RSS and Atom
Both AbstractAtomFeedView and AbstractRssFeedView inherit from the AbstractFeedView base class and are used to provide Atom and RSS Feed views, respectively. They are based on ROME project and are located in the package org.springframework.web.servlet.view.feed.spring-doc.cn
AbstractAtomFeedView requires you to implement the buildFeedEntries() method and optionally override the buildFeedMetadata() method (the default implementation is empty). The following example shows how to do so:spring-doc.cn
public class SampleContentAtomView extends AbstractAtomFeedView {
	protected void buildFeedMetadata(Map<String, Object> model,
			Feed feed, HttpServletRequest request) {
		// implementation omitted
	protected List<Entry> buildFeedEntries(Map<String, Object> model,
			HttpServletRequest request, HttpServletResponse response) throws Exception {
class SampleContentAtomView : AbstractAtomFeedView() {
	override fun buildFeedMetadata(model: Map<String, Any>,
			feed: Feed, request: HttpServletRequest) {
	override fun buildFeedEntries(model: Map<String, Any>,
			request: HttpServletRequest, response: HttpServletResponse): List<Entry> {
Similar requirements apply for implementing AbstractRssFeedView, as the following example shows:spring-doc.cn
public class SampleContentRssView extends AbstractRssFeedView {
			Channel feed, HttpServletRequest request) {
	protected List<Item> buildFeedItems(Map<String, Object> model,
class SampleContentRssView : AbstractRssFeedView() {
								feed: Channel, request: HttpServletRequest) {
	override fun buildFeedItems(model: Map<String, Any>,
			request: HttpServletRequest, response: HttpServletResponse): List<Item> {
The buildFeedItems() and buildFeedEntries() methods pass in the HTTP request, in case you need to access the Locale. The HTTP response is passed in only for the setting of cookies or other HTTP headers. The feed is automatically written to the response object after the method returns.spring-doc.cn
For an example of creating an Atom view, see Alef Arendsen’s Spring Team Blog entry.spring-doc.cn
