Operators
Relational Operators
The relational operators (equal, not equal, less than, less than or equal, greater than, and greater than or equal) are supported by using standard operator notation. These operators work on Number types as well as types implementing Comparable. The following listing shows a few examples of relational operators:spring-doc.cn
// evaluates to true
boolean trueValue = parser.parseExpression("2 == 2").getValue(Boolean.class);
// evaluates to false
boolean falseValue = parser.parseExpression("2 < -5.0").getValue(Boolean.class);
boolean trueValue = parser.parseExpression("'black' < 'block'").getValue(Boolean.class);
// uses CustomValue:::compareTo
boolean trueValue = parser.parseExpression("new CustomValue(1) < new CustomValue(2)").getValue(Boolean.class);
val trueValue = parser.parseExpression("2 == 2").getValue(Boolean::class.java)
val falseValue = parser.parseExpression("2 < -5.0").getValue(Boolean::class.java)
val trueValue = parser.parseExpression("'black' < 'block'").getValue(Boolean::class.java)
val trueValue = parser.parseExpression("new CustomValue(1) < new CustomValue(2)").getValue(Boolean::class.java);
Greater-than and less-than comparisons against null follow a simple rule: null is treated as nothing (that is NOT as zero). As a consequence, any other value is always greater than null (X > null is always true) and no other value is ever less than nothing (X < null is always false).spring-doc.cn
If you prefer numeric comparisons instead, avoid number-based null comparisons in favor of comparisons against zero (for example, X > 0 or X < 0).spring-doc.cn
Each symbolic operator can also be specified as a purely textual equivalent. This avoids problems where the symbols used have special meaning for the document type in which the expression is embedded (such as in an XML document). The textual equivalents are:spring-doc.cn
All of the textual operators are case-insensitive.spring-doc.cn
In addition to the standard relational operators, SpEL supports the between, instanceof, and regular expression-based matches operators. The following listing shows examples of all three:spring-doc.cn
boolean result;
result = parser.parseExpression(
		"1 between {1, 5}").getValue(Boolean.class);
		"1 between {10, 15}").getValue(Boolean.class);
		"'elephant' between {'aardvark', 'zebra'}").getValue(Boolean.class);
		"'elephant' between {'aardvark', 'cobra'}").getValue(Boolean.class);
		"123 instanceof T(Integer)").getValue(Boolean.class);
		"'xyz' instanceof T(Integer)").getValue(Boolean.class);
		"'5.00' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean.class);
		"'5.0067' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean.class);
var result = parser.parseExpression(
		"1 between {1, 5}").getValue(Boolean::class.java)
		"1 between {10, 15}").getValue(Boolean::class.java)
		"'elephant' between {'aardvark', 'zebra'}").getValue(Boolean::class.java)
		"'elephant' between {'aardvark', 'cobra'}").getValue(Boolean::class.java)
		"123 instanceof T(Integer)").getValue(Boolean::class.java)
		"'xyz' instanceof T(Integer)").getValue(Boolean::class.java)
		"'5.00' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean::class.java)
		"'5.0067' matches '^-?\\d+(\\.\\d{2})?$'").getValue(Boolean::class.java)
The syntax for the between operator is <input> between {<range_begin>, <range_end>}, which is effectively a shortcut for <input> >= <range_begin> && <input> <= <range_end>}.spring-doc.cn
Consequently, 1 between {1, 5} evaluates to true, while 1 between {5, 1} evaluates to false.spring-doc.cn
Be careful with primitive types, as they are immediately boxed up to their wrapper types. For example, 1 instanceof T(int) evaluates to false, while 1 instanceof T(Integer) evaluates to true.
Logical Operators
SpEL supports the following logical (boolean) operators:spring-doc.cn
The following example shows how to use the logical operators:spring-doc.cn
// -- AND --
boolean falseValue = parser.parseExpression("true and false").getValue(Boolean.class);
String expression = "isMember('Nikola Tesla') and isMember('Mihajlo Pupin')";
boolean trueValue = parser.parseExpression(expression).getValue(societyContext, Boolean.class);
// -- OR --
boolean trueValue = parser.parseExpression("true or false").getValue(Boolean.class);
String expression = "isMember('Nikola Tesla') or isMember('Albert Einstein')";
// -- NOT --
boolean falseValue = parser.parseExpression("!true").getValue(Boolean.class);
// -- AND and NOT --
String expression = "isMember('Nikola Tesla') and !isMember('Mihajlo Pupin')";
boolean falseValue = parser.parseExpression(expression).getValue(societyContext, Boolean.class);
// -- AND --
val falseValue = parser.parseExpression("true and false").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') and isMember('Mihajlo Pupin')"
val trueValue = parser.parseExpression(expression).getValue(societyContext, Boolean::class.java)
// -- OR --
val trueValue = parser.parseExpression("true or false").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') or isMember('Albert Einstein')"
// -- NOT --
val falseValue = parser.parseExpression("!true").getValue(Boolean::class.java)
val expression = "isMember('Nikola Tesla') and !isMember('Mihajlo Pupin')"
val falseValue = parser.parseExpression(expression).getValue(societyContext, Boolean::class.java)
String Operators
You can use the following operators on strings.spring-doc.cn
The following example shows the String operators in use:spring-doc.cn
// -- Concatenation --
// evaluates to "hello world"
String helloWorld = parser.parseExpression("'hello' + ' ' + 'world'")
		.getValue(String.class);
// -- Character Subtraction --
// evaluates to 'a'
char ch = parser.parseExpression("'d' - 3")
		.getValue(char.class);
// -- Repeat --
// evaluates to "abcabc"
String repeated = parser.parseExpression("'abc' * 2")
val helloWorld = parser.parseExpression("'hello' + ' ' + 'world'")
		.getValue(String::class.java)
// evaluates to 'a'
val ch = parser.parseExpression("'d' - 3")
		.getValue(Character::class.java);
// -- Repeat --
val repeated = parser.parseExpression("'abc' * 2")
		.getValue(String::class.java);
Mathematical Operators
You can use the following operators on numbers, and standard operator precedence is enforced.spring-doc.cn
The division and modulus operators can also be specified as a purely textual equivalent. This avoids problems where the symbols used have special meaning for the document type in which the expression is embedded (such as in an XML document). The textual equivalents are:spring-doc.cn
The increment and decrement operators can be used with either prefix (++A, --A) or postfix (A++, A--) notation with variables or properties that can be written to.spring-doc.cn
The following example shows the mathematical operators in use:spring-doc.cn
Inventor inventor = new Inventor();
EvaluationContext context = SimpleEvaluationContext.forReadWriteDataBinding().build();
// -- Addition --
int two = parser.parseExpression("1 + 1").getValue(int.class);  // 2
// -- Subtraction --
int four = parser.parseExpression("1 - -3").getValue(int.class);  // 4
double d = parser.parseExpression("1000.00 - 1e4").getValue(double.class);  // -9000
// -- Increment --
// The counter property in Inventor has an initial value of 0.
// evaluates to 2; counter is now 1
two = parser.parseExpression("counter++ + 2").getValue(context, inventor, int.class);
// evaluates to 5; counter is now 2
int five = parser.parseExpression("3 + ++counter").getValue(context, inventor, int.class);
// -- Decrement --
// The counter property in Inventor has a value of 2.
// evaluates to 6; counter is now 1
int six = parser.parseExpression("counter-- + 4").getValue(context, inventor, int.class);
// evaluates to 5; counter is now 0
five = parser.parseExpression("5 + --counter").getValue(context, inventor, int.class);
// -- Multiplication --
six = parser.parseExpression("-2 * -3").getValue(int.class);  // 6
double twentyFour = parser.parseExpression("2.0 * 3e0 * 4").getValue(double.class);  // 24.0
// -- Division --
int minusTwo = parser.parseExpression("6 / -3").getValue(int.class);  // -2
double one = parser.parseExpression("8.0 / 4e0 / 2").getValue(double.class);  // 1.0
// -- Modulus --
int three = parser.parseExpression("7 % 4").getValue(int.class);  // 3
int oneInt = parser.parseExpression("8 / 5 % 2").getValue(int.class);  // 1
// -- Exponential power --
int maxInt = parser.parseExpression("(2^31) - 1").getValue(int.class);  // Integer.MAX_VALUE
int minInt = parser.parseExpression("-2^31").getValue(int.class);  // Integer.MIN_VALUE
// -- Operator precedence --
int minusTwentyOne = parser.parseExpression("1+2-3*8").getValue(int.class);  // -21
val inventor = Inventor()
val context = SimpleEvaluationContext.forReadWriteDataBinding().build()
// -- Addition --
var two = parser.parseExpression("1 + 1").getValue(Int::class.java)  // 2
val four = parser.parseExpression("1 - -3").getValue(Int::class.java)  // 4
val d = parser.parseExpression("1000.00 - 1e4").getValue(Double::class.java)  // -9000
// -- Increment --
two = parser.parseExpression("counter++ + 2").getValue(context, inventor, Int::class.java)
var five = parser.parseExpression("3 + ++counter").getValue(context, inventor, Int::class.java)
// -- Decrement --
var six = parser.parseExpression("counter-- + 4").getValue(context, inventor, Int::class.java)
five = parser.parseExpression("5 + --counter").getValue(context, inventor, Int::class.java)
six = parser.parseExpression("-2 * -3").getValue(Int::class.java)  // 6
val twentyFour = parser.parseExpression("2.0 * 3e0 * 4").getValue(Double::class.java)  // 24.0
// -- Division --
val minusTwo = parser.parseExpression("6 / -3").getValue(Int::class.java)  // -2
val one = parser.parseExpression("8.0 / 4e0 / 2").getValue(Double::class.java)  // 1.0
// -- Modulus --
val three = parser.parseExpression("7 % 4").getValue(Int::class.java)  // 3
val oneInt = parser.parseExpression("8 / 5 % 2").getValue(Int::class.java)  // 1
val maxInt = parser.parseExpression("(2^31) - 1").getValue(Int::class.java)  // Integer.MAX_VALUE
val minInt = parser.parseExpression("-2^31").getValue(Int::class.java)  // Integer.MIN_VALUE
val minusTwentyOne = parser.parseExpression("1+2-3*8").getValue(Int::class.java)  // -21
The Assignment Operator
To set a property, use the assignment operator (=). This is typically done within a call to setValue but can also be done inside a call to getValue. The following listing shows both ways to use the assignment operator:spring-doc.cn
parser.parseExpression("name").setValue(context, inventor, "Aleksandar Seovic");
// alternatively
String aleks = parser.parseExpression(
		"name = 'Aleksandar Seovic'").getValue(context, inventor, String.class);
// alternatively
val aleks = parser.parseExpression(
		"name = 'Aleksandar Seovic'").getValue(context, inventor, String::class.java)
Overloaded Operators
By default, the mathematical operations defined in SpEL’s Operation enum (ADD, SUBTRACT, DIVIDE, MULTIPLY, MODULUS, and POWER) support simple types like numbers. By providing an implementation of OperatorOverloader, the expression language can support these operations on other types.spring-doc.cn
For example, if we want to overload the ADD operator to allow two lists to be concatenated using the + sign, we can implement a custom OperatorOverloader as follows.spring-doc.cn
pubic class ListConcatenation implements OperatorOverloader {
	public boolean overridesOperation(Operation operation, Object left, Object right) {
		return (operation == Operation.ADD &&
				left instanceof List && right instanceof List);
	public Object operate(Operation operation, Object left, Object right) {
		if (operation == Operation.ADD &&
				left instanceof List list1 && right instanceof List list2) {
			List result = new ArrayList(list1);
			result.addAll(list2);
			return result;
		throw new UnsupportedOperationException(
			"No overload for operation %s and operands [%s] and [%s]"
				.formatted(operation, left, right));
If we register ListConcatenation as the OperatorOverloader in a StandardEvaluationContext, we can then evaluate expressions like {1, 2, 3} + {4, 5} as demonstrated in the following example.spring-doc.cn
StandardEvaluationContext context = new StandardEvaluationContext();
context.setOperatorOverloader(new ListConcatenation());
// evaluates to a new list: [1, 2, 3, 4, 5]
parser.parseExpression("{1, 2, 3} + {2 + 2, 5}").getValue(context, List.class);
StandardEvaluationContext context = StandardEvaluationContext()
context.setOperatorOverloader(ListConcatenation())
parser.parseExpression("{1, 2, 3} + {2 + 2, 5}").getValue(context, List::class.java)
An OperatorOverloader does not change the default semantics for an operator. For example, 2 + 2 in the above example still evaluates to 4.spring-doc.cn
Any expression that uses an overloaded operator cannot be compiled. See Compiler Limitations for details.spring-doc.cn
