Context Configuration with Dynamic Property Sources
The Spring TestContext Framework provides support for dynamic properties via the DynamicPropertyRegistry, the @DynamicPropertySource annotation, and the DynamicPropertyRegistrar API.spring-doc.cn
The dynamic property source infrastructure was originally designed to allow properties from Testcontainers based tests to be exposed easily to Spring integration tests. However, these features may be used with any form of external resource whose lifecycle is managed outside the test’s ApplicationContext or with beans whose lifecycle is managed by the test’s ApplicationContext.spring-doc.cn
Precedence
Dynamic properties have higher precedence than those loaded from @TestPropertySource, the operating system’s environment, Java system properties, or property sources added by the application declaratively by using @PropertySource or programmatically. Thus, dynamic properties can be used to selectively override properties loaded via @TestPropertySource, system property sources, and application property sources.spring-doc.cn
A DynamicPropertyRegistry is used to add name-value pairs to the Environment. Values are dynamic and provided via a Supplier which is only invoked when the property is resolved. Typically, method references are used to supply values. The following sections provide examples of how to use the DynamicPropertyRegistry.spring-doc.cn
In contrast to the @TestPropertySource annotation that is applied at the class level, @DynamicPropertySource can be applied to static methods in integration test classes in order to add properties with dynamic values to the set of PropertySources in the Environment for the ApplicationContext loaded for the integration test.spring-doc.cn
Methods in integration test classes that are annotated with @DynamicPropertySource must be static and must accept a single DynamicPropertyRegistry argument. See the class-level javadoc for DynamicPropertyRegistry for further details.spring-doc.cn
If you use @DynamicPropertySource in a base class and discover that tests in subclasses fail because the dynamic properties change between subclasses, you may need to annotate your base class with @DirtiesContext to ensure that each subclass gets its own ApplicationContext with the correct dynamic properties.spring-doc.cn
The following example uses the Testcontainers project to manage a Redis container outside of the Spring ApplicationContext. The IP address and port of the managed Redis container are made available to components within the test’s ApplicationContext via the redis.host and redis.port properties. These properties can be accessed via Spring’s Environment abstraction or injected directly into Spring-managed components – for example, via @Value("${redis.host}") and @Value("${redis.port}"), respectively.spring-doc.cn
@SpringJUnitConfig(/* ... */)
@Testcontainers
class ExampleIntegrationTests {
	@Container
	static GenericContainer redis =
		new GenericContainer("redis:5.0.3-alpine").withExposedPorts(6379);
	static void redisProperties(DynamicPropertyRegistry registry) {
		registry.add("redis.host", redis::getHost);
		registry.add("redis.port", redis::getFirstMappedPort);
	// tests ...
@Testcontainers
	companion object {
		@Container
		@JvmStatic
		val redis: GenericContainer =
		@JvmStatic
		fun redisProperties(registry: DynamicPropertyRegistry) {
	// tests ...
As an alternative to implementing @DynamicPropertySource methods in integration test classes, you can register implementations of the DynamicPropertyRegistrar API as beans within the test’s ApplicationContext. Doing so allows you to support additional use cases that are not possible with a @DynamicPropertySource method. For example, since a DynamicPropertyRegistrar is itself a bean in the ApplicationContext, it can interact with other beans in the context and register dynamic properties that are sourced from those beans.spring-doc.cn
Any bean in a test’s ApplicationContext that implements the DynamicPropertyRegistrar interface will be automatically detected and eagerly initialized before the singleton pre-instantiation phase, and the accept() methods of such beans will be invoked with a DynamicPropertyRegistry that performs the actual dynamic property registration on behalf of the registrar.spring-doc.cn
Any interaction with other beans results in eager initialization of those other beans and their dependencies.
The following example demonstrates how to implement a DynamicPropertyRegistrar as a lambda expression that registers a dynamic property for the ApiServer bean. The api.url property can be accessed via Spring’s Environment abstraction or injected directly into other Spring-managed components – for example, via @Value("${api.url}"), and the value of the api.url property will be dynamically retrieved from the ApiServer bean.spring-doc.cn
class TestConfig {
	ApiServer apiServer() {
		return new ApiServer();
	DynamicPropertyRegistrar apiPropertiesRegistrar(ApiServer apiServer) {
		return registry -> registry.add("api.url", apiServer::getUrl);
class TestConfig {
	fun apiServer(): ApiServer {
		return ApiServer()
	fun apiPropertiesRegistrar(apiServer: ApiServer): DynamicPropertyRegistrar {
