SockJS Fallback
Over the public Internet, restrictive proxies outside your control may preclude WebSocket interactions, either because they are not configured to pass on the Upgrade header or because they close long-lived connections that appear to be idle.spring-doc.cn
The solution to this problem is WebSocket emulation — that is, attempting to use WebSocket first and then falling back on HTTP-based techniques that emulate a WebSocket interaction and expose the same application-level API.spring-doc.cn
On the Servlet stack, the Spring Framework provides both server (and also client) support for the SockJS protocol.spring-doc.cn
Overview
The goal of SockJS is to let applications use a WebSocket API but fall back to non-WebSocket alternatives when necessary at runtime, without the need to change application code.spring-doc.cn
SockJS consists of:spring-doc.cn
SockJS is designed for use in browsers. It uses a variety of techniques to support a wide range of browser versions. For the full list of SockJS transport types and browsers, see the SockJS client page. Transports fall in three general categories: WebSocket, HTTP Streaming, and HTTP Long Polling. For an overview of these categories, see this blog post.spring-doc.cn
The SockJS client begins by sending GET /info to obtain basic information from the server. After that, it must decide what transport to use. If possible, WebSocket is used. If not, in most browsers, there is at least one HTTP streaming option. If not, then HTTP (long) polling is used.spring-doc.cn
All transport requests have the following URL structure:spring-doc.cn
https://host:port/myApp/myEndpoint/{server-id}/{session-id}/{transport}
  • {server-id} is useful for routing requests in a cluster but is not used otherwise.spring-doc.cn
  • {session-id} correlates HTTP requests belonging to a SockJS session.spring-doc.cn
  • {transport} indicates the transport type (for example, websocket, xhr-streaming, and others).spring-doc.cn
The WebSocket transport needs only a single HTTP request to do the WebSocket handshake. All messages thereafter are exchanged on that socket.spring-doc.cn
HTTP transports require more requests. Ajax/XHR streaming, for example, relies on one long-running request for server-to-client messages and additional HTTP POST requests for client-to-server messages. Long polling is similar, except that it ends the current request after each server-to-client send.spring-doc.cn
SockJS adds minimal message framing. For example, the server sends the letter o (“open” frame) initially, messages are sent as a["message1","message2"] (JSON-encoded array), the letter h (“heartbeat” frame) if no messages flow for 25 seconds (by default), and the letter c (“close” frame) to close the session.spring-doc.cn
To learn more, run an example in a browser and watch the HTTP requests. The SockJS client allows fixing the list of transports, so it is possible to see each transport one at a time. The SockJS client also provides a debug flag, which enables helpful messages in the browser console. On the server side, you can enable TRACE logging for org.springframework.web.socket. For even more detail, see the SockJS protocol narrated test.spring-doc.cn
Enabling SockJS
You can enable SockJS through configuration, as the following example shows:spring-doc.cn
@EnableWebSocket
public class WebSocketConfiguration implements WebSocketConfigurer {
	public void registerWebSocketHandlers(WebSocketHandlerRegistry registry) {
		registry.addHandler(myHandler(), "/myHandler").withSockJS();
	public WebSocketHandler myHandler() {
		return new MyHandler();
@EnableWebSocket
class WebSocketConfiguration : WebSocketConfigurer {
	override fun registerWebSocketHandlers(registry: WebSocketHandlerRegistry) {
	fun myHandler(): WebSocketHandler {
		return MyHandler()
	   xmlns:websocket="http://www.springframework.org/schema/websocket"
	   xsi:schemaLocation="
		https://www.springframework.org/schema/websocket/spring-websocket.xsd">
	<websocket:handlers>
		<websocket:mapping path="/myHandler" handler="myHandler"/>
		<websocket:sockjs/>
	</websocket:handlers>
	<bean id="myHandler" class="org.springframework.docs.web.websocket.websocketserverhandler.MyHandler"/>
</beans>
The preceding example is for use in Spring MVC applications and should be included in the configuration of a DispatcherServlet. However, Spring’s WebSocket and SockJS support does not depend on Spring MVC. It is relatively simple to integrate into other HTTP serving environments with the help of SockJsHttpRequestHandler.spring-doc.cn
On the browser side, applications can use the sockjs-client (version 1.0.x). It emulates the W3C WebSocket API and communicates with the server to select the best transport option, depending on the browser in which it runs. See the sockjs-client page and the list of transport types supported by browser. The client also provides several configuration options — for example, to specify which transports to include.spring-doc.cn
IE 8 and 9
Internet Explorer 8 and 9 remain in use. They are a key reason for having SockJS. This section covers important considerations about running in those browsers.spring-doc.cn
The SockJS client supports Ajax/XHR streaming in IE 8 and 9 by using Microsoft’s XDomainRequest. That works across domains but does not support sending cookies. Cookies are often essential for Java applications. However, since the SockJS client can be used with many server types (not just Java ones), it needs to know whether cookies matter. If so, the SockJS client prefers Ajax/XHR for streaming. Otherwise, it relies on an iframe-based technique.spring-doc.cn
The first /info request from the SockJS client is a request for information that can influence the client’s choice of transports. One of those details is whether the server application relies on cookies (for example, for authentication purposes or clustering with sticky sessions). Spring’s SockJS support includes a property called sessionCookieNeeded. It is enabled by default, since most Java applications rely on the JSESSIONID cookie. If your application does not need it, you can turn off this option, and SockJS client should then choose xdr-streaming in IE 8 and 9.spring-doc.cn
If you do use an iframe-based transport, keep in mind that browsers can be instructed to block the use of IFrames on a given page by setting the HTTP response header X-Frame-Options to DENY, SAMEORIGIN, or ALLOW-FROM <origin>. This is used to prevent clickjacking.spring-doc.cn
Spring Security 3.2+ provides support for setting X-Frame-Options on every response. By default, the Spring Security Java configuration sets it to DENY. In 3.2, the Spring Security XML namespace does not set that header by default but can be configured to do so. In the future, it may set it by default.spring-doc.cn
See Default Security Headers of the Spring Security documentation for details on how to configure the setting of the X-Frame-Options header. You can also see gh-2718 for additional background.spring-doc.cn
If your application adds the X-Frame-Options response header (as it should!) and relies on an iframe-based transport, you need to set the header value to SAMEORIGIN or ALLOW-FROM <origin>. The Spring SockJS support also needs to know the location of the SockJS client, because it is loaded from the iframe. By default, the iframe is set to download the SockJS client from a CDN location. It is a good idea to configure this option to use a URL from the same origin as the application.spring-doc.cn
The following example shows how to do so in Java configuration:spring-doc.cn
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
	public void registerStompEndpoints(StompEndpointRegistry registry) {
		registry.addEndpoint("/portfolio").withSockJS()
				.setClientLibraryUrl("http://localhost:8080/myapp/js/sockjs-client.js");
The XML namespace provides a similar option through the <websocket:sockjs> element.spring-doc.cn
During initial development, do enable the SockJS client devel mode that prevents the browser from caching SockJS requests (like the iframe) that would otherwise be cached. For details on how to enable it see the SockJS client page.
Heartbeats
The SockJS protocol requires servers to send heartbeat messages to preclude proxies from concluding that a connection is hung. The Spring SockJS configuration has a property called heartbeatTime that you can use to customize the frequency. By default, a heartbeat is sent after 25 seconds, assuming no other messages were sent on that connection. This 25-second value is in line with the following IETF recommendation for public Internet applications.spring-doc.cn
When using STOMP over WebSocket and SockJS, if the STOMP client and server negotiate heartbeats to be exchanged, the SockJS heartbeats are disabled.
The Spring SockJS support also lets you configure the TaskScheduler to schedule heartbeats tasks. The task scheduler is backed by a thread pool, with default settings based on the number of available processors. You should consider customizing the settings according to your specific needs.spring-doc.cn
Client Disconnects
HTTP streaming and HTTP long polling SockJS transports require a connection to remain open longer than usual. For an overview of these techniques, see this blog post.spring-doc.cn
In Servlet containers, this is done through Servlet 3 asynchronous support that allows exiting the Servlet container thread, processing a request, and continuing to write to the response from another thread.spring-doc.cn
A specific issue is that the Servlet API does not provide notifications for a client that has gone away. See eclipse-ee4j/servlet-api#44. However, Servlet containers raise an exception on subsequent attempts to write to the response. Since Spring’s SockJS Service supports server-sent heartbeats (every 25 seconds by default), that means a client disconnect is usually detected within that time period (or earlier, if messages are sent more frequently).spring-doc.cn
As a result, network I/O failures can occur because a client has disconnected, which can fill the log with unnecessary stack traces. Spring makes a best effort to identify such network failures that represent client disconnects (specific to each server) and log a minimal message by using the dedicated log category, DISCONNECTED_CLIENT_LOG_CATEGORY (defined in AbstractSockJsSession). If you need to see the stack traces, you can set that log category to TRACE.
SockJS and CORS
If you allow cross-origin requests (see Allowed Origins), the SockJS protocol uses CORS for cross-domain support in the XHR streaming and polling transports. Therefore, CORS headers are added automatically, unless the presence of CORS headers in the response is detected. So, if an application is already configured to provide CORS support (for example, through a Servlet Filter), Spring’s SockJsService skips this part.spring-doc.cn
It is also possible to disable the addition of these CORS headers by setting the suppressCors property in Spring’s SockJsService.spring-doc.cn
SockJS expects the following headers and values:spring-doc.cn
  • Access-Control-Allow-Origin: Initialized from the value of the Origin request header.spring-doc.cn
  • Access-Control-Allow-Credentials: Always set to true.spring-doc.cn
  • Access-Control-Request-Headers: Initialized from values from the equivalent request header.spring-doc.cn
  • Access-Control-Allow-Methods: The HTTP methods a transport supports (see TransportType enum).spring-doc.cn
  • Access-Control-Max-Age: Set to 31536000 (1 year).spring-doc.cn
For the exact implementation, see addCorsHeaders in AbstractSockJsService and the TransportType enum in the source code.spring-doc.cn
Alternatively, if the CORS configuration allows it, consider excluding URLs with the SockJS endpoint prefix, thus letting Spring’s SockJsService handle it.spring-doc.cn
SockJsClient
Spring provides a SockJS Java client to connect to remote SockJS endpoints without using a browser. This can be especially useful when there is a need for bidirectional communication between two servers over a public network (that is, where network proxies can preclude the use of the WebSocket protocol). A SockJS Java client is also very useful for testing purposes (for example, to simulate a large number of concurrent users).spring-doc.cn
The SockJS Java client supports the websocket, xhr-streaming, and xhr-polling transports. The remaining ones only make sense for use in a browser.spring-doc.cn
You can configure the WebSocketTransport with:spring-doc.cn
  • StandardWebSocketClient in a JSR-356 runtime.spring-doc.cn
  • JettyWebSocketClient by using the Jetty 9+ native WebSocket API.spring-doc.cn
  • Any implementation of Spring’s WebSocketClient.spring-doc.cn
An XhrTransport, by definition, supports both xhr-streaming and xhr-polling, since, from a client perspective, there is no difference other than in the URL used to connect to the server. At present there are two implementations:spring-doc.cn
  • RestTemplateXhrTransport uses Spring’s RestTemplate for HTTP requests.spring-doc.cn
  • JettyXhrTransport uses Jetty’s HttpClient for HTTP requests.spring-doc.cn
The following example shows how to create a SockJS client and connect to a SockJS endpoint:spring-doc.cn
List<Transport> transports = new ArrayList<>(2);
transports.add(new WebSocketTransport(new StandardWebSocketClient()));
transports.add(new RestTemplateXhrTransport());
SockJsClient sockJsClient = new SockJsClient(transports);
sockJsClient.doHandshake(new MyWebSocketHandler(), "ws://example.com:8080/sockjs");
SockJS uses JSON formatted arrays for messages. By default, Jackson 2 is used and needs to be on the classpath. Alternatively, you can configure a custom implementation of SockJsMessageCodec and configure it on the SockJsClient.
To use SockJsClient to simulate a large number of concurrent users, you need to configure the underlying HTTP client (for XHR transports) to allow a sufficient number of connections and threads. The following example shows how to do so with Jetty:spring-doc.cn
HttpClient jettyHttpClient = new HttpClient();
jettyHttpClient.setMaxConnectionsPerDestination(1000);
jettyHttpClient.setExecutor(new QueuedThreadPool(1000));
The following example shows the server-side SockJS-related properties (see javadoc for details) that you should also consider customizing:spring-doc.cn
public class WebSocketConfig extends WebSocketMessageBrokerConfigurationSupport {
		registry.addEndpoint("/sockjs").withSockJS()
			.setStreamBytesLimit(512 * 1024) (1)
			.setHttpMessageCacheSize(1000) (2)
			.setDisconnectDelay(30 * 1000); (3)
1 Set the streamBytesLimit property to 512KB (the default is 128KB — 128 * 1024).
2 Set the httpMessageCacheSize property to 1,000 (the default is 100).
3 Set the disconnectDelay property to 30 property seconds (the default is five seconds — 5 * 1000).
