Info (info)
The info endpoint provides general information about the application.spring-doc.cn
Retrieving the Info
To retrieve the information about the application, make a GET request to /actuator/info, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/info' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 231
  "git" : {
    "branch" : "main",
    "commit" : {
      "id" : "df027cf",
      "time" : "2025-04-24T12:37:53Z"
  "build" : {
    "artifact" : "application",
    "version" : "1.0.3",
    "group" : "com.example"
Response Structure
The response contains general information about the application. Each section of the response is contributed by an InfoContributor. Spring Boot provides several contributors that are described below.spring-doc.cn
Build Response Structure
The following table describe the structure of the build section of the response:spring-doc.cn
Path Type Description
artifactspring-doc.cn
Stringspring-doc.cn
Artifact ID of the application, if any.spring-doc.cn
groupspring-doc.cn
Stringspring-doc.cn
Group ID of the application, if any.spring-doc.cn
namespring-doc.cn
Stringspring-doc.cn
Name of the application, if any.spring-doc.cn
versionspring-doc.cn
Stringspring-doc.cn
Version of the application, if any.spring-doc.cn
timespring-doc.cn
Variesspring-doc.cn
Timestamp of when the application was built, if any.spring-doc.cn
Git Response Structure
The following table describes the structure of the git section of the response:spring-doc.cn
branchspring-doc.cn
Stringspring-doc.cn
Name of the Git branch, if any.spring-doc.cn
commitspring-doc.cn
Objectspring-doc.cn
Details of the Git commit, if any.spring-doc.cn
commit.timespring-doc.cn
Variesspring-doc.cn
Timestamp of the commit, if any.spring-doc.cn
commit.idspring-doc.cn
Stringspring-doc.cn
ID of the commit, if any.spring-doc.cn
This is the "simple" output. The contributor can also be configured to output all available data.
