Metrics (metrics)
The metrics endpoint provides access to application metrics to diagnose the metrics the application has recorded. This endpoint should not be "scraped" or used as a metrics backend in production. Its purpose is to show the currently registered metrics so users can see what metrics are available, what their current values are, and if triggering certain operations cause any change in certain values. If you want to diagnose your applications through the metrics they collect, you should use an external metrics backend. In this case, the metrics endpoint can still be useful.spring-doc.cn
Retrieving Metric Names
To retrieve the names of the available metrics, make a GET request to /actuator/metrics, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/metrics' -i -X GET
The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 154
  "names" : [ "jvm.buffer.count", "jvm.buffer.memory.used", "jvm.buffer.total.capacity", "jvm.memory.committed", "jvm.memory.max", "jvm.memory.used" ]
Response Structure
The response contains details of the metric names. The following table describes the structure of the response:spring-doc.cn
Path Type Description
namesspring-doc.cn
Arrayspring-doc.cn
Names of the known metrics.spring-doc.cn
Retrieving a Metric
To retrieve a metric, make a GET request to /actuator/metrics/{metric.name}, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/metrics/jvm.memory.max' -i -X GET
The preceding example retrieves information about the metric named jvm.memory.max. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Disposition: inline;filename=f.txt
Content-Length: 555
  "name" : "jvm.memory.max",
  "description" : "The maximum amount of memory in bytes that can be used for memory management",
  "baseUnit" : "bytes",
  "measurements" : [ {
    "statistic" : "VALUE",
    "value" : 2.399141885E9
  "availableTags" : [ {
    "tag" : "area",
    "values" : [ "heap", "nonheap" ]
    "tag" : "id",
    "values" : [ "CodeHeap 'profiled nmethods'", "G1 Old Gen", "CodeHeap 'non-profiled nmethods'", "G1 Survivor Space", "Compressed Class Space", "Metaspace", "G1 Eden Space", "CodeHeap 'non-nmethods'" ]
Query Parameters
The endpoint uses query parameters to drill down into a metric by using its tags. The following table shows the single supported query parameter:spring-doc.cn
Parameter Description
tagspring-doc.cn
A tag to use for drill-down in the form name:value.spring-doc.cn
Response Structure
The response contains details of the metric. The following table describes the structure of the response:spring-doc.cn
namespring-doc.cn
Stringspring-doc.cn
Name of the metricspring-doc.cn
descriptionspring-doc.cn
Stringspring-doc.cn
Description of the metricspring-doc.cn
baseUnitspring-doc.cn
Stringspring-doc.cn
Base unit of the metricspring-doc.cn
measurementsspring-doc.cn
Arrayspring-doc.cn
Measurements of the metricspring-doc.cn
measurements[].statisticspring-doc.cn
Stringspring-doc.cn
Statistic of the measurement. (TOTAL, TOTAL_TIME, COUNT, MAX, VALUE, UNKNOWN, ACTIVE_TASKS, DURATION).spring-doc.cn
measurements[].valuespring-doc.cn
Numberspring-doc.cn
Value of the measurement.spring-doc.cn
availableTagsspring-doc.cn
Arrayspring-doc.cn
Tags that are available for drill-down.spring-doc.cn
availableTags[].tagspring-doc.cn
Stringspring-doc.cn
Name of the tag.spring-doc.cn
availableTags[].valuesspring-doc.cn
Arrayspring-doc.cn
Possible values of the tag.spring-doc.cn
Drilling Down
To drill down into a metric, make a GET request to /actuator/metrics/{metric.name} using the tag query parameter, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/metrics/jvm.memory.max?tag=area%3Anonheap&tag=id%3ACompressed+Class+Space' -i -X GET
The preceding example retrieves the jvm.memory.max metric, where the area tag has a value of nonheap and the id attribute has a value of Compressed Class Space. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Length: 263
    "value" : 1.073741824E9
  "availableTags" : [ ]
