Email
This section describes how to send email with the Spring Framework.spring-doc.cn
Library dependencies
The following JAR needs to be on the classpath of your application in order to use the Spring Framework’s email support:spring-doc.cn
This library is freely available on the web — for example, in Maven Central as com.sun.mail:jakarta.mail. Please make sure to use the latest 2.x version (which uses the jakarta.mail package namespace) rather than Jakarta Mail 1.6.x (which uses the javax.mail package namespace).spring-doc.cn
The Spring Framework provides a helpful utility library for sending email that shields you from the specifics of the underlying mailing system and is responsible for low-level resource handling on behalf of the client.spring-doc.cn
The org.springframework.mail package is the root level package for the Spring Framework’s email support. The central interface for sending emails is the MailSender interface. A simple value object that encapsulates the properties of a simple mail such as from and to (plus many others) is the SimpleMailMessage class. This package also contains a hierarchy of checked exceptions that provide a higher level of abstraction over the lower level mail system exceptions, with the root exception being MailException. See the javadoc for more information on the rich mail exception hierarchy.spring-doc.cn
The org.springframework.mail.javamail.JavaMailSender interface adds specialized JavaMail features, such as MIME message support to the MailSender interface (from which it inherits). JavaMailSender also provides a callback interface called org.springframework.mail.javamail.MimeMessagePreparator for preparing a MimeMessage.spring-doc.cn
Usage
Assume that we have a business interface called OrderManager, as the following example shows:spring-doc.cn
public interface OrderManager {
	void placeOrder(Order order);
	fun placeOrder(order: Order)
Further assume that we have a requirement stating that an email message with an order number needs to be generated and sent to a customer who placed the relevant order.spring-doc.cn
Basic MailSender and SimpleMailMessage Usage
The following example shows how to use MailSender and SimpleMailMessage to send an email when someone places an order:spring-doc.cn
public class SimpleOrderManager implements OrderManager {
	private MailSender mailSender;
	private SimpleMailMessage templateMessage;
	public void setMailSender(MailSender mailSender) {
		this.mailSender = mailSender;
	public void setTemplateMessage(SimpleMailMessage templateMessage) {
		this.templateMessage = templateMessage;
	public void placeOrder(Order order) {
		// Do the business calculations...
		// Call the collaborators to persist the order...
		// Create a thread-safe "copy" of the template message and customize it
		SimpleMailMessage msg = new SimpleMailMessage(this.templateMessage);
		msg.setTo(order.getCustomer().getEmailAddress());
		msg.setText(
				"Dear " + order.getCustomer().getFirstName()
						+ order.getCustomer().getLastName()
						+ ", thank you for placing order. Your order number is "
						+ order.getOrderNumber());
		try {
			this.mailSender.send(msg);
		catch (MailException ex) {
			// simply log it and go on...
			System.err.println(ex.getMessage());
class SimpleOrderManager : OrderManager {
	lateinit var mailSender: MailSender
	lateinit var templateMessage: SimpleMailMessage
	override fun placeOrder(order: Order) {
		val msg = SimpleMailMessage(this.templateMessage)
		msg.setTo(order.customer.emailAddress)
		msg.text = ("Dear " + order.customer.firstName
				+ order.customer.lastName
				+ order.orderNumber)
		try {
		} catch (ex: MailException) {
			System.err.println(ex.message)
The following example shows the bean definitions for the preceding code:spring-doc.cn
JavaMailSender mailSender() {
	JavaMailSenderImpl mailSender = new JavaMailSenderImpl();
	mailSender.setHost("mail.mycompany.example");
	return mailSender;
@Bean // this is a template message that we can pre-load with default state
SimpleMailMessage templateMessage() {
	SimpleMailMessage message = new SimpleMailMessage();
	message.setFrom("[email protected]");
	message.setSubject("Your order");
	return message;
SimpleOrderManager orderManager(JavaMailSender mailSender, SimpleMailMessage templateMessage) {
	SimpleOrderManager orderManager = new SimpleOrderManager();
	orderManager.setMailSender(mailSender);
	orderManager.setTemplateMessage(templateMessage);
	return orderManager;
fun mailSender(): JavaMailSender {
	return JavaMailSenderImpl().apply {
		host = "mail.mycompany.example"
fun templateMessage() = SimpleMailMessage().apply {
	from = "[email protected]"
	subject = "Your order"
fun orderManager(javaMailSender: JavaMailSender, simpleTemplateMessage: SimpleMailMessage) = SimpleOrderManager().apply {
	mailSender = javaMailSender
	templateMessage = simpleTemplateMessage
<bean id="mailSender" class="org.springframework.mail.javamail.JavaMailSenderImpl">
	<property name="host" value="mail.mycompany.example"/>
</bean>
<!-- this is a template message that we can pre-load with default state -->
<bean id="templateMessage" class="org.springframework.mail.SimpleMailMessage">
	<property name="from" value="[email protected]"/>
	<property name="subject" value="Your order"/>
</bean>
<bean id="orderManager" class="com.mycompany.businessapp.support.SimpleOrderManager">
	<property name="mailSender" ref="mailSender"/>
	<property name="templateMessage" ref="templateMessage"/>
</bean>
Using JavaMailSender and MimeMessagePreparator
This section describes another implementation of OrderManager that uses the MimeMessagePreparator callback interface. In the following example, the mailSender property is of type JavaMailSender so that we are able to use the JavaMail MimeMessage class:spring-doc.cn
import jakarta.mail.Message;
import jakarta.mail.MessagingException;
import jakarta.mail.internet.InternetAddress;
import jakarta.mail.internet.MimeMessage;
import org.springframework.mail.MailException;
import org.springframework.mail.javamail.JavaMailSender;
import org.springframework.mail.javamail.MimeMessagePreparator;
	private JavaMailSender mailSender;
	public void setMailSender(JavaMailSender mailSender) {
	public void placeOrder(final Order order) {
		MimeMessagePreparator preparator = new MimeMessagePreparator() {
			public void prepare(MimeMessage mimeMessage) throws Exception {
				mimeMessage.setRecipient(Message.RecipientType.TO,
						new InternetAddress(order.getCustomer().getEmailAddress()));
				mimeMessage.setFrom(new InternetAddress("[email protected]"));
				mimeMessage.setText("Dear " + order.getCustomer().getFirstName() + " " +
						order.getCustomer().getLastName() + ", thanks for your order. " +
						"Your order number is " + order.getOrderNumber() + ".");
		try {
			this.mailSender.send(preparator);
The mail code is a crosscutting concern and could well be a candidate for refactoring into a custom Spring AOP aspect, which could then be run at appropriate joinpoints on the OrderManager target.
The Spring Framework’s mail support ships with the standard JavaMail implementation. See the relevant javadoc for more information.spring-doc.cn
Using the JavaMail MimeMessageHelper
A class that comes in pretty handy when dealing with JavaMail messages is org.springframework.mail.javamail.MimeMessageHelper, which shields you from having to use the verbose JavaMail API. Using the MimeMessageHelper, it is pretty easy to create a MimeMessage, as the following example shows:spring-doc.cn
// of course you would use DI in any real-world cases
JavaMailSenderImpl sender = new JavaMailSenderImpl();
sender.setHost("mail.host.com");
MimeMessage message = sender.createMimeMessage();
MimeMessageHelper helper = new MimeMessageHelper(message);
helper.setTo("[email protected]");
helper.setText("Thank you for ordering!");
sender.send(message);
Sending Attachments and Inline Resources
Multipart email messages allow for both attachments and inline resources. Examples of inline resources include an image or a stylesheet that you want to use in your message but that you do not want displayed as an attachment.spring-doc.cn
The following example shows you how to use the MimeMessageHelper to send an email with a single JPEG image attachment:spring-doc.cn
// use the true flag to indicate you need a multipart message
MimeMessageHelper helper = new MimeMessageHelper(message, true);
helper.setText("Check out this image!");
// let's attach the infamous windows Sample file (this time copied to c:/)
FileSystemResource file = new FileSystemResource(new File("c:/Sample.jpg"));
helper.addAttachment("CoolImage.jpg", file);
Inline Resources
The following example shows you how to use the MimeMessageHelper to send an email with an inline image:spring-doc.cn
// use the true flag to indicate the text included is HTML
helper.setText("<html><body><img src='cid:identifier1234'></body></html>", true);
// let's include the infamous windows Sample file (this time copied to c:/)
FileSystemResource res = new FileSystemResource(new File("c:/Sample.jpg"));
helper.addInline("identifier1234", res);
Inline resources are added to the MimeMessage by using the specified Content-ID (identifier1234 in the above example). The order in which you add the text and the resource are very important. Be sure to first add the text and then the resources. If you are doing it the other way around, it does not work.
Creating Email Content by Using a Templating Library
The code in the examples shown in the previous sections explicitly created the content of the email message, by using methods calls such as message.setText(..). This is fine for simple cases, and it is okay in the context of the aforementioned examples, where the intent was to show you the very basics of the API.spring-doc.cn
In your typical enterprise application, though, developers often do not create the content of email messages by using the previously shown approach for a number of reasons:spring-doc.cn
  • Creating HTML-based email content in Java code is tedious and error prone.spring-doc.cn
  • There is no clear separation between display logic and business logic.spring-doc.cn
  • Changing the display structure of the email content requires writing Java code, recompiling, redeploying, and so on.spring-doc.cn
Typically, the approach taken to address these issues is to use a template library (such as FreeMarker) to define the display structure of email content. This leaves your code tasked only with creating the data that is to be rendered in the email template and sending the email. It is definitely a best practice when the content of your email messages becomes even moderately complex, and, with the Spring Framework’s support classes for FreeMarker, it becomes quite easy to do.spring-doc.cn
