Running Integration Tests
While you may start your Spring Boot application very easily from your test (or test suite) itself, it may be desirable to handle that in the build itself.
To make sure that the lifecycle of your Spring Boot application is properly managed around your integration tests, you can use the start
and stop
goals, as shown in the following example:
<build>
<plugins>
<plugin>
<executions>
<execution>
<id>pre-integration-test</id>
<goals>
<goal>start</goal>
</goals>
</execution>
<execution>
<id>post-integration-test</id>
<goals>
<goal>stop</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
Such setup can now use the failsafe-plugin to run your integration tests as you would expect.
The application is started in a separate process and JMX is used to communicate with the application.
By default, the plugin uses port 9001 .
If you need to configure the JMX port, see the dedicated example.
You could also configure a more advanced setup to skip the integration tests when a specific property has been set, see the dedicated example.
Using Failsafe Without Spring Boot’s Parent POM
Spring Boot’s Parent POM, spring-boot-starter-parent
, configures Failsafe’s <classesDirectory>
to be ${project.build.outputDirectory}
Without this configuration, which causes Failsafe to use the compiled classes rather than the repackaged jar, Failsafe cannot load your application’s classes.
If you are not using the parent POM, you should configure Failsafe in the same way, as shown in the following example:
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-failsafe-plugin</artifactId>
<configuration>
<classesDirectory>${project.build.outputDirectory}</classesDirectory>
</configuration>
</plugin>
spring-boot:start
org.springframework.boot:spring-boot-maven-plugin:3.4.5
Start a spring application. Contrary to the run
goal, this does not block and allows other goals to operate on the application. This goal is typically used in integration test scenario where the application is started before a test suite and stopped after.
Optional parameters
Name | Type | Default |
Parameter details
addResources
Add maven resources to the classpath directly, this allows live in-place editing of resources. Duplicate resources are removed from target/classes
to prevent them from appearing twice if ClassLoader.getResources()
is called. Please consider adding spring-boot-devtools
to your project instead as it provides this feature and many more.
Name |
Type |
Default value |
User property |
Since |
additionalClasspathElements
Additional classpath elements that should be added to the classpath. An element can be a directory with classes and resources or a jar file.
Name |
Type |
Default value |
User property |
Since |
agents
Path to agent jars.
Name |
Type |
Default value |
User property |
Since |
arguments
Arguments that should be passed to the application.
Name |
Type |
Default value |
User property |
Since |
classesDirectory
Directory containing the classes and resource files that should be used to run the application.
Name |
Type |
Default value |
User property |
Since |
commandlineArguments
Arguments from the command line that should be passed to the application. Use spaces to separate multiple arguments and make sure to wrap multiple values between quotes. When specified, takes precedence over #arguments
Name |
Type |
Default value |
User property |
Since |
environmentVariables
List of Environment variables that should be associated with the forked process used to run the application.
Name |
Type |
Default value |
User property |
Since |
excludeGroupIds
Comma separated list of groupId names to exclude (exact match).
Name |
Type |
Default value |
User property |
Since |
excludes
Collection of artifact definitions to exclude. The Exclude
element defines mandatory groupId
and artifactId
components and an optional classifier
component. When configured as a property, values should be comma-separated with colon-separated components: groupId:artifactId,groupId:artifactId:classifier
Name |
Type |
Default value |
User property |
Since |
includes
Collection of artifact definitions to include. The Include
and artifactId
Name |
Type |
Default value |
User property |
Since |
jmxName
The JMX name of the automatically deployed MBean managing the lifecycle of the spring application.
Name |
Type |
Default value |
User property |
Since |
jmxPort
The port to use to expose the platform MBeanServer.
Name |
Type |
Default value |
User property |
Since |
jvmArguments
JVM arguments that should be associated with the forked process used to run the application. On command line, make sure to wrap multiple values between quotes.
Name |
Type |
Default value |
User property |
Since |
mainClass
The name of the main class. If not specified the first compiled class found that contains a 'main' method will be used.
Name |
Type |
Default value |
User property |
Since |
maxAttempts
The maximum number of attempts to check if the spring application is ready. Combined with the "wait" argument, this gives a global timeout value (30 sec by default)
Name |
Type |
Default value |
User property |
Since |
noverify
Flag to say that the agent requires -noverify.
Name |
Type |
Default value |
User property |
Since |
profiles
The spring profiles to activate. Convenience shortcut of specifying the 'spring.profiles.active' argument. On command line use commas to separate multiple profiles.
Name |
Type |
Default value |
User property |
Since |
skip
Skip the execution.
Name |
Type |
Default value |
User property |
Since |
systemPropertyVariables
List of JVM system properties to pass to the process.
Name |
Type |
Default value |
User property |
Since |
useTestClasspath
Flag to include the test classpath when running.
Name |
Type |
Default value |
User property |
Since |
spring-boot:stop
Stop an application that has been started by the "start" goal. Typically invoked once a test suite has completed.
Optional parameters
Parameter details
jmxName
The JMX name of the automatically deployed MBean managing the lifecycle of the application.
Name |
Type |
Default value |
User property |
Since |
Examples
Random Port for Integration Tests
One nice feature of the Spring Boot test integration is that it can allocate a free port for the web application.
When the start
goal of the plugin is used, the Spring Boot application is started separately, making it difficult to pass the actual port to the integration test itself.
The example below showcases how you could achieve the same feature using the Build Helper Maven Plugin:
<build>
<plugins>
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>build-helper-maven-plugin</artifactId>
<executions>
<execution>
<id>reserve-tomcat-port</id>
<goals>
<goal>reserve-network-port</goal>
</goals>
<phase>process-resources</phase>
<configuration>
<portNames>
<portName>tomcat.http.port</portName>
</portNames>
</configuration>
</execution>
</executions>
</plugin>
<plugin>
<executions>
<execution>
<goals>
<goal>start</goal>
</goals>
<configuration>
<arguments>
<argument>--server.port=${tomcat.http.port}</argument>
</arguments>
</configuration>
</execution>
<execution>
<goals>
<goal>stop</goal>
</goals>
</execution>
</executions>
</plugin>
<plugin>
<configuration>
<systemPropertyVariables>
<test.server.port>${tomcat.http.port}</test.server.port>
</systemPropertyVariables>
</configuration>
</plugin>
</plugins>
</build>
You can now retrieve the test.server.port
system property in any of your integration test to create a proper URL
to the server.
Customize JMX Port
The jmxPort
property allows to customize the port the plugin uses to communicate with the Spring Boot application.
This example shows how you can customize the port in case 9001
is already used:
<build>
<plugins>
<plugin>
<configuration>
<jmxPort>9009</jmxPort>
</configuration>
<executions>
<execution>
<goals>
<goal>start</goal>
</goals>
</execution>
<execution>
<goals>
<goal>stop</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
If you need to configure the JMX port, make sure to do so in the global configuration as shown above so that it is shared by both goals. |
Skip Integration Tests
The skip
property allows to skip the execution of the Spring Boot maven plugin altogether.
This example shows how you can skip integration tests with a command-line property and still make sure that the repackage
goal runs:
<project>
<properties>
<skip.it>false</skip.it>
</properties>
<build>
<plugins>
<plugin>
<executions>
<execution>
<goals>
<goal>start</goal>
</goals>
<configuration>
<skip>${skip.it}</skip>
</configuration>
</execution>
<execution>
<goals>
<goal>stop</goal>
</goals>
<configuration>
</configuration>
</execution>
</executions>
</plugin>
<plugin>
<configuration>
</configuration>
</plugin>
</plugins>
</build>
</project>
By default, the integration tests will run but this setup allows you to easily disable them on the command-line as follows:
$ mvn verify -Dskip.it=true
