Methods
You can invoke methods by using typical Java programming syntax. You can also invoke methods on literals. Variable arguments are also supported. The following examples show how to invoke methods:spring-doc.cn
// string literal, evaluates to "bc"
String bc = parser.parseExpression("'abc'.substring(1, 3)").getValue(String.class);
// evaluates to true
boolean isMember = parser.parseExpression("isMember('Mihajlo Pupin')").getValue(
		societyContext, Boolean.class);
val bc = parser.parseExpression("'abc'.substring(1, 3)").getValue(String::class.java)
val isMember = parser.parseExpression("isMember('Mihajlo Pupin')").getValue(
		societyContext, Boolean::class.java)
