Web
Router DSL
Spring Framework comes with a Kotlin router DSL available in 3 flavors:spring-doc.cn
These DSL let you write clean and idiomatic Kotlin code to build a RouterFunction instance as the following example shows:spring-doc.cn
class RouterRouterConfiguration {
	fun mainRouter(userHandler: UserHandler) = router {
		accept(TEXT_HTML).nest {
			GET("/") { ok().render("index") }
			GET("/sse") { ok().render("sse") }
			GET("/users", userHandler::findAllView)
		"/api".nest {
			accept(APPLICATION_JSON).nest {
				GET("/users", userHandler::findAll)
			accept(TEXT_EVENT_STREAM).nest {
				GET("/users", userHandler::stream)
		resources("/**", ClassPathResource("static/"))
This DSL is programmatic, meaning that it allows custom registration logic of beans through an if expression, a for loop, or any other Kotlin constructs. That can be useful when you need to register routes depending on dynamic data (for example, from a database).
See MiXiT project for a concrete example.spring-doc.cn
MockMvc DSL
A Kotlin DSL is provided via MockMvc Kotlin extensions in order to provide a more idiomatic Kotlin API and to allow better discoverability (no usage of static methods).spring-doc.cn
val mockMvc: MockMvc = ...
mockMvc.get("/person/{name}", "Lee") {
	secure = true
	accept = APPLICATION_JSON
	headers {
		contentLanguage = Locale.FRANCE
	principal = Principal { "foo" }
}.andExpect {
	status { isOk }
	content { contentType(APPLICATION_JSON) }
	jsonPath("$.name") { value("Lee") }
	content { json("""{"someBoolean": false}""", false) }
}.andDo {
	print()
Kotlin Script Templates
Spring Framework provides a ScriptTemplateView which supports JSR-223 to render templates by using script engines.spring-doc.cn
By leveraging scripting-jsr223 dependencies, it is possible to use such feature to render Kotlin-based templates with kotlinx.html DSL or Kotlin multiline interpolated String.spring-doc.cn
build.gradle.ktsspring-doc.cn
dependencies {
        runtime("org.jetbrains.kotlin:kotlin-scripting-jsr223:${kotlinVersion}")
Configuration is usually done with ScriptTemplateConfigurer and ScriptTemplateViewResolver beans.spring-doc.cn
KotlinScriptConfiguration.ktspring-doc.cn
class KotlinScriptConfiguration {
	fun kotlinScriptConfigurer() = ScriptTemplateConfigurer().apply {
		engineName = "kotlin"
		setScripts("scripts/render.kts")
		renderFunction = "render"
		isSharedEngine = false
    fun kotlinScriptViewResolver() = ScriptTemplateViewResolver().apply {
        setPrefix("templates/")
        setSuffix(".kts")
See the kotlin-script-templating example project for more details.spring-doc.cn
Kotlin multiplatform serialization
Kotlin multiplatform serialization is supported in Spring MVC, Spring WebFlux and Spring Messaging (RSocket). The builtin support currently targets CBOR, JSON, and ProtoBuf formats.spring-doc.cn
To enable it, follow those instructions to add the related dependency and plugin. With Spring MVC and WebFlux, both Kotlin serialization and Jackson will be configured by default if they are in the classpath since Kotlin serialization is designed to serialize only Kotlin classes annotated with @Serializable. With Spring Messaging (RSocket), make sure that neither Jackson, GSON or JSONB are in the classpath if you want automatic configuration, if Jackson is needed configure KotlinSerializationJsonMessageConverter manually.spring-doc.cn
