@Sql
@Sql is used to annotate a test class or test method to configure SQL scripts to be run against a given database during integration tests. The following example shows how to use it:spring-doc.cn
@Test
@Sql({"/test-schema.sql", "/test-user-data.sql"}) (1)
void userTest() {
	// run code that relies on the test schema and test data
1 Run two scripts for this test.
@Test
@Sql("/test-schema.sql", "/test-user-data.sql") (1)
fun userTest() {
