@SqlGroup
@SqlGroup is a container annotation that aggregates several @Sql annotations. You can use @SqlGroup natively to declare several nested @Sql annotations, or you can use it in conjunction with Java 8’s support for repeatable annotations, where @Sql can be declared several times on the same class or method, implicitly generating this container annotation. The following example shows how to declare an SQL group:spring-doc.cn
@Test
@SqlGroup({ (1)
	@Sql(scripts = "/test-schema.sql", config = @SqlConfig(commentPrefix = "`")),
	@Sql("/test-user-data.sql")
void userTest() {
	// run code that uses the test schema and test data
1 Declare a group of SQL scripts.
@Test
@SqlGroup( (1)
	Sql("/test-schema.sql", config = SqlConfig(commentPrefix = "`")),
	Sql("/test-user-data.sql"))
fun userTest() {
