Context Configuration with Component Classes
To load an ApplicationContext for your tests by using component classes (see Java-based container configuration), you can annotate your test class with @ContextConfiguration and configure the classes attribute with an array that contains references to component classes. The following example shows how to do so:spring-doc.cn
@ExtendWith(SpringExtension.class)
// ApplicationContext will be loaded from AppConfig and TestConfig
@ContextConfiguration(classes = {AppConfig.class, TestConfig.class}) (1)
class MyTest {
	// class body...
1 Specifying component classes.
@ExtendWith(SpringExtension::class)
@ContextConfiguration(classes = [AppConfig::class, TestConfig::class]) (1)
class MyTest {
	// class body...
Component Classes
The term “component class” can refer to any of the following:spring-doc.cn
  • A class annotated with @Configuration.spring-doc.cn
  • A component (that is, a class annotated with @Component, @Service, @Repository, or other stereotype annotations).spring-doc.cn
  • A JSR-330 compliant class that is annotated with jakarta.inject annotations.spring-doc.cn
  • Any class that contains @Bean-methods.spring-doc.cn
  • Any other class that is intended to be registered as a Spring component (i.e., a Spring bean in the ApplicationContext), potentially taking advantage of automatic autowiring of a single constructor without the use of Spring annotations.spring-doc.cn
See the javadoc of @Configuration and @Bean for further information regarding the configuration and semantics of component classes, paying special attention to the discussion of @Bean Lite Mode.spring-doc.cn
If you omit the classes attribute from the @ContextConfiguration annotation, the TestContext framework tries to detect the presence of default configuration classes. Specifically, AnnotationConfigContextLoader and AnnotationConfigWebContextLoader detect all static nested classes of the test class that meet the requirements for configuration class implementations, as specified in the @Configuration javadoc. Note that the name of the configuration class is arbitrary. In addition, a test class can contain more than one static nested configuration class if desired. In the following example, the OrderServiceTest class declares a static nested configuration class named Config that is automatically used to load the ApplicationContext for the test class:spring-doc.cn
@SpringJUnitConfig (1)
// ApplicationContext will be loaded from the static nested Config class
class OrderServiceTest {
	static class Config {
		// this bean will be injected into the OrderServiceTest class
		OrderService orderService() {
			OrderService orderService = new OrderServiceImpl();
			// set properties, etc.
			return orderService;
	@Autowired
	OrderService orderService;
	@Test
	void testOrderService() {
		// test the orderService
1 Loading configuration information from the nested Config class.
// ApplicationContext will be loaded from the nested Config class
	@Autowired
	lateinit var orderService: OrderService
	class Config {
		fun orderService(): OrderService {
			return OrderServiceImpl()
	@Test
	fun testOrderService() {
