Exceptions
@Controller and @ControllerAdvice classes can have @ExceptionHandler methods to handle exceptions from controller methods, as the following example shows:spring-doc.cn
import java.io.IOException;
import org.springframework.http.ResponseEntity;
import org.springframework.stereotype.Controller;
import org.springframework.web.bind.annotation.ExceptionHandler;
@Controller
public class SimpleController {
	@ExceptionHandler(IOException.class)
	public ResponseEntity<String> handle() {
		return ResponseEntity.internalServerError().body("Could not read file storage");
@Controller
	@ExceptionHandler(IOException::class)
	fun handle() : ResponseEntity<String> {
Exception Mapping
The exception may match against a top-level exception being propagated (for example, a direct IOException being thrown) or against a nested cause within a wrapper exception (for example, an IOException wrapped inside an IllegalStateException). As of 5.3, this can match at arbitrary cause levels, whereas previously only an immediate cause was considered.spring-doc.cn
For matching exception types, preferably declare the target exception as a method argument, as the preceding example shows. When multiple exception methods match, a root exception match is generally preferred to a cause exception match. More specifically, the ExceptionDepthComparator is used to sort exceptions based on their depth from the thrown exception type.spring-doc.cn
Alternatively, the annotation declaration may narrow the exception types to match, as the following example shows:spring-doc.cn
@ExceptionHandler({FileSystemException.class, RemoteException.class})
public ResponseEntity<String> handleIoException(IOException ex) {
	return ResponseEntity.internalServerError().body(ex.getMessage());
@ExceptionHandler(FileSystemException::class, RemoteException::class)
fun handleIoException(ex: IOException): ResponseEntity<String> {
	return ResponseEntity.internalServerError().body(ex.message)
You can even use a list of specific exception types with a very generic argument signature, as the following example shows:spring-doc.cn
public ResponseEntity<String> handleExceptions(Exception ex) {
fun handleExceptions(ex: Exception): ResponseEntity<String> {
The distinction between root and cause exception matching can be surprising.spring-doc.cn
In the IOException variant shown earlier, the method is typically called with the actual FileSystemException or RemoteException instance as the argument, since both of them extend from IOException. However, if any such matching exception is propagated within a wrapper exception which is itself an IOException, the passed-in exception instance is that wrapper exception.spring-doc.cn
The behavior is even simpler in the handle(Exception) variant. This is always invoked with the wrapper exception in a wrapping scenario, with the actually matching exception to be found through ex.getCause() in that case. The passed-in exception is the actual FileSystemException or RemoteException instance only when these are thrown as top-level exceptions.spring-doc.cn
We generally recommend that you be as specific as possible in the argument signature, reducing the potential for mismatches between root and cause exception types. Consider breaking a multi-matching method into individual @ExceptionHandler methods, each matching a single specific exception type through its signature.spring-doc.cn
In a multi-@ControllerAdvice arrangement, we recommend declaring your primary root exception mappings on a @ControllerAdvice prioritized with a corresponding order. While a root exception match is preferred to a cause, this is defined among the methods of a given controller or @ControllerAdvice class. This means a cause match on a higher-priority @ControllerAdvice bean is preferred to any match (for example, root) on a lower-priority @ControllerAdvice bean.spring-doc.cn
Last but not least, an @ExceptionHandler method implementation can choose to back out of dealing with a given exception instance by rethrowing it in its original form. This is useful in scenarios where you are interested only in root-level matches or in matches within a specific context that cannot be statically determined. A rethrown exception is propagated through the remaining resolution chain, as though the given @ExceptionHandler method would not have matched in the first place.spring-doc.cn
Support for @ExceptionHandler methods in Spring MVC is built on the DispatcherServlet level, HandlerExceptionResolver mechanism.spring-doc.cn
Media Type Mapping
In addition to exception types, @ExceptionHandler methods can also declare producible media types. This allows to refine error responses depending on the media types requested by HTTP clients, typically in the "Accept" HTTP request header.spring-doc.cn
Applications can declare producible media types directly on annotations, for the same exception type:spring-doc.cn
@ExceptionHandler(produces = "application/json")
public ResponseEntity<ErrorMessage> handleJson(IllegalArgumentException exc) {
	return ResponseEntity.badRequest().body(new ErrorMessage(exc.getMessage(), 42));
@ExceptionHandler(produces = "text/html")
public String handle(IllegalArgumentException exc, Model model) {
	model.addAttribute("error", new ErrorMessage(exc.getMessage(), 42));
	return "errorView";
@ExceptionHandler(produces = ["application/json"])
fun handleJson(exc: IllegalArgumentException): ResponseEntity<ErrorMessage> {
	return ResponseEntity.badRequest().body(ErrorMessage(exc.message, 42))
@ExceptionHandler(produces = ["text/html"])
fun handle(exc: IllegalArgumentException, model: Model): String {
	model.addAttribute("error", ErrorMessage(exc.message, 42))
	return "errorView"
Here, methods handle the same exception type but will not be rejected as duplicates. Instead, API clients requesting "application/json" will receive a JSON error, and browsers will get an HTML error view. Each @ExceptionHandler annotation can declare several producible media types, the content negotiation during the error handling phase will decide which content type will be used.spring-doc.cn
Method Arguments
@ExceptionHandler methods support the following arguments:spring-doc.cn
Method argument Description
Exception typespring-doc.cn
For access to the raised exception.spring-doc.cn
HandlerMethodspring-doc.cn
For access to the controller method that raised the exception.spring-doc.cn
WebRequest, NativeWebRequestspring-doc.cn
Generic access to request parameters and request and session attributes without direct use of the Servlet API.spring-doc.cn
jakarta.servlet.ServletRequest, jakarta.servlet.ServletResponsespring-doc.cn
Choose any specific request or response type (for example, ServletRequest or HttpServletRequest or Spring’s MultipartRequest or MultipartHttpServletRequest).spring-doc.cn
jakarta.servlet.http.HttpSessionspring-doc.cn
Enforces the presence of a session. As a consequence, such an argument is never null.
Note that session access is not thread-safe. Consider setting the RequestMappingHandlerAdapter instance’s synchronizeOnSession flag to true if multiple requests are allowed to access a session concurrently.spring-doc.cn
java.security.Principalspring-doc.cn
Currently authenticated user — possibly a specific Principal implementation class if known.spring-doc.cn
HttpMethodspring-doc.cn
The HTTP method of the request.spring-doc.cn
java.util.Localespring-doc.cn
The current request locale, determined by the most specific LocaleResolver available — in effect, the configured LocaleResolver or LocaleContextResolver.spring-doc.cn
java.util.TimeZone, java.time.ZoneIdspring-doc.cn
The time zone associated with the current request, as determined by a LocaleContextResolver.spring-doc.cn
java.io.OutputStream, java.io.Writerspring-doc.cn
For access to the raw response body, as exposed by the Servlet API.spring-doc.cn
java.util.Map, org.springframework.ui.Model, org.springframework.ui.ModelMapspring-doc.cn
For access to the model for an error response. Always empty.spring-doc.cn
RedirectAttributesspring-doc.cn
Specify attributes to use in case of a redirect — (that is to be appended to the query string) and flash attributes to be stored temporarily until the request after the redirect. See Redirect Attributes and Flash Attributes.spring-doc.cn
@SessionAttributespring-doc.cn
For access to any session attribute, in contrast to model attributes stored in the session as a result of a class-level @SessionAttributes declaration. See @SessionAttribute for more details.spring-doc.cn
@RequestAttributespring-doc.cn
For access to request attributes. See @RequestAttribute for more details.spring-doc.cn
Return Values
@ExceptionHandler methods support the following return values:spring-doc.cn
Return value Description
@ResponseBodyspring-doc.cn
The return value is converted through HttpMessageConverter instances and written to the response. See @ResponseBody.spring-doc.cn
HttpEntity<B>, ResponseEntity<B>spring-doc.cn
The return value specifies that the full response (including the HTTP headers and the body) be converted through HttpMessageConverter instances and written to the response. See ResponseEntity.spring-doc.cn
ErrorResponsespring-doc.cn
To render an RFC 9457 error response with details in the body, see Error Responsesspring-doc.cn
ProblemDetailspring-doc.cn
Stringspring-doc.cn
A view name to be resolved with ViewResolver implementations and used together with the implicit model — determined through command objects and @ModelAttribute methods. The handler method can also programmatically enrich the model by declaring a Model argument (described earlier).spring-doc.cn
Viewspring-doc.cn
A View instance to use for rendering together with the implicit model — determined through command objects and @ModelAttribute methods. The handler method may also programmatically enrich the model by declaring a Model argument (descried earlier).spring-doc.cn
java.util.Map, org.springframework.ui.Modelspring-doc.cn
Attributes to be added to the implicit model with the view name implicitly determined through a RequestToViewNameTranslator.spring-doc.cn
@ModelAttributespring-doc.cn
An attribute to be added to the model with the view name implicitly determined through a RequestToViewNameTranslator.spring-doc.cn
Note that @ModelAttribute is optional. See “Any other return value” at the end of this table.spring-doc.cn
ModelAndView objectspring-doc.cn
The view and model attributes to use and, optionally, a response status.spring-doc.cn
voidspring-doc.cn
A method with a void return type (or null return value) is considered to have fully handled the response if it also has a ServletResponse an OutputStream argument, or a @ResponseStatus annotation. The same is also true if the controller has made a positive ETag or lastModified timestamp check (see Controllers for details).spring-doc.cn
If none of the above is true, a void return type can also indicate “no response body” for REST controllers or default view name selection for HTML controllers.spring-doc.cn
Any other return valuespring-doc.cn
If a return value is not matched to any of the above and is not a simple type (as determined by BeanUtils#isSimpleProperty), by default, it is treated as a model attribute to be added to the model. If it is a simple type, it remains unresolved.spring-doc.cn
