", "7!jd#h23");
public class User {
	public interface WithoutPasswordView {};
	public interface WithPasswordView extends WithoutPasswordView {};
	private String username;
	private String password;
	public User() {
	public User(String username, String password) {
		this.username = username;
		this.password = password;
	@JsonView(WithoutPasswordView.class)
	public String getUsername() {
		return this.username;
	@JsonView(WithPasswordView.class)
	public String getPassword() {
		return this.password;
@RestController
	@JsonView(User.WithoutPasswordView::class)
	fun getUser() = User("eric", "7!jd#h23")
class User(
		@JsonView(WithoutPasswordView::class) val username: String,
		@JsonView(WithPasswordView::class) val password: String) {
	interface WithPasswordView : WithoutPasswordView
@JsonView allows an array of view classes, but you can specify only one per controller method. If you need to activate multiple views, you can use a composite interface.
If you want to do the above programmatically, instead of declaring an @JsonView annotation, wrap the return value with MappingJacksonValue and use it to supply the serialization view:spring-doc.cn
@RestController
	public MappingJacksonValue getUser() {
		User user = new User("eric", "7!jd#h23");
		MappingJacksonValue value = new MappingJacksonValue(user);
		value.setSerializationView(User.WithoutPasswordView.class);
		return value;
@RestController
	fun getUser(): MappingJacksonValue {
		val value = MappingJacksonValue(User("eric", "7!jd#h23"))
		value.serializationView = User.WithoutPasswordView::class.java
		return value
For controllers that rely on view resolution, you can add the serialization view class to the model, as the following example shows:spring-doc.cn
@Controller
public class UserController extends AbstractController {
	public String getUser(Model model) {
		model.addAttribute("user", new User("eric", "7!jd#h23"));
		model.addAttribute(JsonView.class.getName(), User.WithoutPasswordView.class);
		return "userView";
@Controller
class UserController : AbstractController() {
	fun getUser(model: Model): String {
		model["user"] = User("eric", "7!jd#h23")
		model[JsonView::class.qualifiedName] = User.WithoutPasswordView::class.java
		return "userView"
