Content Types
You can configure how Spring MVC determines the requested media types from the request (for example, Accept header, URL path extension, query parameter, and others).spring-doc.cn
By default, only the Accept header is checked.spring-doc.cn
If you must use URL-based content type resolution, consider using the query parameter strategy over path extensions. See Suffix Match and Suffix Match and RFD for more details.spring-doc.cn
You can customize requested content type resolution, as the following example shows:spring-doc.cn
public class WebConfiguration implements WebMvcConfigurer {
	public void configureContentNegotiation(ContentNegotiationConfigurer configurer) {
		configurer.mediaType("json", MediaType.APPLICATION_JSON);
		configurer.mediaType("xml", MediaType.APPLICATION_XML);
class WebConfiguration : WebMvcConfigurer {
	override fun configureContentNegotiation(configurer: ContentNegotiationConfigurer) {
<mvc:annotation-driven content-negotiation-manager="contentNegotiationManager"/>
<bean id="contentNegotiationManager" class="org.springframework.web.accept.ContentNegotiationManagerFactoryBean">
<property name="mediaTypes">
	<value>
		json=application/json
		xml=application/xml
	</value>
</property>
</bean>
