Externalized Configuration
Spring Boot lets you externalize your configuration so that you can work with the same application code in different environments. You can use a variety of external configuration sources including Java properties files, YAML files, environment variables, and command-line arguments.spring-doc.cn
Property values can be injected directly into your beans by using the @Value annotation, accessed through Spring’s Environment abstraction, or be bound to structured objects through @ConfigurationProperties.spring-doc.cn
Spring Boot uses a very particular PropertySource order that is designed to allow sensible overriding of values. Later property sources can override the values defined in earlier ones. Sources are considered in the following order:spring-doc.cn
  1. Default properties (specified by setting SpringApplication.setDefaultProperties(Map)).spring-doc.cn
  2. @PropertySource annotations on your @Configuration classes. Please note that such property sources are not added to the Environment until the application context is being refreshed. This is too late to configure certain properties such as logging.* and spring.main.* which are read before refresh begins.spring-doc.cn
  3. Config data (such as application.properties files).spring-doc.cn
  4. A RandomValuePropertySource that has properties only in random.*.spring-doc.cn
  5. OS environment variables.spring-doc.cn
  6. Java System properties (System.getProperties()).spring-doc.cn
  7. JNDI attributes from java:comp/env.spring-doc.cn
  8. ServletContext init parameters.spring-doc.cn
  9. ServletConfig init parameters.spring-doc.cn
  10. Properties from SPRING_APPLICATION_JSON (inline JSON embedded in an environment variable or system property).spring-doc.cn
  11. Command line arguments.spring-doc.cn
  12. properties attribute on your tests. Available on @SpringBootTest and the test annotations for testing a particular slice of your application.spring-doc.cn
  13. @DynamicPropertySource annotations in your tests.spring-doc.cn
  14. @TestPropertySource annotations on your tests.spring-doc.cn
  15. Devtools global settings properties in the $HOME/.config/spring-boot directory when devtools is active.spring-doc.cn
Config data files are considered in the following order:spring-doc.cn
  1. Application properties packaged inside your jar (application.properties and YAML variants).spring-doc.cn
  2. Profile-specific application properties packaged inside your jar (application-{profile}.properties and YAML variants).spring-doc.cn
  3. Application properties outside of your packaged jar (application.properties and YAML variants).spring-doc.cn
  4. Profile-specific application properties outside of your packaged jar (application-{profile}.properties and YAML variants).spring-doc.cn
It is recommended to stick with one format for your entire application. If you have configuration files with both .properties and YAML format in the same location, .properties takes precedence.
If you use environment variables rather than system properties, most operating systems disallow period-separated key names, but you can use underscores instead (for example, SPRING_CONFIG_NAME instead of spring.config.name). See Binding From Environment Variables for details.
If your application runs in a servlet container or application server, then JNDI properties (in java:comp/env) or servlet context initialization parameters can be used instead of, or as well as, environment variables or system properties.
To provide a concrete example, suppose you develop a @Component that uses a name property, as shown in the following example:spring-doc.cn
import org.springframework.beans.factory.annotation.Value;
@Component
public class MyBean {
	@Value("${name}")
	private String name;
@Component
class MyBean {
	@Value("\${name}")
	private val name: String? = null
On your application classpath (for example, inside your jar) you can have an application.properties file that provides a sensible default property value for name. When running in a new environment, an application.properties file can be provided outside of your jar that overrides the name. For one-off testing, you can launch with a specific command line switch (for example, java -jar app.jar --name="Spring").spring-doc.cn
The env and configprops endpoints can be useful in determining why a property has a particular value. You can use these two endpoints to diagnose unexpected property values. See the Production ready features section for details.
Accessing Command Line Properties
By default, SpringApplication converts any command line option arguments (that is, arguments starting with --, such as --server.port=9000) to a property and adds them to the Spring Environment. As mentioned previously, command line properties always take precedence over file-based property sources.spring-doc.cn
If you do not want command line properties to be added to the Environment, you can disable them by using SpringApplication.setAddCommandLineProperties(false).spring-doc.cn
JSON Application Properties
Environment variables and system properties often have restrictions that mean some property names cannot be used. To help with this, Spring Boot allows you to encode a block of properties into a single JSON structure.spring-doc.cn
When your application starts, any spring.application.json or SPRING_APPLICATION_JSON properties will be parsed and added to the Environment.spring-doc.cn
For example, the SPRING_APPLICATION_JSON property can be supplied on the command line in a UN*X shell as an environment variable:spring-doc.cn
$ SPRING_APPLICATION_JSON='{"my":{"name":"test"}}' java -jar myapp.jar
In the preceding example, you end up with my.name=test in the Spring Environment.spring-doc.cn
The same JSON can also be provided as a system property:spring-doc.cn
$ java -Dspring.application.json='{"my":{"name":"test"}}' -jar myapp.jar
Or you could supply the JSON by using a command line argument:spring-doc.cn
$ java -jar myapp.jar --spring.application.json='{"my":{"name":"test"}}'
If you are deploying to a classic Application Server, you could also use a JNDI variable named java:comp/env/spring.application.json.spring-doc.cn
Although null values from the JSON will be added to the resulting property source, the PropertySourcesPropertyResolver treats null properties as missing values. This means that the JSON cannot override properties from lower order property sources with a null value.
External Application Properties
Spring Boot will automatically find and load application.properties and application.yaml files from the following locations when your application starts:spring-doc.cn
  1. From the classpathspring-doc.cn
    1. The classpath rootspring-doc.cn
    2. The classpath /config packagespring-doc.cn
  2. From the current directoryspring-doc.cn
    1. The current directoryspring-doc.cn
    2. The config/ subdirectory in the current directoryspring-doc.cn
    3. Immediate child directories of the config/ subdirectoryspring-doc.cn
The list is ordered by precedence (with values from lower items overriding earlier ones). Documents from the loaded files are added as PropertySource instances to the Spring Environment.spring-doc.cn
If you do not like application as the configuration file name, you can switch to another file name by specifying a spring.config.name environment property. For example, to look for myproject.properties and myproject.yaml files you can run your application as follows:spring-doc.cn
$ java -jar myproject.jar --spring.config.name=myproject
You can also refer to an explicit location by using the spring.config.location environment property. This property accepts a comma-separated list of one or more locations to check.spring-doc.cn
The following example shows how to specify two distinct files:spring-doc.cn
$ java -jar myproject.jar --spring.config.location=\
	optional:classpath:/default.properties,\
	optional:classpath:/override.properties
Use the prefix optional: if the locations are optional and you do not mind if they do not exist.
spring.config.name, spring.config.location, and spring.config.additional-location are used very early to determine which files have to be loaded. They must be defined as an environment property (typically an OS environment variable, a system property, or a command-line argument).
If spring.config.location contains directories (as opposed to files), they should end in /. At runtime they will be appended with the names generated from spring.config.name before being loaded. Files specified in spring.config.location are imported directly.spring-doc.cn
Both directory and file location values are also expanded to check for profile-specific files. For example, if you have a spring.config.location of classpath:myconfig.properties, you will also find appropriate classpath:myconfig-<profile>.properties files are loaded.
In most situations, each spring.config.location item you add will reference a single file or directory. Locations are processed in the order that they are defined and later ones can override the values of earlier ones.spring-doc.cn
If you have a complex location setup, and you use profile-specific configuration files, you may need to provide further hints so that Spring Boot knows how they should be grouped. A location group is a collection of locations that are all considered at the same level. For example, you might want to group all classpath locations, then all external locations. Items within a location group should be separated with ;. See the example in the Profile Specific Files section for more details.spring-doc.cn
Locations configured by using spring.config.location replace the default locations. For example, if spring.config.location is configured with the value optional:classpath:/custom-config/,optional:file:./custom-config/, the complete set of locations considered is:spring-doc.cn
  1. optional:classpath:custom-config/spring-doc.cn
  2. optional:file:./custom-config/spring-doc.cn
If you prefer to add additional locations, rather than replacing them, you can use spring.config.additional-location. Properties loaded from additional locations can override those in the default locations. For example, if spring.config.additional-location is configured with the value optional:classpath:/custom-config/,optional:file:./custom-config/, the complete set of locations considered is:spring-doc.cn
  1. optional:classpath:/;optional:classpath:/config/spring-doc.cn
  2. optional:file:./;optional:file:./config/;optional:file:./config/*/spring-doc.cn
  3. optional:classpath:custom-config/spring-doc.cn
  4. optional:file:./custom-config/spring-doc.cn
This search ordering lets you specify default values in one configuration file and then selectively override those values in another. You can provide default values for your application in application.properties (or whatever other basename you choose with spring.config.name) in one of the default locations. These default values can then be overridden at runtime with a different file located in one of the custom locations.spring-doc.cn
Optional Locations
By default, when a specified config data location does not exist, Spring Boot will throw a ConfigDataLocationNotFoundException and your application will not start.spring-doc.cn
If you want to specify a location, but you do not mind if it does not always exist, you can use the optional: prefix. You can use this prefix with the spring.config.location and spring.config.additional-location properties, as well as with spring.config.import declarations.spring-doc.cn
For example, a spring.config.import value of optional:file:./myconfig.properties allows your application to start, even if the myconfig.properties file is missing.spring-doc.cn
If you want to ignore all ConfigDataLocationNotFoundException errors and always continue to start your application, you can use the spring.config.on-not-found property. Set the value to ignore using SpringApplication.setDefaultProperties(…​) or with a system/environment variable.spring-doc.cn
Wildcard Locations
If a config file location includes the * character for the last path segment, it is considered a wildcard location. Wildcards are expanded when the config is loaded so that immediate subdirectories are also checked. Wildcard locations are particularly useful in an environment such as Kubernetes when there are multiple sources of config properties.spring-doc.cn
For example, if you have some Redis configuration and some MySQL configuration, you might want to keep those two pieces of configuration separate, while requiring that both those are present in an application.properties file. This might result in two separate application.properties files mounted at different locations such as /config/redis/application.properties and /config/mysql/application.properties. In such a case, having a wildcard location of config/*/, will result in both files being processed.spring-doc.cn
By default, Spring Boot includes config/*/ in the default search locations. It means that all subdirectories of the /config directory outside of your jar will be searched.spring-doc.cn
You can use wildcard locations yourself with the spring.config.location and spring.config.additional-location properties.spring-doc.cn
A wildcard location must contain only one * and end with */ for search locations that are directories or */<filename> for search locations that are files. Locations with wildcards are sorted alphabetically based on the absolute path of the file names.
Wildcard locations only work with external directories. You cannot use a wildcard in a classpath: location.
As well as application property files, Spring Boot will also attempt to load profile-specific files using the naming convention application-{profile}. For example, if your application activates a profile named prod and uses YAML files, then both application.yaml and application-prod.yaml will be considered.spring-doc.cn
Profile-specific properties are loaded from the same locations as standard application.properties, with profile-specific files always overriding the non-specific ones. If several profiles are specified, a last-wins strategy applies. For example, if profiles prod,live are specified by the spring.profiles.active property, values in application-prod.properties can be overridden by those in application-live.properties.spring-doc.cn
The last-wins strategy applies at the location group level. A spring.config.location of classpath:/cfg/,classpath:/ext/ will not have the same override rules as classpath:/cfg/;classpath:/ext/.spring-doc.cn
For example, continuing our prod,live example above, we might have the following files:spring-doc.cn
/cfg
/ext
When we have a spring.config.location of classpath:/cfg/,classpath:/ext/ we process all /cfg files before all /ext files:spring-doc.cn
  1. /cfg/application-live.propertiesspring-doc.cn
  2. /ext/application-prod.propertiesspring-doc.cn
  3. /ext/application-live.propertiesspring-doc.cn
When we have classpath:/cfg/;classpath:/ext/ instead (with a ; delimiter) we process /cfg and /ext at the same level:spring-doc.cn
  1. /ext/application-prod.propertiesspring-doc.cn
  2. /cfg/application-live.propertiesspring-doc.cn
The Environment has a set of default profiles (by default, [default]) that are used if no active profiles are set. In other words, if no profiles are explicitly activated, then properties from application-default are considered.spring-doc.cn
Properties files are only ever loaded once. If you have already directly imported a profile specific property files then it will not be imported a second time.
Importing Additional Data
Application properties may import further config data from other locations using the spring.config.import property. Imports are processed as they are discovered, and are treated as additional documents inserted immediately below the one that declares the import.spring-doc.cn
For example, you might have the following in your classpath application.properties file:spring-doc.cn
spring.application.name=myapp
spring.config.import=optional:file:./dev.properties
spring:
  application:
  config:
    import: "optional:file:./dev.properties"
This will trigger the import of a dev.properties file in current directory (if such a file exists). Values from the imported dev.properties will take precedence over the file that triggered the import. In the above example, the dev.properties could redefine spring.application.name to a different value.spring-doc.cn
An import will only be imported once no matter how many times it is declared. The order an import is defined inside a single document within the properties/yaml file does not matter. For instance, the two examples below produce the same result:spring-doc.cn
spring.config.import=my.properties
my.property=value
spring:
  config:
    import: "my.properties"
my:
  property: "value"
my.property=value
my:
  property: "value"
spring:
  config:
In both of the above examples, the values from the my.properties file will take precedence over the file that triggered its import.spring-doc.cn
Several locations can be specified under a single spring.config.import key. Locations will be processed in the order that they are defined, with later imports taking precedence.spring-doc.cn
When appropriate, Profile-specific variants are also considered for import. The example above would import both my.properties as well as any my-<profile>.properties variants.
Spring Boot includes pluggable API that allows various different location addresses to be supported. By default you can import Java Properties, YAML and configuration trees.spring-doc.cn
Third-party jars can offer support for additional technologies (there is no requirement for files to be local). For example, you can imagine config data being from external stores such as Consul, Apache ZooKeeper or Netflix Archaius.spring-doc.cn
If you want to support your own locations, see the ConfigDataLocationResolver and ConfigDataLoader classes in the org.springframework.boot.context.config package.spring-doc.cn
Importing Extensionless Files
Some cloud platforms cannot add a file extension to volume mounted files. To import these extensionless files, you need to give Spring Boot a hint so that it knows how to load them. You can do this by putting an extension hint in square brackets.spring-doc.cn
For example, suppose you have a /etc/config/myconfig file that you wish to import as yaml. You can import it from your application.properties using the following:spring-doc.cn
spring.config.import=file:/etc/config/myconfig[.yaml]
spring:
  config:
    import: "file:/etc/config/myconfig[.yaml]"
Using Configuration Trees
When running applications on a cloud platform (such as Kubernetes) you often need to read config values that the platform supplies. It is not uncommon to use environment variables for such purposes, but this can have drawbacks, especially if the value is supposed to be kept secret.spring-doc.cn
As an alternative to environment variables, many cloud platforms now allow you to map configuration into mounted data volumes. For example, Kubernetes can volume mount both ConfigMaps and Secrets.spring-doc.cn
There are two common volume mount patterns that can be used:spring-doc.cn
  1. A single file contains a complete set of properties (usually written as YAML).spring-doc.cn
  2. Multiple files are written to a directory tree, with the filename becoming the ‘key’ and the contents becoming the ‘value’.spring-doc.cn
For the first case, you can import the YAML or Properties file directly using spring.config.import as described above. For the second case, you need to use the configtree: prefix so that Spring Boot knows it needs to expose all the files as properties.spring-doc.cn
As an example, let’s imagine that Kubernetes has mounted the following volume:spring-doc.cn
etc/
  config/
    myapp/
      username
      password
The contents of the username file would be a config value, and the contents of password would be a secret.spring-doc.cn
To import these properties, you can add the following to your application.properties or application.yaml file:spring-doc.cn
spring.config.import=optional:configtree:/etc/config/
spring:
  config:
    import: "optional:configtree:/etc/config/"
You can then access or inject myapp.username and myapp.password properties from the Environment in the usual way.spring-doc.cn
The names of the folders and files under the config tree form the property name. In the above example, to access the properties as username and password, you can set spring.config.import to optional:configtree:/etc/config/myapp.
Filenames with dot notation are also correctly mapped. For example, in the above example, a file named myapp.username in /etc/config would result in a myapp.username property in the Environment.
Configuration tree values can be bound to both string String and byte[] types depending on the contents expected.
If you have multiple config trees to import from the same parent folder you can use a wildcard shortcut. Any configtree: location that ends with /*/ will import all immediate children as config trees. As with a non-wildcard import, the names of the folders and files under each config tree form the property name.spring-doc.cn
For example, given the following volume:spring-doc.cn
etc/
  config/
    dbconfig/
      db/
        username
        password
    mqconfig/
      mq/
        username
        password
You can use configtree:/etc/config/*/ as the import location:spring-doc.cn
spring.config.import=optional:configtree:/etc/config/*/
spring:
  config:
    import: "optional:configtree:/etc/config/*/"
This will add db.username, db.password, mq.username and mq.password properties.spring-doc.cn
Directories loaded using a wildcard are sorted alphabetically. If you need a different order, then you should list each location as a separate import
Configuration trees can also be used for Docker secrets. When a Docker swarm service is granted access to a secret, the secret gets mounted into the container. For example, if a secret named db.password is mounted at location /run/secrets/, you can make db.password available to the Spring environment using the following:spring-doc.cn
spring.config.import=optional:configtree:/run/secrets/
spring:
  config:
    import: "optional:configtree:/run/secrets/"
Property Placeholders
The values in application.properties and application.yaml are filtered through the existing Environment when they are used, so you can refer back to previously defined values (for example, from System properties or environment variables). The standard ${name} property-placeholder syntax can be used anywhere within a value. Property placeholders can also specify a default value using a : to separate the default value from the property name, for example ${name:default}.spring-doc.cn
The use of placeholders with and without defaults is shown in the following example:spring-doc.cn
app.name=MyApp
app.description=${app.name} is a Spring Boot application written by ${username:Unknown}
app:
  description: "${app.name} is a Spring Boot application written by ${username:Unknown}"
Assuming that the username property has not been set elsewhere, app.description will have the value MyApp is a Spring Boot application written by Unknown.spring-doc.cn
You should always refer to property names in the placeholder using their canonical form (kebab-case using only lowercase letters). This will allow Spring Boot to use the same logic as it does when relaxed binding @ConfigurationProperties.spring-doc.cn
For example, ${demo.item-price} will pick up demo.item-price and demo.itemPrice forms from the application.properties file, as well as DEMO_ITEMPRICE from the system environment. If you used ${demo.itemPrice} instead, demo.item-price and DEMO_ITEMPRICE would not be considered.spring-doc.cn
You can also use this technique to create “short” variants of existing Spring Boot properties. See the Use ‘Short’ Command Line Arguments section in “How-to Guides” for details.
Working With Multi-Document Files
Spring Boot allows you to split a single physical file into multiple logical documents which are each added independently. Documents are processed in order, from top to bottom. Later documents can override the properties defined in earlier ones.spring-doc.cn
For application.yaml files, the standard YAML multi-document syntax is used. Three consecutive hyphens represent the end of one document, and the start of the next.spring-doc.cn
For example, the following file has two logical documents:spring-doc.cn
spring:
  application:
spring:
  application:
  config:
    activate:
      on-cloud-platform: "kubernetes"
For application.properties files a special #--- or !--- comment is used to mark the document splits:spring-doc.cn
spring.application.name=MyApp
spring.application.name=MyCloudApp
spring.config.activate.on-cloud-platform=kubernetes
Property file separators must not have any leading whitespace and must have exactly three hyphen characters. The lines immediately before and after the separator must not be same comment prefix.
Multi-document property files are often used in conjunction with activation properties such as spring.config.activate.on-profile. See the next section for details.
Multi-document property files cannot be loaded by using the @PropertySource or @TestPropertySource annotations.
Activation Properties
It is sometimes useful to only activate a given set of properties when certain conditions are met. For example, you might have properties that are only relevant when a specific profile is active.spring-doc.cn
You can conditionally activate a properties document using spring.config.activate.*.spring-doc.cn
The following activation properties are available:spring-doc.cn
Table 1. activation properties
Property Note
on-profilespring-doc.cn
A profile expression that must match for the document to be active, or a list of profile expressions of which at least one must match for the document to be active.spring-doc.cn
on-cloud-platformspring-doc.cn
The CloudPlatform that must be detected for the document to be active.spring-doc.cn
For example, the following specifies that the second document is only active when running on Kubernetes, and only when either the “prod” or “staging” profiles are active:spring-doc.cn
myprop=always-set
spring.config.activate.on-profile=prod | staging
myotherprop=sometimes-set
myprop:
  "always-set"
spring:
  config:
    activate:
      on-profile: "prod | staging"
myotherprop: "sometimes-set"
Encrypting Properties
Spring Boot does not provide any built-in support for encrypting property values, however, it does provide the hook points necessary to modify values contained in the Spring Environment. The EnvironmentPostProcessor interface allows you to manipulate the Environment before the application starts. See Customize the Environment or ApplicationContext Before It Starts for details.spring-doc.cn
If you need a secure way to store credentials and passwords, the Spring Cloud Vault project provides support for storing externalized configuration in HashiCorp Vault.spring-doc.cn
Working With YAML
YAML is a superset of JSON and, as such, is a convenient format for specifying hierarchical configuration data. The SpringApplication class automatically supports YAML as an alternative to properties whenever you have the SnakeYAML library on your classpath.spring-doc.cn
If you use starters, SnakeYAML is automatically provided by spring-boot-starter.
Mapping YAML to Properties
YAML documents need to be converted from their hierarchical format to a flat structure that can be used with the Spring Environment. For example, consider the following YAML document:spring-doc.cn
environments:
  dev:
    url: "https://dev.example.com"
  prod:
    url: "https://another.example.com"
    name: "My Cool App"
In order to access these properties from the Environment, they would be flattened as follows:spring-doc.cn
environments.dev.url=https://dev.example.com
environments.dev.name=Developer Setup
environments.prod.url=https://another.example.com
environments.prod.name=My Cool App
Likewise, YAML lists also need to be flattened. They are represented as property keys with [index] dereferencers. For example, consider the following YAML:spring-doc.cn
 my:
  servers:
  - "dev.example.com"
  - "another.example.com"
The preceding example would be transformed into these properties:spring-doc.cn
my.servers[0]=dev.example.com
my.servers[1]=another.example.com
Properties that use the [index] notation can be bound to Java List or Set objects using Spring Boot’s Binder class. For more details see the Type-safe Configuration Properties section below.
YAML files cannot be loaded by using the @PropertySource or @TestPropertySource annotations. So, in the case that you need to load values that way, you need to use a properties file.
Directly Loading YAML
Spring Framework provides two convenient classes that can be used to load YAML documents. The YamlPropertiesFactoryBean loads YAML as Properties and the YamlMapFactoryBean loads YAML as a Map.spring-doc.cn
You can also use the YamlPropertySourceLoader class if you want to load YAML as a Spring PropertySource.spring-doc.cn
Configuring Random Values
The RandomValuePropertySource is useful for injecting random values (for example, into secrets or test cases). It can produce integers, longs, uuids, or strings, as shown in the following example:spring-doc.cn
my.secret=${random.value}
my.number=${random.int}
my.bignumber=${random.long}
my.uuid=${random.uuid}
my.number-less-than-ten=${random.int(10)}
my.number-in-range=${random.int[1024,65536]}
my:
  secret: "${random.value}"
  number: "${random.int}"
  bignumber: "${random.long}"
  uuid: "${random.uuid}"
  number-less-than-ten: "${random.int(10)}"
  number-in-range: "${random.int[1024,65536]}"
The random.int* syntax is OPEN value (,max) CLOSE where the OPEN,CLOSE are any character and value,max are integers. If max is provided, then value is the minimum value and max is the maximum value (exclusive).spring-doc.cn
Configuring System Environment Properties
Spring Boot supports setting a prefix for environment properties. This is useful if the system environment is shared by multiple Spring Boot applications with different configuration requirements. The prefix for system environment properties can be set directly on SpringApplication.spring-doc.cn
For example, if you set the prefix to input, a property such as remote.timeout will also be resolved as input.remote.timeout in the system environment.spring-doc.cn
Using the @Value("${property}") annotation to inject configuration properties can sometimes be cumbersome, especially if you are working with multiple properties or your data is hierarchical in nature. Spring Boot provides an alternative method of working with properties that lets strongly typed beans govern and validate the configuration of your application.spring-doc.cn
See also the differences between @Value and type-safe configuration properties.
JavaBean Properties Binding
It is possible to bind a bean declaring standard JavaBean properties as shown in the following example:spring-doc.cn
import java.net.InetAddress;
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
import org.springframework.boot.context.properties.ConfigurationProperties;
@ConfigurationProperties("my.service")
public class MyProperties {
	private boolean enabled;
	private InetAddress remoteAddress;
	private final Security security = new Security();
	// getters / setters...
	public boolean isEnabled() {
		return this.enabled;
	public void setEnabled(boolean enabled) {
		this.enabled = enabled;
	public InetAddress getRemoteAddress() {
		return this.remoteAddress;
	public void setRemoteAddress(InetAddress remoteAddress) {
		this.remoteAddress = remoteAddress;
	public Security getSecurity() {
		return this.security;
	public static class Security {
		private String username;
		private String password;
		private List<String> roles = new ArrayList<>(Collections.singleton("USER"));
		public String getUsername() {
			return this.username;
		public void setUsername(String username) {
			this.username = username;
		public String getPassword() {
			return this.password;
		public void setPassword(String password) {
			this.password = password;
		public List<String> getRoles() {
			return this.roles;
		public void setRoles(List<String> roles) {
			this.roles = roles;
	var isEnabled = false
	var remoteAddress: InetAddress? = null
	val security = Security()
	class Security {
		var username: String? = null
		var password: String? = null
		var roles: List<String> = ArrayList(setOf("USER"))
The preceding POJO defines the following properties:spring-doc.cn
  • my.service.enabled, with a value of false by default.spring-doc.cn
  • my.service.remote-address, with a type that can be coerced from String.spring-doc.cn
  • my.service.security.username, with a nested "security" object whose name is determined by the name of the property. In particular, the type is not used at all there and could have been SecurityProperties.spring-doc.cn
  • my.service.security.password.spring-doc.cn
  • my.service.security.roles, with a collection of String that defaults to USER.spring-doc.cn
To use a reserved keyword in the name of a property, such as my.service.import, use the @Name annotation on the property’s field.
The properties that map to @ConfigurationProperties classes available in Spring Boot, which are configured through properties files, YAML files, environment variables, and other mechanisms, are public API but the accessors (getters/setters) of the class itself are not meant to be used directly.
Such arrangement relies on a default empty constructor and getters and setters are usually mandatory, since binding is through standard Java Beans property descriptors, just like in Spring MVC. A setter may be omitted in the following cases:spring-doc.cn
  • Maps, as long as they are initialized, need a getter but not necessarily a setter, since they can be mutated by the binder.spring-doc.cn
  • Collections and arrays can be accessed either through an index (typically with YAML) or by using a single comma-separated value (properties). In the latter case, a setter is mandatory. We recommend to always add a setter for such types. If you initialize a collection, make sure it is not immutable (as in the preceding example).spring-doc.cn
  • If nested POJO properties are initialized (like the Security field in the preceding example), a setter is not required. If you want the binder to create the instance on the fly by using its default constructor, you need a setter.spring-doc.cn
Some people use Project Lombok to add getters and setters automatically. Make sure that Lombok does not generate any particular constructor for such a type, as it is used automatically by the container to instantiate the object.spring-doc.cn
Finally, only standard Java Bean properties are considered and binding on static properties is not supported.spring-doc.cn
Constructor Binding
The example in the previous section can be rewritten in an immutable fashion as shown in the following example:spring-doc.cn
import org.springframework.boot.context.properties.bind.DefaultValue;
	// fields...
	private final boolean enabled;
	private final InetAddress remoteAddress;
	private final Security security;
	public MyProperties(boolean enabled, InetAddress remoteAddress, Security security) {
		this.security = security;
	// getters...
		// fields...
		private final String username;
		private final String password;
		private final List<String> roles;
		public Security(String username, String password, @DefaultValue("USER") List<String> roles) {
			this.roles = roles;
		// getters...
			return this.roles;
class MyProperties(val enabled: Boolean, val remoteAddress: InetAddress,
		val security: Security) {
	class Security(val username: String, val password: String,
			@param:DefaultValue("USER") val roles: List<String>)
In this setup, the presence of a single parameterized constructor implies that constructor binding should be used. This means that the binder will find a constructor with the parameters that you wish to have bound. If your class has multiple constructors, the @ConstructorBinding annotation can be used to specify which constructor to use for constructor binding. To opt out of constructor binding for a class with a single parameterized constructor, the constructor must be annotated with @Autowired or made private. Constructor binding can be used with records. Unless your record has multiple constructors, there is no need to use @ConstructorBinding.spring-doc.cn
Nested members of a constructor bound class (such as Security in the example above) will also be bound through their constructor.spring-doc.cn
Default values can be specified using @DefaultValue on constructor parameters and record components. The conversion service will be applied to coerce the annotation’s String value to the target type of a missing property.spring-doc.cn
Referring to the previous example, if no properties are bound to Security, the MyProperties instance will contain a null value for security. To make it contain a non-null instance of Security even when no properties are bound to it (when using Kotlin, this will require the username and password parameters of Security to be declared as nullable as they do not have default values), use an empty @DefaultValue annotation:spring-doc.cn
	public MyProperties(boolean enabled, InetAddress remoteAddress, @DefaultValue Security security) {
		@DefaultValue val security: Security) {
	class Security(val username: String?, val password: String?,
To use constructor binding the class must be enabled using @EnableConfigurationProperties or configuration property scanning. You cannot use constructor binding with beans that are created by the regular Spring mechanisms (for example @Component beans, beans created by using @Bean methods or beans loaded by using @Import)
To use constructor binding the class must be compiled with -parameters. This will happen automatically if you use Spring Boot’s Gradle plugin or if you use Maven and spring-boot-starter-parent.
The use of Optional with @ConfigurationProperties is not recommended as it is primarily intended for use as a return type. As such, it is not well-suited to configuration property injection. For consistency with properties of other types, if you do declare an Optional property and it has no value, null rather than an empty Optional will be bound.
To use a reserved keyword in the name of a property, such as my.service.import, use the @Name annotation on the constructor parameter.
Enabling @ConfigurationProperties-annotated Types
Spring Boot provides infrastructure to bind @ConfigurationProperties types and register them as beans. You can either enable configuration properties on a class-by-class basis or enable configuration property scanning that works in a similar manner to component scanning.spring-doc.cn
Sometimes, classes annotated with @ConfigurationProperties might not be suitable for scanning, for example, if you’re developing your own auto-configuration or you want to enable them conditionally. In these cases, specify the list of types to process using the @EnableConfigurationProperties annotation. This can be done on any @Configuration class, as shown in the following example:spring-doc.cn
import org.springframework.boot.context.properties.EnableConfigurationProperties;
@EnableConfigurationProperties(SomeProperties.class)
public class MyConfiguration {
@EnableConfigurationProperties(SomeProperties::class)
@ConfigurationProperties("some.properties")
public class SomeProperties {
To use configuration property scanning, add the @ConfigurationPropertiesScan annotation to your application. Typically, it is added to the main application class that is annotated with @SpringBootApplication but it can be added to any @Configuration class. By default, scanning will occur from the package of the class that declares the annotation. If you want to define specific packages to scan, you can do so as shown in the following example:spring-doc.cn
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.boot.context.properties.ConfigurationPropertiesScan;
@ConfigurationPropertiesScan({ "com.example.app", "com.example.another" })
public class MyApplication {
@ConfigurationPropertiesScan("com.example.app", "com.example.another")
class MyApplication
When the @ConfigurationProperties bean is registered using configuration property scanning or through @EnableConfigurationProperties, the bean has a conventional name: <prefix>-<fqn>, where <prefix> is the environment key prefix specified in the @ConfigurationProperties annotation and <fqn> is the fully qualified name of the bean. If the annotation does not provide any prefix, only the fully qualified name of the bean is used.spring-doc.cn
Assuming that it is in the com.example.app package, the bean name of the SomeProperties example above is some.properties-com.example.app.SomeProperties.spring-doc.cn
We recommend that @ConfigurationProperties only deal with the environment and, in particular, does not inject other beans from the context. For corner cases, setter injection can be used or any of the *Aware interfaces provided by the framework (such as EnvironmentAware if you need access to the Environment). If you still want to inject other beans using the constructor, the configuration properties bean must be annotated with @Component and use JavaBean-based property binding.spring-doc.cn
Using @ConfigurationProperties-annotated Types
This style of configuration works particularly well with the SpringApplication external YAML configuration, as shown in the following example:spring-doc.cn
my:
  service:
    remote-address: 192.168.1.1
    security:
      username: "admin"
      roles:
      - "USER"
      - "ADMIN"
To work with @ConfigurationProperties beans, you can inject them in the same way as any other bean, as shown in the following example:spring-doc.cn
import org.springframework.stereotype.Service;
@Service
public class MyService {
	private final MyProperties properties;
	public MyService(MyProperties properties) {
		this.properties = properties;
	public void openConnection() {
		Server server = new Server(this.properties.getRemoteAddress());
		server.start();
@Service
class MyService(val properties: MyProperties) {
	fun openConnection() {
		val server = Server(properties.remoteAddress)
		server.start()
Using @ConfigurationProperties also lets you generate metadata files that can be used by IDEs to offer auto-completion for your own keys. See the appendix for details.
Third-party Configuration
As well as using @ConfigurationProperties to annotate a class, you can also use it on public @Bean methods. Doing so can be particularly useful when you want to bind properties to third-party components that are outside of your control.spring-doc.cn
To configure a bean from the Environment properties, add @ConfigurationProperties to its bean registration, as shown in the following example:spring-doc.cn
public class ThirdPartyConfiguration {
	@ConfigurationProperties(prefix = "another")
	public AnotherComponent anotherComponent() {
		return new AnotherComponent();
	fun anotherComponent(): AnotherComponent = AnotherComponent()
Any JavaBean property defined with the another prefix is mapped onto that AnotherComponent bean in manner similar to the preceding SomeProperties example.spring-doc.cn
Relaxed Binding
Spring Boot uses some relaxed rules for binding Environment properties to @ConfigurationProperties beans, so there does not need to be an exact match between the Environment property name and the bean property name. Common examples where this is useful include dash-separated environment properties (for example, context-path binds to contextPath), and capitalized environment properties (for example, PORT binds to port).spring-doc.cn
As an example, consider the following @ConfigurationProperties class:spring-doc.cn
@ConfigurationProperties(prefix = "my.main-project.person")
public class MyPersonProperties {
	private String firstName;
	public String getFirstName() {
		return this.firstName;
	public void setFirstName(String firstName) {
		this.firstName = firstName;
	var firstName: String? = null
With the preceding code, the following properties names can all be used:spring-doc.cn
Table 2. relaxed binding
Property Note
my.main-project.person.first-namespring-doc.cn
Kebab case, which is recommended for use in .properties and YAML files.spring-doc.cn
my.main-project.person.firstNamespring-doc.cn
Standard camel case syntax.spring-doc.cn
my.main-project.person.first_namespring-doc.cn
Underscore notation, which is an alternative format for use in .properties and YAML files.spring-doc.cn
MY_MAINPROJECT_PERSON_FIRSTNAMEspring-doc.cn
Upper case format, which is recommended when using system environment variables.spring-doc.cn
The prefix value for the annotation must be in kebab case (lowercase and separated by -, such as my.main-project.person).
Table 3. relaxed binding rules per property source
Property Source Simple List
Properties Filesspring-doc.cn
Camel case, kebab case, or underscore notationspring-doc.cn
Standard list syntax using [ ] or comma-separated valuesspring-doc.cn
YAML Filesspring-doc.cn
Standard YAML list syntax or comma-separated valuesspring-doc.cn
Environment Variablesspring-doc.cn
Upper case format with underscore as the delimiter (see Binding From Environment Variables).spring-doc.cn
Numeric values surrounded by underscores (see Binding From Environment Variables)spring-doc.cn
System propertiesspring-doc.cn
We recommend that, when possible, properties are stored in lower-case kebab format, such as my.person.first-name=Rod.
Binding Maps
When binding to Map properties you may need to use a special bracket notation so that the original key value is preserved. If the key is not surrounded by [], any characters that are not alpha-numeric, - or . are removed.spring-doc.cn
For example, consider binding the following properties to a Map<String,String>:spring-doc.cn
my.map[/key1]=value1
my.map[/key2]=value2
my.map./key3=value3
my:
  map:
    "[/key1]": "value1"
    "[/key2]": "value2"
    "/key3": "value3"
For YAML files, the brackets need to be surrounded by quotes for the keys to be parsed properly.
The properties above will bind to a Map with /key1, /key2 and key3 as the keys in the map. The slash has been removed from key3 because it was not surrounded by square brackets.spring-doc.cn
When binding to scalar values, keys with . in them do not need to be surrounded by []. Scalar values include enums and all types in the java.lang package except for Object. Binding a.b=c to Map<String, String> will preserve the . in the key and return a Map with the entry {"a.b"="c"}. For any other types you need to use the bracket notation if your key contains a .. For example, binding a.b=c to Map<String, Object> will return a Map with the entry {"a"={"b"="c"}} whereas [a.b]=c will return a Map with the entry {"a.b"="c"}.spring-doc.cn
Most operating systems impose strict rules around the names that can be used for environment variables. For example, Linux shell variables can contain only letters (a to z or A to Z), numbers (0 to 9) or the underscore character (_). By convention, Unix shell variables will also have their names in UPPERCASE.spring-doc.cn
Spring Boot’s relaxed binding rules are, as much as possible, designed to be compatible with these naming restrictions.spring-doc.cn
To convert a property name in the canonical-form to an environment variable name you can follow these rules:spring-doc.cn
For example, the configuration property spring.main.log-startup-info would be an environment variable named SPRING_MAIN_LOGSTARTUPINFO.spring-doc.cn
Environment variables can also be used when binding to object lists. To bind to a List, the element number should be surrounded with underscores in the variable name.spring-doc.cn
For example, the configuration property my.service[0].other would use an environment variable named MY_SERVICE_0_OTHER.spring-doc.cn
Support for binding from environment variables is applied to the systemEnvironment property source and to any additional property source whose name ends with -systemEnvironment.spring-doc.cn
Binding Maps From Environment Variables
When Spring Boot binds an environment variable to a property class, it lowercases the environment variable name before binding. Most of the time this detail isn’t important, except when binding to Map properties.spring-doc.cn
The keys in the Map are always in lowercase, as seen in the following example:spring-doc.cn
import java.util.HashMap;
import java.util.Map;
@ConfigurationProperties(prefix = "my.props")
public class MyMapsProperties {
	private final Map<String, String> values = new HashMap<>();
	public Map<String, String> getValues() {
		return this.values;
	val values: Map<String, String> = HashMap()
When setting MY_PROPS_VALUES_KEY=value, the values Map contains a {"key"="value"} entry.spring-doc.cn
Only the environment variable name is lower-cased, not the value. When setting MY_PROPS_VALUES_KEY=VALUE, the values Map contains a {"key"="VALUE"} entry.spring-doc.cn
Caching
Relaxed binding uses a cache to improve performance. By default, this caching is only applied to immutable property sources. To customize this behavior, for example to enable caching for mutable property sources, use ConfigurationPropertyCaching.spring-doc.cn
Merging Complex Types
When lists are configured in more than one place, overriding works by replacing the entire list.spring-doc.cn
For example, assume a MyPojo object with name and description attributes that are null by default. The following example exposes a list of MyPojo objects from MyProperties:spring-doc.cn
@ConfigurationProperties("my")
	private final List<MyPojo> list = new ArrayList<>();
	public List<MyPojo> getList() {
		return this.list;
	val list: List<MyPojo> = ArrayList()
Consider the following configuration:spring-doc.cn
my.list[0].name=my name
my.list[0].description=my description
spring.config.activate.on-profile=dev
my.list[0].name=my another name
my:
  list:
  - name: "my name"
    description: "my description"
spring:
  config:
    activate:
      on-profile: "dev"
my:
  list:
  - name: "my another name"
If the dev profile is not active, MyProperties.list contains one MyPojo entry, as previously defined. If the dev profile is enabled, however, the list still contains only one entry (with a name of my another name and a description of null). This configuration does not add a second MyPojo instance to the list, and it does not merge the items.spring-doc.cn
When a List is specified in multiple profiles, the one with the highest priority (and only that one) is used. Consider the following example:spring-doc.cn
my.list[1].name=another name
my.list[1].description=another description
my:
  list:
  - name: "my name"
  - name: "another name"
    description: "another description"
spring:
  config:
    activate:
      on-profile: "dev"
my:
  list:
In the preceding example, if the dev profile is active, MyProperties.list contains one MyPojo entry (with a name of my another name and a description of null). For YAML, both comma-separated lists and YAML lists can be used for completely overriding the contents of the list.spring-doc.cn
For Map properties, you can bind with property values drawn from multiple sources. However, for the same property in multiple sources, the one with the highest priority is used. The following example exposes a Map<String, MyPojo> from MyProperties:spring-doc.cn
import java.util.LinkedHashMap;
	private final Map<String, MyPojo> map = new LinkedHashMap<>();
	public Map<String, MyPojo> getMap() {
		return this.map;
	val map: Map<String, MyPojo> = LinkedHashMap()
my.map.key1.name=my name 1
my.map.key1.description=my description 1
my.map.key1.name=dev name 1
my.map.key2.name=dev name 2
my.map.key2.description=dev description 2
my:
  map:
    key1:
      name: "my name 1"
      description: "my description 1"
spring:
  config:
    activate:
      on-profile: "dev"
my:
  map:
    key1:
      name: "dev name 1"
    key2:
      name: "dev name 2"
      description: "dev description 2"
If the dev profile is not active, MyProperties.map contains one entry with key key1 (with a name of my name 1 and a description of my description 1). If the dev profile is enabled, however, map contains two entries with keys key1 (with a name of dev name 1 and a description of my description 1) and key2 (with a name of dev name 2 and a description of dev description 2).spring-doc.cn
The preceding merging rules apply to properties from all property sources, and not just files.
Properties Conversion
Spring Boot attempts to coerce the external application properties to the right type when it binds to the @ConfigurationProperties beans. If you need custom type conversion, you can provide a ConversionService bean (with a bean named conversionService) or custom property editors (through a CustomEditorConfigurer bean) or custom converters (with bean definitions annotated as @ConfigurationPropertiesBinding).spring-doc.cn
As this bean is requested very early during the application lifecycle, make sure to limit the dependencies that your ConversionService is using. Typically, any dependency that you require may not be fully initialized at creation time. You may want to rename your custom ConversionService if it is not required for configuration keys coercion and only rely on custom converters qualified with @ConfigurationPropertiesBinding.
Converting Durations
Spring Boot has dedicated support for expressing durations. If you expose a Duration property, the following formats in application properties are available:spring-doc.cn
import java.time.Duration;
import java.time.temporal.ChronoUnit;
import org.springframework.boot.convert.DurationUnit;
	@DurationUnit(ChronoUnit.SECONDS)
	private Duration sessionTimeout = Duration.ofSeconds(30);
	private Duration readTimeout = Duration.ofMillis(1000);
	public Duration getSessionTimeout() {
		return this.sessionTimeout;
	public void setSessionTimeout(Duration sessionTimeout) {
		this.sessionTimeout = sessionTimeout;
	public Duration getReadTimeout() {
		return this.readTimeout;
	public void setReadTimeout(Duration readTimeout) {
		this.readTimeout = readTimeout;
	var sessionTimeout = Duration.ofSeconds(30)
	var readTimeout = Duration.ofMillis(1000)
To specify a session timeout of 30 seconds, 30, PT30S and 30s are all equivalent. A read timeout of 500ms can be specified in any of the following form: 500, PT0.5S and 500ms.spring-doc.cn
You can also use any of the supported units. These are:spring-doc.cn
The default unit is milliseconds and can be overridden using @DurationUnit as illustrated in the sample above.spring-doc.cn
If you prefer to use constructor binding, the same properties can be exposed, as shown in the following example:spring-doc.cn
	// fields...
	private final Duration sessionTimeout;
	private final Duration readTimeout;
	public MyProperties(@DurationUnit(ChronoUnit.SECONDS) @DefaultValue("30s") Duration sessionTimeout,
			@DefaultValue("1000ms") Duration readTimeout) {
	// getters...
class MyProperties(@param:DurationUnit(ChronoUnit.SECONDS) @param:DefaultValue("30s") val sessionTimeout: Duration,
		@param:DefaultValue("1000ms") val readTimeout: Duration)
If you are upgrading a Long property, make sure to define the unit (using @DurationUnit) if it is not milliseconds. Doing so gives a transparent upgrade path while supporting a much richer format.
Converting Periods
In addition to durations, Spring Boot can also work with Period type. The following formats can be used in application properties:spring-doc.cn
The following units are supported with the simple format:spring-doc.cn
The Period type never actually stores the number of weeks, it is a shortcut that means “7 days”.
Converting Data Sizes
Spring Framework has a DataSize value type that expresses a size in bytes. If you expose a DataSize property, the following formats in application properties are available:spring-doc.cn
  • A regular long representation (using bytes as the default unit unless a @DataSizeUnit has been specified)spring-doc.cn
  • A more readable format where the value and the unit are coupled (10MB means 10 megabytes)spring-doc.cn
import org.springframework.boot.convert.DataSizeUnit;
import org.springframework.util.unit.DataSize;
import org.springframework.util.unit.DataUnit;
	@DataSizeUnit(DataUnit.MEGABYTES)
	private DataSize bufferSize = DataSize.ofMegabytes(2);
	private DataSize sizeThreshold = DataSize.ofBytes(512);
	// getters/setters...
	public DataSize getBufferSize() {
		return this.bufferSize;
	public void setBufferSize(DataSize bufferSize) {
		this.bufferSize = bufferSize;
	public DataSize getSizeThreshold() {
		return this.sizeThreshold;
	public void setSizeThreshold(DataSize sizeThreshold) {
		this.sizeThreshold = sizeThreshold;
	var bufferSize = DataSize.ofMegabytes(2)
	var sizeThreshold = DataSize.ofBytes(512)
To specify a buffer size of 10 megabytes, 10 and 10MB are equivalent. A size threshold of 256 bytes can be specified as 256 or 256B.spring-doc.cn
The default unit is bytes and can be overridden using @DataSizeUnit as illustrated in the sample above.spring-doc.cn
	// fields...
	private final DataSize bufferSize;
	private final DataSize sizeThreshold;
	public MyProperties(@DataSizeUnit(DataUnit.MEGABYTES) @DefaultValue("2MB") DataSize bufferSize,
			@DefaultValue("512B") DataSize sizeThreshold) {
	// getters...
class MyProperties(@param:DataSizeUnit(DataUnit.MEGABYTES) @param:DefaultValue("2MB") val bufferSize: DataSize,
		@param:DefaultValue("512B") val sizeThreshold: DataSize)
If you are upgrading a Long property, make sure to define the unit (using @DataSizeUnit) if it is not bytes. Doing so gives a transparent upgrade path while supporting a much richer format.
Converting Base64 Data
Spring Boot supports resolving binary data that have been Base64 encoded. If you expose a Resource property, the base64 encoded text can be provided as the value with a base64: prefix, as shown in the following example:spring-doc.cn
my.property=base64:SGVsbG8gV29ybGQ=
my:
  property: base64:SGVsbG8gV29ybGQ=
The Resource property can also be used to provide the path to the resource, making it more versatile.
@ConfigurationProperties Validation
Spring Boot attempts to validate @ConfigurationProperties classes whenever they are annotated with Spring’s @Validated annotation. You can use JSR-303 jakarta.validation constraint annotations directly on your configuration class. To do so, ensure that a compliant JSR-303 implementation is on your classpath and then add constraint annotations to your fields, as shown in the following example:spring-doc.cn
import jakarta.validation.constraints.NotNull;
import org.springframework.validation.annotation.Validated;
@Validated
	@NotNull
@Validated
	var remoteAddress: @NotNull InetAddress? = null
You can also trigger validation by annotating the @Bean method that creates the configuration properties with @Validated.
To cascade validation to nested properties the associated field must be annotated with @Valid. The following example builds on the preceding MyProperties example:spring-doc.cn
import jakarta.validation.Valid;
import jakarta.validation.constraints.NotEmpty;
@Validated
	@NotNull
	@Valid
		@NotEmpty
@Validated
	@Valid
	class Security {
		@NotEmpty
You can also add a custom Spring Validator by creating a bean definition called configurationPropertiesValidator. The @Bean method should be declared static. The configuration properties validator is created very early in the application’s lifecycle, and declaring the @Bean method as static lets the bean be created without having to instantiate the @Configuration class. Doing so avoids any problems that may be caused by early instantiation.spring-doc.cn
The spring-boot-actuator module includes an endpoint that exposes all @ConfigurationProperties beans. Point your web browser to /actuator/configprops or use the equivalent JMX endpoint. See the Production ready features section for details.
@ConfigurationProperties vs. @Value
The @Value annotation is a core container feature, and it does not provide the same features as type-safe configuration properties. The following table summarizes the features that are supported by @ConfigurationProperties and @Value:spring-doc.cn
Feature @ConfigurationProperties @Value
Relaxed bindingspring-doc.cn
Yesspring-doc.cn
Limited (see note below)spring-doc.cn
Meta-data supportspring-doc.cn
Yesspring-doc.cn
Nospring-doc.cn
SpEL evaluationspring-doc.cn
Nospring-doc.cn
Yesspring-doc.cn
If you do want to use @Value, we recommend that you refer to property names using their canonical form (kebab-case using only lowercase letters). This will allow Spring Boot to use the same logic as it does when relaxed binding @ConfigurationProperties.spring-doc.cn
For example, @Value("${demo.item-price}") will pick up demo.item-price and demo.itemPrice forms from the application.properties file, as well as DEMO_ITEMPRICE from the system environment. If you used @Value("${demo.itemPrice}") instead, demo.item-price and DEMO_ITEMPRICE would not be considered.spring-doc.cn
If you define a set of configuration keys for your own components, we recommend you group them in a POJO annotated with @ConfigurationProperties. Doing so will provide you with structured, type-safe object that you can inject into your own beans.spring-doc.cn
SpEL expressions from application property files are not processed at time of parsing these files and populating the environment. However, it is possible to write a SpEL expression in @Value. If the value of a property from an application property file is a SpEL expression, it will be evaluated when consumed through @Value.spring-doc.cn
