Endpoints
Actuator endpoints let you monitor and interact with your application. Spring Boot includes a number of built-in endpoints and lets you add your own. For example, the health endpoint provides basic application health information.spring-doc.cn
You can control access to each individual endpoint and expose them (make them remotely accessible) over HTTP or JMX. An endpoint is considered to be available when access to it is permitted and it is exposed. The built-in endpoints are auto-configured only when they are available. Most applications choose exposure over HTTP, where the ID of the endpoint and a prefix of /actuator is mapped to a URL. For example, by default, the health endpoint is mapped to /actuator/health.spring-doc.cn
To learn more about the Actuator’s endpoints and their request and response formats, see the API documentation.
The following technology-agnostic endpoints are available:spring-doc.cn
ID Description
auditeventsspring-doc.cn
Exposes audit events information for the current application. Requires an AuditEventRepository bean.spring-doc.cn
beansspring-doc.cn
Displays a complete list of all the Spring beans in your application.spring-doc.cn
cachesspring-doc.cn
Exposes available caches.spring-doc.cn
conditionsspring-doc.cn
Shows the conditions that were evaluated on configuration and auto-configuration classes and the reasons why they did or did not match.spring-doc.cn
configpropsspring-doc.cn
Displays a collated list of all @ConfigurationProperties. Subject to sanitization.spring-doc.cn
envspring-doc.cn
Exposes properties from Spring’s ConfigurableEnvironment. Subject to sanitization.spring-doc.cn
flywayspring-doc.cn
Shows any Flyway database migrations that have been applied. Requires one or more Flyway beans.spring-doc.cn
healthspring-doc.cn
Shows application health information.spring-doc.cn
httpexchangesspring-doc.cn
Displays HTTP exchange information (by default, the last 100 HTTP request-response exchanges). Requires an HttpExchangeRepository bean.spring-doc.cn
infospring-doc.cn
Displays arbitrary application info.spring-doc.cn
integrationgraphspring-doc.cn
Shows the Spring Integration graph. Requires a dependency on spring-integration-core.spring-doc.cn
loggersspring-doc.cn
Shows and modifies the configuration of loggers in the application.spring-doc.cn
liquibasespring-doc.cn
Shows any Liquibase database migrations that have been applied. Requires one or more Liquibase beans.spring-doc.cn
metricsspring-doc.cn
Shows “metrics” information for the current application to diagnose the metrics the application has recorded.spring-doc.cn
mappingsspring-doc.cn
Displays a collated list of all @RequestMapping paths.spring-doc.cn
quartzspring-doc.cn
Shows information about Quartz Scheduler jobs. Subject to sanitization.spring-doc.cn
scheduledtasksspring-doc.cn
Displays the scheduled tasks in your application.spring-doc.cn
sessionsspring-doc.cn
Allows retrieval and deletion of user sessions from a Spring Session-backed session store. Requires a servlet-based web application that uses Spring Session.spring-doc.cn
shutdownspring-doc.cn
Lets the application be gracefully shutdown. Only works when using jar packaging. Disabled by default.spring-doc.cn
startupspring-doc.cn
Shows the startup steps data collected by the ApplicationStartup. Requires the SpringApplication to be configured with a BufferingApplicationStartup.spring-doc.cn
threaddumpspring-doc.cn
Performs a thread dump.spring-doc.cn
If your application is a web application (Spring MVC, Spring WebFlux, or Jersey), you can use the following additional endpoints:spring-doc.cn
ID Description
heapdumpspring-doc.cn
Returns a heap dump file. On a HotSpot JVM, an HPROF-format file is returned. On an OpenJ9 JVM, a PHD-format file is returned.spring-doc.cn
logfilespring-doc.cn
Returns the contents of the logfile (if the logging.file.name or the logging.file.path property has been set). Supports the use of the HTTP Range header to retrieve part of the log file’s content.spring-doc.cn
prometheusspring-doc.cn
Exposes metrics in a format that can be scraped by a Prometheus server. Requires a dependency on micrometer-registry-prometheus.spring-doc.cn
Controlling Access to Endpoints
By default, access to all endpoints except for shutdown is unrestricted. To configure the permitted access to an endpoint, use its management.endpoint.<id>.access property. The following example allows unrestricted access to the shutdown endpoint:spring-doc.cn
management.endpoint.shutdown.access=unrestricted
management:
  endpoint:
    shutdown:
      access: unrestricted
If you prefer access to be opt-in rather than opt-out, set the management.endpoints.access.default property to none and use individual endpoint access properties to opt back in. The following example allows read-only access to the loggers endpoint and denies access to all other endpoints:spring-doc.cn
management.endpoints.access.default=none
management.endpoint.loggers.access=read-only
management:
  endpoints:
    access:
      default: none
  endpoint:
    loggers:
      access: read-only
Inaccessible endpoints are removed entirely from the application context. If you want to change only the technologies over which an endpoint is exposed, use the include and exclude properties instead.
Limiting Access
Application-wide endpoint access can be limited using the management.endpoints.access.max-permitted property. This property takes precedence over the default access or an individual endpoint’s access level. Set it to none to make all endpoints inaccessible. Set it to read-only to only allow read access to endpoints.spring-doc.cn
For @Endpoint, @JmxEndpoint, and @WebEndpoint, read access equates to the endpoint methods annotated with @ReadOperation. For @ControllerEndpoint and @RestControllerEndpoint, read access equates to request mappings that can handle GET and HEAD requests. For @ServletEndpoint, read access equates to GET and HEAD requests.spring-doc.cn
Exposing Endpoints
By default, only the health endpoint is exposed over HTTP and JMX. Since Endpoints may contain sensitive information, you should carefully consider when to expose them.spring-doc.cn
To change which endpoints are exposed, use the following technology-specific include and exclude properties:spring-doc.cn
Property Default
management.endpoints.jmx.exposure.excludespring-doc.cn
management.endpoints.jmx.exposure.includespring-doc.cn
healthspring-doc.cn
management.endpoints.web.exposure.excludespring-doc.cn
management.endpoints.web.exposure.includespring-doc.cn
healthspring-doc.cn
The include property lists the IDs of the endpoints that are exposed. The exclude property lists the IDs of the endpoints that should not be exposed. The exclude property takes precedence over the include property. You can configure both the include and the exclude properties with a list of endpoint IDs.spring-doc.cn
For example, to only expose the health and info endpoints over JMX, use the following property:spring-doc.cn
management.endpoints.jmx.exposure.include=health,info
management:
  endpoints:
    jmx:
      exposure:
        include: "health,info"
* can be used to select all endpoints. For example, to expose everything over HTTP except the env and beans endpoints, use the following properties:spring-doc.cn
management.endpoints.web.exposure.include=*
management.endpoints.web.exposure.exclude=env,beans
management:
  endpoints:
    web:
      exposure:
        include: "*"
        exclude: "env,beans"
* has a special meaning in YAML, so be sure to add quotation marks if you want to include (or exclude) all endpoints.
If your application is exposed publicly, we strongly recommend that you also secure your endpoints.
If you want to implement your own strategy for when endpoints are exposed, you can register an EndpointFilter bean.
Security
For security purposes, only the /health endpoint is exposed over HTTP by default. You can use the management.endpoints.web.exposure.include property to configure the endpoints that are exposed.spring-doc.cn
Before setting the management.endpoints.web.exposure.include, ensure that the exposed actuators do not contain sensitive information, are secured by placing them behind a firewall, or are secured by something like Spring Security.
If Spring Security is on the classpath and no other SecurityFilterChain bean is present, all actuators other than /health are secured by Spring Boot auto-configuration. If you define a custom SecurityFilterChain bean, Spring Boot auto-configuration backs off and lets you fully control the actuator access rules.spring-doc.cn
If you wish to configure custom security for HTTP endpoints (for example, to allow only users with a certain role to access them), Spring Boot provides some convenient RequestMatcher objects that you can use in combination with Spring Security.spring-doc.cn
A typical Spring Security configuration might look something like the following example:spring-doc.cn
import org.springframework.boot.actuate.autoconfigure.security.servlet.EndpointRequest;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.web.SecurityFilterChain;
import static org.springframework.security.config.Customizer.withDefaults;
public class MySecurityConfiguration {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		http.securityMatcher(EndpointRequest.toAnyEndpoint());
		http.authorizeHttpRequests((requests) -> requests.anyRequest().hasRole("ENDPOINT_ADMIN"));
		http.httpBasic(withDefaults());
		return http.build();
import org.springframework.security.config.Customizer.withDefaults
	fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
		http.securityMatcher(EndpointRequest.toAnyEndpoint()).authorizeHttpRequests { requests ->
		return http.build()
The preceding example uses EndpointRequest.toAnyEndpoint() to match a request to any endpoint and then ensures that all have the ENDPOINT_ADMIN role. Several other matcher methods are also available on EndpointRequest. See the API documentation for details.spring-doc.cn
If you deploy applications behind a firewall, you may prefer that all your actuator endpoints can be accessed without requiring authentication. You can do so by changing the management.endpoints.web.exposure.include property, as follows:spring-doc.cn
management:
  endpoints:
    web:
      exposure:
        include: "*"
Additionally, if Spring Security is present, you would need to add custom security configuration that allows unauthenticated access to the endpoints, as the following example shows:spring-doc.cn
		http.authorizeHttpRequests((requests) -> requests.anyRequest().permitAll());
		return http.build()
In both of the preceding examples, the configuration applies only to the actuator endpoints. Since Spring Boot’s security configuration backs off completely in the presence of any SecurityFilterChain bean, you need to configure an additional SecurityFilterChain bean with rules that apply to the rest of the application.
Cross Site Request Forgery Protection
Since Spring Boot relies on Spring Security’s defaults, CSRF protection is turned on by default. This means that the actuator endpoints that require a POST (shutdown and loggers endpoints), a PUT, or a DELETE get a 403 (forbidden) error when the default security configuration is in use.spring-doc.cn
We recommend disabling CSRF protection completely only if you are creating a service that is used by non-browser clients.
You can find additional information about CSRF protection in the Spring Security Reference Guide.spring-doc.cn
Configuring Endpoints
Endpoints automatically cache responses to read operations that do not take any parameters. To configure the amount of time for which an endpoint caches a response, use its cache.time-to-live property. The following example sets the time-to-live of the beans endpoint’s cache to 10 seconds:spring-doc.cn
management.endpoint.beans.cache.time-to-live=10s
management:
  endpoint:
    beans:
      cache:
        time-to-live: "10s"
The management.endpoint.<name> prefix uniquely identifies the endpoint that is being configured.
Sanitize Sensitive Values
Information returned by the /env, /configprops and /quartz endpoints can be sensitive, so by default values are always fully sanitized (replaced by ******).spring-doc.cn
Values can only be viewed in an unsanitized form when:spring-doc.cn
The show-values property can be configured for sanitizable endpoints to one of the following values:spring-doc.cn
For HTTP endpoints, a user is considered to be authorized if they have authenticated and have the roles configured by the endpoint’s roles property. By default, any authenticated user is authorized.spring-doc.cn
For JMX endpoints, all users are always authorized.spring-doc.cn
The following example allows all users with the admin role to view values from the /env endpoint in their original form. Unauthorized users, or users without the admin role, will see only sanitized values.spring-doc.cn
management.endpoint.env.show-values=when-authorized
management.endpoint.env.roles=admin
management:
  endpoint:
    env:
      show-values: when-authorized
      roles: "admin"
This example assumes that no SanitizingFunction beans have been defined.
Hypermedia for Actuator Web Endpoints
A “discovery page” is added with links to all the endpoints. The “discovery page” is available on /actuator by default.spring-doc.cn
To disable the “discovery page”, add the following property to your application properties:spring-doc.cn
management.endpoints.web.discovery.enabled=false
management:
  endpoints:
    web:
      discovery:
        enabled: false
When a custom management context path is configured, the “discovery page” automatically moves from /actuator to the root of the management context. For example, if the management context path is /management, the discovery page is available from /management. When the management context path is set to /, the discovery page is disabled to prevent the possibility of a clash with other mappings.spring-doc.cn
CORS Support
Cross-origin resource sharing (CORS) is a W3C specification that lets you specify in a flexible way what kind of cross-domain requests are authorized. If you use Spring MVC or Spring WebFlux, you can configure Actuator’s web endpoints to support such scenarios.spring-doc.cn
CORS support is disabled by default and is only enabled once you have set the management.endpoints.web.cors.allowed-origins property. The following configuration permits GET and POST calls from the example.com domain:spring-doc.cn
management.endpoints.web.cors.allowed-origins=https://example.com
management.endpoints.web.cors.allowed-methods=GET,POST
management:
  endpoints:
    web:
      cors:
        allowed-origins: "https://example.com"
        allowed-methods: "GET,POST"
See CorsEndpointProperties for a complete list of options.
Implementing Custom Endpoints
If you add a @Bean annotated with @Endpoint, any methods annotated with @ReadOperation, @WriteOperation, or @DeleteOperation are automatically exposed over JMX and, in a web application, over HTTP as well. Endpoints can be exposed over HTTP by using Jersey, Spring MVC, or Spring WebFlux. If both Jersey and Spring MVC are available, Spring MVC is used.spring-doc.cn
The following example exposes a read operation that returns a custom object:spring-doc.cn
	@ReadOperation
	public CustomData getData() {
		return new CustomData("test", 5);
	@ReadOperation
	fun getData(): CustomData {
		return CustomData("test", 5)
You can also write technology-specific endpoints by using @JmxEndpoint or @WebEndpoint. These endpoints are restricted to their respective technologies. For example, @WebEndpoint is exposed only over HTTP and not over JMX.spring-doc.cn
You can write technology-specific extensions by using @EndpointWebExtension and @EndpointJmxExtension. These annotations let you provide technology-specific operations to augment an existing endpoint.spring-doc.cn
Finally, if you need access to web-framework-specific functionality, you can implement servlet or Spring @Controller and @RestController endpoints at the cost of them not being available over JMX or when using a different web framework.spring-doc.cn
Receiving Input
Operations on an endpoint receive input through their parameters. When exposed over the web, the values for these parameters are taken from the URL’s query parameters and from the JSON request body. When exposed over JMX, the parameters are mapped to the parameters of the MBean’s operations. Parameters are required by default. They can be made optional by annotating them with either @javax.annotation.Nullable or @Nullable.spring-doc.cn
You can map each root property in the JSON request body to a parameter of the endpoint. Consider the following JSON request body:spring-doc.cn
	"name": "test",
	"counter": 42
You can use this to invoke a write operation that takes String name and int counter parameters, as the following example shows:spring-doc.cn
	@WriteOperation
	public void updateData(String name, int counter) {
		// injects "test" and 42
	@WriteOperation
	fun updateData(name: String?, counter: Int) {
Because endpoints are technology agnostic, only simple types can be specified in the method signature. In particular, declaring a single parameter with a CustomData type that defines a name and counter properties is not supported.
To let the input be mapped to the operation method’s parameters, Java code that implements an endpoint should be compiled with -parameters. For Kotlin code, please review the recommendation of the Spring Framework reference. This will happen automatically if you use Spring Boot’s Gradle plugin or if you use Maven and spring-boot-starter-parent.
Input Type Conversion
The parameters passed to endpoint operation methods are, if necessary, automatically converted to the required type. Before calling an operation method, the input received over JMX or HTTP is converted to the required types by using an instance of ApplicationConversionService as well as any Converter or GenericConverter beans qualified with @EndpointConverter.spring-doc.cn
Custom Web Endpoints
Operations on an @Endpoint, @WebEndpoint, or @EndpointWebExtension are automatically exposed over HTTP using Jersey, Spring MVC, or Spring WebFlux. If both Jersey and Spring MVC are available, Spring MVC is used.spring-doc.cn
Web Endpoint Request Predicates
A request predicate is automatically generated for each operation on a web-exposed endpoint.spring-doc.cn
Path
The path of the predicate is determined by the ID of the endpoint and the base path of the web-exposed endpoints. The default base path is /actuator. For example, an endpoint with an ID of sessions uses /actuator/sessions as its path in the predicate.spring-doc.cn
You can further customize the path by annotating one or more parameters of the operation method with @Selector. Such a parameter is added to the path predicate as a path variable. The variable’s value is passed into the operation method when the endpoint operation is invoked. If you want to capture all remaining path elements, you can add @Selector(Match=ALL_REMAINING) to the last parameter and make it a type that is conversion-compatible with a String[].spring-doc.cn
HTTP method
The HTTP method of the predicate is determined by the operation type, as shown in the following table:spring-doc.cn
Operation HTTP method
@ReadOperationspring-doc.cn
GETspring-doc.cn
@WriteOperationspring-doc.cn
POSTspring-doc.cn
@DeleteOperationspring-doc.cn
DELETEspring-doc.cn
Consumes
For a @WriteOperation (HTTP POST) that uses the request body, the consumes clause of the predicate is application/vnd.spring-boot.actuator.v2+json, application/json. For all other operations, the consumes clause is empty.spring-doc.cn
Produces
The produces clause of the predicate can be determined by the produces attribute of the @DeleteOperation, @ReadOperation, and @WriteOperation annotations. The attribute is optional. If it is not used, the produces clause is determined automatically.spring-doc.cn
If the operation method returns void or Void, the produces clause is empty. If the operation method returns a Resource, the produces clause is application/octet-stream. For all other operations, the produces clause is application/vnd.spring-boot.actuator.v2+json, application/json.spring-doc.cn
Web Endpoint Response Status
The default response status for an endpoint operation depends on the operation type (read, write, or delete) and what, if anything, the operation returns.spring-doc.cn
If a @ReadOperation returns a value, the response status will be 200 (OK). If it does not return a value, the response status will be 404 (Not Found).spring-doc.cn
If a @WriteOperation or @DeleteOperation returns a value, the response status will be 200 (OK). If it does not return a value, the response status will be 204 (No Content).spring-doc.cn
If an operation is invoked without a required parameter or with a parameter that cannot be converted to the required type, the operation method is not called, and the response status will be 400 (Bad Request).spring-doc.cn
Web Endpoint Range Requests
You can use an HTTP range request to request part of an HTTP resource. When using Spring MVC or Spring Web Flux, operations that return a Resource automatically support range requests.spring-doc.cn
Range requests are not supported when using Jersey.
Web Endpoint Security
An operation on a web endpoint or a web-specific endpoint extension can receive the current Principal or SecurityContext as a method parameter. The former is typically used in conjunction with either @javax.annotation.Nullable or @Nullable to provide different behavior for authenticated and unauthenticated users. The latter is typically used to perform authorization checks by using its isUserInRole(String) method.spring-doc.cn
Health Information
You can use health information to check the status of your running application. It is often used by monitoring software to alert someone when a production system goes down. The information exposed by the health endpoint depends on the management.endpoint.health.show-details and management.endpoint.health.show-components properties, which can be configured with one of the following values:spring-doc.cn
Name Description
neverspring-doc.cn
Details are never shown.spring-doc.cn
when-authorizedspring-doc.cn
Details are shown only to authorized users. Authorized roles can be configured by using management.endpoint.health.roles.spring-doc.cn
alwaysspring-doc.cn
Details are shown to all users.spring-doc.cn
The default value is never. A user is considered to be authorized when they are in one or more of the endpoint’s roles. If the endpoint has no configured roles (the default), all authenticated users are considered to be authorized. You can configure the roles by using the management.endpoint.health.roles property.spring-doc.cn
If you have secured your application and wish to use always, your security configuration must permit access to the health endpoint for both authenticated and unauthenticated users.
Health information is collected from the content of a HealthContributorRegistry (by default, all HealthContributor instances defined in your ApplicationContext). Spring Boot includes a number of auto-configured HealthContributor beans, and you can also write your own.spring-doc.cn
A HealthContributor can be either a HealthIndicator or a CompositeHealthContributor. A HealthIndicator provides actual health information, including a Status. A CompositeHealthContributor provides a composite of other HealthContributor instances. Taken together, contributors form a tree structure to represent the overall system health.spring-doc.cn
By default, the final system health is derived by a StatusAggregator, which sorts the statuses from each HealthIndicator based on an ordered list of statuses. The first status in the sorted list is used as the overall health status. If no HealthIndicator returns a status that is known to the StatusAggregator, an UNKNOWN status is used.spring-doc.cn
You can use the HealthContributorRegistry to register and unregister health indicators at runtime.
Auto-configured HealthIndicators
When appropriate, Spring Boot auto-configures the HealthIndicator beans listed in the following table. You can also enable or disable selected indicators by configuring management.health.key.enabled, with the key listed in the following table:spring-doc.cn
Key Name Description
cassandraspring-doc.cn
CassandraDriverHealthIndicatorspring-doc.cn
Checks that a Cassandra database is up.spring-doc.cn
couchbasespring-doc.cn
CouchbaseHealthIndicatorspring-doc.cn
Checks that a Couchbase cluster is up.spring-doc.cn
dbspring-doc.cn
DataSourceHealthIndicatorspring-doc.cn
Checks that a connection to DataSource can be obtained.spring-doc.cn
diskspacespring-doc.cn
DiskSpaceHealthIndicatorspring-doc.cn
Checks for low disk space.spring-doc.cn
elasticsearchspring-doc.cn
ElasticsearchRestClientHealthIndicatorspring-doc.cn
Checks that an Elasticsearch cluster is up.spring-doc.cn
hazelcastspring-doc.cn
HazelcastHealthIndicatorspring-doc.cn
Checks that a Hazelcast server is up.spring-doc.cn
jmsspring-doc.cn
JmsHealthIndicatorspring-doc.cn
Checks that a JMS broker is up.spring-doc.cn
ldapspring-doc.cn
LdapHealthIndicatorspring-doc.cn
Checks that an LDAP server is up.spring-doc.cn
mailspring-doc.cn
MailHealthIndicatorspring-doc.cn
Checks that a mail server is up.spring-doc.cn
mongospring-doc.cn
MongoHealthIndicatorspring-doc.cn
Checks that a Mongo database is up.spring-doc.cn
neo4jspring-doc.cn
Neo4jHealthIndicatorspring-doc.cn
Checks that a Neo4j database is up.spring-doc.cn
pingspring-doc.cn
PingHealthIndicatorspring-doc.cn
Always responds with UP.spring-doc.cn
rabbitspring-doc.cn
RabbitHealthIndicatorspring-doc.cn
Checks that a Rabbit server is up.spring-doc.cn
redisspring-doc.cn
RedisHealthIndicatorspring-doc.cn
Checks that a Redis server is up.spring-doc.cn
sslspring-doc.cn
SslHealthIndicatorspring-doc.cn
Checks that SSL certificates are ok.spring-doc.cn
You can disable them all by setting the management.health.defaults.enabled property.
The ssl HealthIndicator has a "warning threshold" property named management.health.ssl.certificate-validity-warning-threshold. If an SSL certificate will be invalid within the time span defined by this threshold, the HealthIndicator will warn you but it will still return HTTP 200 to not disrupt the application. You can use this threshold to give yourself enough lead time to rotate the soon to be expired certificate.
Additional HealthIndicator beans are available but are not enabled by default:spring-doc.cn
livenessstatespring-doc.cn
LivenessStateHealthIndicatorspring-doc.cn
Exposes the “Liveness” application availability state.spring-doc.cn
readinessstatespring-doc.cn
ReadinessStateHealthIndicatorspring-doc.cn
Exposes the “Readiness” application availability state.spring-doc.cn
Writing Custom HealthIndicators
To provide custom health information, you can register Spring beans that implement the HealthIndicator interface. You need to provide an implementation of the health() method and return a Health response. The Health response should include a status and can optionally include additional details to be displayed. The following code shows a sample HealthIndicator implementation:spring-doc.cn
import org.springframework.boot.actuate.health.Health;
import org.springframework.boot.actuate.health.HealthIndicator;
@Component
public class MyHealthIndicator implements HealthIndicator {
	public Health health() {
		int errorCode = check();
		if (errorCode != 0) {
			return Health.down().withDetail("Error Code", errorCode).build();
		return Health.up().build();
	private int check() {
		// perform some specific health check
		return ...
@Component
class MyHealthIndicator : HealthIndicator {
	override fun health(): Health {
		val errorCode = check()
	private fun check(): Int {
		return  ...
The identifier for a given HealthIndicator is the name of the bean without the HealthIndicator suffix, if it exists. In the preceding example, the health information is available in an entry named my.
Health indicators are usually called over HTTP and need to respond before any connection timeouts. Spring Boot will log a warning message for any health indicator that takes longer than 10 seconds to respond. If you want to configure this threshold, you can use the management.endpoint.health.logging.slow-indicator-threshold property.
In addition to Spring Boot’s predefined Status types, Health can return a custom Status that represents a new system state. In such cases, you also need to provide a custom implementation of the StatusAggregator interface, or you must configure the default implementation by using the management.endpoint.health.status.order configuration property.spring-doc.cn
For example, assume a new Status with a code of FATAL is being used in one of your HealthIndicator implementations. To configure the severity order, add the following property to your application properties:spring-doc.cn
management.endpoint.health.status.order=fatal,down,out-of-service,unknown,up
management:
  endpoint:
    health:
      status:
        order: "fatal,down,out-of-service,unknown,up"
The HTTP status code in the response reflects the overall health status. By default, OUT_OF_SERVICE and DOWN map to 503. Any unmapped health statuses, including UP, map to 200. You might also want to register custom status mappings if you access the health endpoint over HTTP. Configuring a custom mapping disables the defaults mappings for DOWN and OUT_OF_SERVICE. If you want to retain the default mappings, you must explicitly configure them, alongside any custom mappings. For example, the following property maps FATAL to 503 (service unavailable) and retains the default mappings for DOWN and OUT_OF_SERVICE:spring-doc.cn
management.endpoint.health.status.http-mapping.down=503
management.endpoint.health.status.http-mapping.fatal=503
management.endpoint.health.status.http-mapping.out-of-service=503
management:
  endpoint:
    health:
      status:
        http-mapping:
          down: 503
          fatal: 503
          out-of-service: 503
If you need more control, you can define your own HttpCodeStatusMapper bean.
The following table shows the default status mappings for the built-in statuses:spring-doc.cn
Status Mapping
DOWNspring-doc.cn
SERVICE_UNAVAILABLE (503)spring-doc.cn
OUT_OF_SERVICEspring-doc.cn
UPspring-doc.cn
No mapping by default, so HTTP status is 200spring-doc.cn
UNKNOWNspring-doc.cn
Reactive Health Indicators
For reactive applications, such as those that use Spring WebFlux, ReactiveHealthContributor provides a non-blocking contract for getting application health. Similar to a traditional HealthContributor, health information is collected from the content of a ReactiveHealthContributorRegistry (by default, all HealthContributor and ReactiveHealthContributor instances defined in your ApplicationContext). Regular HealthContributor instances that do not check against a reactive API are executed on the elastic scheduler.spring-doc.cn
In a reactive application, you should use the ReactiveHealthContributorRegistry to register and unregister health indicators at runtime. If you need to register a regular HealthContributor, you should wrap it with ReactiveHealthContributor#adapt.
To provide custom health information from a reactive API, you can register Spring beans that implement the ReactiveHealthIndicator interface. The following code shows a sample ReactiveHealthIndicator implementation:spring-doc.cn
import reactor.core.publisher.Mono;
import org.springframework.boot.actuate.health.ReactiveHealthIndicator;
@Component
public class MyReactiveHealthIndicator implements ReactiveHealthIndicator {
	public Mono<Health> health() {
		return doHealthCheck().onErrorResume((exception) ->
			Mono.just(new Health.Builder().down(exception).build()));
	private Mono<Health> doHealthCheck() {
		return ...
@Component
class MyReactiveHealthIndicator : ReactiveHealthIndicator {
	override fun health(): Mono<Health> {
		return doHealthCheck()!!.onErrorResume { exception: Throwable? ->
			Mono.just(Health.Builder().down(exception).build())
	private fun doHealthCheck(): Mono<Health>? {
		return  ...
To handle the error automatically, consider extending from AbstractReactiveHealthIndicator.
Auto-configured ReactiveHealthIndicators
When appropriate, Spring Boot auto-configures the following ReactiveHealthIndicator beans:spring-doc.cn
CassandraDriverReactiveHealthIndicatorspring-doc.cn
CouchbaseReactiveHealthIndicatorspring-doc.cn
ElasticsearchReactiveHealthIndicatorspring-doc.cn
mongospring-doc.cn
MongoReactiveHealthIndicatorspring-doc.cn
neo4jspring-doc.cn
Neo4jReactiveHealthIndicatorspring-doc.cn
redisspring-doc.cn
RedisReactiveHealthIndicatorspring-doc.cn
If necessary, reactive indicators replace the regular ones. Also, any HealthIndicator that is not handled explicitly is wrapped automatically.
Health Groups
It is sometimes useful to organize health indicators into groups that you can use for different purposes.spring-doc.cn
To create a health indicator group, you can use the management.endpoint.health.group.<name> property and specify a list of health indicator IDs to include or exclude. For example, to create a group that includes only database indicators you can define the following:spring-doc.cn
management.endpoint.health.group.custom.include=db
management:
  endpoint:
    health:
      group:
        custom:
          include: "db"
You can then check the result by hitting localhost:8080/actuator/health/custom.spring-doc.cn
Similarly, to create a group that excludes the database indicators from the group and includes all the other indicators, you can define the following:spring-doc.cn
management.endpoint.health.group.custom.exclude=db
management:
  endpoint:
    health:
      group:
        custom:
          exclude: "db"
By default, startup will fail if a health group includes or excludes a health indicator that does not exist. To disable this behavior set management.endpoint.health.validate-group-membership to false.spring-doc.cn
By default, groups inherit the same StatusAggregator and HttpCodeStatusMapper settings as the system health. However, you can also define these on a per-group basis. You can also override the show-details and roles properties if required:spring-doc.cn
management.endpoint.health.group.custom.show-details=when-authorized
management.endpoint.health.group.custom.roles=admin
management.endpoint.health.group.custom.status.order=fatal,up
management.endpoint.health.group.custom.status.http-mapping.fatal=500
management.endpoint.health.group.custom.status.http-mapping.out-of-service=500
management:
  endpoint:
    health:
      group:
        custom:
          show-details: "when-authorized"
          roles: "admin"
          status:
            order: "fatal,up"
            http-mapping:
              fatal: 500
              out-of-service: 500
You can use @Qualifier("groupname") if you need to register custom StatusAggregator or HttpCodeStatusMapper beans for use with the group.
A health group can also include/exclude a CompositeHealthContributor. You can also include/exclude only a certain component of a CompositeHealthContributor. This can be done using the fully qualified name of the component as follows:spring-doc.cn
management.endpoint.health.group.custom.include="test/primary"
management.endpoint.health.group.custom.exclude="test/primary/b"
In the example above, the custom group will include the HealthContributor with the name primary which is a component of the composite test. Here, primary itself is a composite and the HealthContributor with the name b will be excluded from the custom group.spring-doc.cn
Health groups can be made available at an additional path on either the main or management port. This is useful in cloud environments such as Kubernetes, where it is quite common to use a separate management port for the actuator endpoints for security purposes. Having a separate port could lead to unreliable health checks because the main application might not work properly even if the health check is successful. The health group can be configured with an additional path as follows:spring-doc.cn
management.endpoint.health.group.live.additional-path="server:/healthz"
This would make the live health group available on the main server port at /healthz. The prefix is mandatory and must be either server: (represents the main server port) or management: (represents the management port, if configured.) The path must be a single path segment.spring-doc.cn
DataSource Health
The DataSource health indicator shows the health of both standard data sources and routing data source beans. The health of a routing data source includes the health of each of its target data sources. In the health endpoint’s response, each of a routing data source’s targets is named by using its routing key. If you prefer not to include routing data sources in the indicator’s output, set management.health.db.ignore-routing-data-sources to true.spring-doc.cn
Kubernetes Probes
Applications deployed on Kubernetes can provide information about their internal state with Container Probes. Depending on your Kubernetes configuration, the kubelet calls those probes and reacts to the result.spring-doc.cn
By default, Spring Boot manages your Application Availability state. If deployed in a Kubernetes environment, actuator gathers the “Liveness” and “Readiness” information from the ApplicationAvailability interface and uses that information in dedicated health indicators: LivenessStateHealthIndicator and ReadinessStateHealthIndicator. These indicators are shown on the global health endpoint ("/actuator/health"). They are also exposed as separate HTTP Probes by using health groups: "/actuator/health/liveness" and "/actuator/health/readiness".spring-doc.cn
You can then configure your Kubernetes infrastructure with the following endpoint information:spring-doc.cn
livenessProbe:
  httpGet:
    path: "/actuator/health/liveness"
    port: <actuator-port>
  failureThreshold: ...
  periodSeconds: ...
readinessProbe:
  httpGet:
    path: "/actuator/health/readiness"
  periodSeconds: ...
<actuator-port> should be set to the port that the actuator endpoints are available on. It could be the main web server port or a separate management port if the "management.server.port" property has been set.
These health groups are automatically enabled only if the application runs in a Kubernetes environment. You can enable them in any environment by using the management.endpoint.health.probes.enabled configuration property.spring-doc.cn
If an application takes longer to start than the configured liveness period, Kubernetes mentions the "startupProbe" as a possible solution. Generally speaking, the "startupProbe" is not necessarily needed here, as the "readinessProbe" fails until all startup tasks are done. This means your application will not receive traffic until it is ready. However, if your application takes a long time to start, consider using a "startupProbe" to make sure that Kubernetes won’t kill your application while it is in the process of starting. See the section that describes how probes behave during the application lifecycle.
If your Actuator endpoints are deployed on a separate management context, the endpoints do not use the same web infrastructure (port, connection pools, framework components) as the main application. In this case, a probe check could be successful even if the main application does not work properly (for example, it cannot accept new connections). For this reason, it is a good idea to make the liveness and readiness health groups available on the main server port. This can be done by setting the following property:spring-doc.cn
management.endpoint.health.probes.add-additional-paths=true
This would make the liveness group available at /livez and the readiness group available at /readyz on the main server port. Paths can be customized using the additional-path property on each group, see health groups for details.spring-doc.cn
Checking External State With Kubernetes Probes
Actuator configures the “liveness” and “readiness” probes as Health Groups. This means that all the health groups features are available for them. You can, for example, configure additional Health Indicators:spring-doc.cn
management.endpoint.health.group.readiness.include=readinessState,customCheck
management:
  endpoint:
    health:
      group:
        readiness:
          include: "readinessState,customCheck"
By default, Spring Boot does not add other health indicators to these groups.spring-doc.cn
The “liveness” probe should not depend on health checks for external systems. If the liveness state of an application is broken, Kubernetes tries to solve that problem by restarting the application instance. This means that if an external system (such as a database, a Web API, or an external cache) fails, Kubernetes might restart all application instances and create cascading failures.spring-doc.cn
As for the “readiness” probe, the choice of checking external systems must be made carefully by the application developers. For this reason, Spring Boot does not include any additional health checks in the readiness probe. If the readiness state of an application instance is unready, Kubernetes does not route traffic to that instance. Some external systems might not be shared by application instances, in which case they could be included in a readiness probe. Other external systems might not be essential to the application (the application could have circuit breakers and fallbacks), in which case they definitely should not be included. Unfortunately, an external system that is shared by all application instances is common, and you have to make a judgement call: Include it in the readiness probe and expect that the application is taken out of service when the external service is down or leave it out and deal with failures higher up the stack, perhaps by using a circuit breaker in the caller.spring-doc.cn
If all instances of an application are unready, a Kubernetes Service with type=ClusterIP or NodePort does not accept any incoming connections. There is no HTTP error response (503 and so on), since there is no connection. A service with type=LoadBalancer might or might not accept connections, depending on the provider. A service that has an explicit ingress also responds in a way that depends on the implementation — the ingress service itself has to decide how to handle the “connection refused” from downstream. HTTP 503 is quite likely in the case of both load balancer and ingress.
Also, if an application uses Kubernetes autoscaling, it may react differently to applications being taken out of the load-balancer, depending on its autoscaler configuration.spring-doc.cn
Application Lifecycle and Probe States
An important aspect of the Kubernetes Probes support is its consistency with the application lifecycle. There is a significant difference between the AvailabilityState (which is the in-memory, internal state of the application) and the actual probe (which exposes that state). Depending on the phase of application lifecycle, the probe might not be available.spring-doc.cn
Spring Boot publishes application events during startup and shutdown, and probes can listen to such events and expose the AvailabilityState information.spring-doc.cn
The following tables show the AvailabilityState and the state of HTTP connectors at different stages.spring-doc.cn
When a Spring Boot application starts:spring-doc.cn
Startup phase LivenessState ReadinessState HTTP server Notes
Startingspring-doc.cn
BROKENspring-doc.cn
REFUSING_TRAFFICspring-doc.cn
Not startedspring-doc.cn
Kubernetes checks the "liveness" Probe and restarts the application if it takes too long.spring-doc.cn
Startedspring-doc.cn
CORRECTspring-doc.cn
Refuses requestsspring-doc.cn
The application context is refreshed. The application performs startup tasks and does not receive traffic yet.spring-doc.cn
Readyspring-doc.cn
ACCEPTING_TRAFFICspring-doc.cn
Accepts requestsspring-doc.cn
Startup tasks are finished. The application is receiving traffic.spring-doc.cn
When a Spring Boot application shuts down:spring-doc.cn
Shutdown phase Liveness State Readiness State HTTP server Notes
Runningspring-doc.cn
Shutdown has been requested.spring-doc.cn
Graceful shutdownspring-doc.cn
New requests are rejectedspring-doc.cn
If enabled, graceful shutdown processes in-flight requests.spring-doc.cn
Shutdown completespring-doc.cn
N/Aspring-doc.cn
N/Aspring-doc.cn
Server is shut downspring-doc.cn
The application context is closed and the application is shut down.spring-doc.cn
See Kubernetes Container Lifecycle for more information about Kubernetes deployment.
Application Information
Application information exposes various information collected from all InfoContributor beans defined in your ApplicationContext. Spring Boot includes a number of auto-configured InfoContributor beans, and you can write your own.spring-doc.cn
Auto-configured InfoContributors
When appropriate, Spring auto-configures the following InfoContributor beans:spring-doc.cn
ID Name Description Prerequisites
buildspring-doc.cn
BuildInfoContributorspring-doc.cn
Exposes build information.spring-doc.cn
A META-INF/build-info.properties resource.spring-doc.cn
envspring-doc.cn
EnvironmentInfoContributorspring-doc.cn
Exposes any property from the Environment whose name starts with info..spring-doc.cn
None.spring-doc.cn
gitspring-doc.cn
GitInfoContributorspring-doc.cn
Exposes git information.spring-doc.cn
A git.properties resource.spring-doc.cn
javaspring-doc.cn
JavaInfoContributorspring-doc.cn
Exposes Java runtime information.spring-doc.cn
None.spring-doc.cn
osspring-doc.cn
OsInfoContributorspring-doc.cn
Exposes Operating System information.spring-doc.cn
None.spring-doc.cn
processspring-doc.cn
ProcessInfoContributorspring-doc.cn
Exposes process information.spring-doc.cn
None.spring-doc.cn
sslspring-doc.cn
SslInfoContributorspring-doc.cn
Exposes SSL certificate information.spring-doc.cn
An SSL Bundle configured.spring-doc.cn
Whether an individual contributor is enabled is controlled by its management.info.<id>.enabled property. Different contributors have different defaults for this property, depending on their prerequisites and the nature of the information that they expose.spring-doc.cn
With no prerequisites to indicate that they should be enabled, the env, java, os, and process contributors are disabled by default. The ssl contributor has a prerequisite of having an SSL Bundle configured but it is disabled by default. Each can be enabled by setting its management.info.<id>.enabled property to true.spring-doc.cn
The build and git info contributors are enabled by default. Each can be disabled by setting its management.info.<id>.enabled property to false. Alternatively, to disable every contributor that is usually enabled by default, set the management.info.defaults.enabled property to false.spring-doc.cn
Custom Application Information
When the env contributor is enabled, you can customize the data exposed by the info endpoint by setting info.* Spring properties. All Environment properties under the info key are automatically exposed. For example, you could add the following settings to your application.properties file:spring-doc.cn
info.app.encoding=UTF-8
info.app.java.source=17
info.app.java.target=17
info:
  app:
    encoding: "UTF-8"
    java:
      source: "17"
      target: "17"
Rather than hardcoding those values, you could also expand info properties at build time.spring-doc.cn
Assuming you use Maven, you could rewrite the preceding example as follows:spring-doc.cn
info:
  app:
    encoding: "@project.build.sourceEncoding@"
    java:
      source: "@java.version@"
      target: "@java.version@"
Git Commit Information
Another useful feature of the info endpoint is its ability to publish information about the state of your git source code repository when the project was built. If a GitProperties bean is available, you can use the info endpoint to expose these properties.spring-doc.cn
A GitProperties bean is auto-configured if a git.properties file is available at the root of the classpath. See Generate Git Information for more detail.
By default, the endpoint exposes git.branch, git.commit.id, and git.commit.time properties, if present. If you do not want any of these properties in the endpoint response, they need to be excluded from the git.properties file. If you want to display the full git information (that is, the full content of git.properties), use the management.info.git.mode property, as follows:spring-doc.cn
management.info.git.mode=full
management:
  info:
    git:
      mode: "full"
To disable the git commit information from the info endpoint completely, set the management.info.git.enabled property to false, as follows:spring-doc.cn
management.info.git.enabled=false
management:
  info:
    git:
      enabled: false
Build Information
If a BuildProperties bean is available, the info endpoint can also publish information about your build. This happens if a META-INF/build-info.properties file is available in the classpath.spring-doc.cn
The Maven and Gradle plugins can both generate that file. See Generate Build Information for more details.
Java Information
The info endpoint publishes information about your Java runtime environment, see JavaInfo for more details.spring-doc.cn
OS Information
The info endpoint publishes information about your Operating System, see OsInfo for more details.spring-doc.cn
Process Information
The info endpoint publishes information about your process, see ProcessInfo for more details.spring-doc.cn
SSL Information
The info endpoint publishes information about your SSL certificates (that are configured through SSL Bundles), see SslInfo for more details. This endpoint reuses the "warning threshold" property of SslHealthIndicator: if an SSL certificate will be invalid within the time span defined by this threshold, it will trigger a warning. See the management.health.ssl.certificate-validity-warning-threshold property.spring-doc.cn
Writing Custom InfoContributors
To provide custom application information, you can register Spring beans that implement the InfoContributor interface.spring-doc.cn
The following example contributes an example entry with a single value:spring-doc.cn
import java.util.Collections;
import org.springframework.boot.actuate.info.Info;
import org.springframework.boot.actuate.info.InfoContributor;
@Component
public class MyInfoContributor implements InfoContributor {
	public void contribute(Info.Builder builder) {
		builder.withDetail("example", Collections.singletonMap("key", "value"));
@Component
class MyInfoContributor : InfoContributor {
	override fun contribute(builder: Info.Builder) {
If you reach the info endpoint, you should see a response that contains the following additional entry:spring-doc.cn
	"example": {
		"key" : "value"
Software Bill of Materials (SBOM)
The sbom endpoint exposes the Software Bill of Materials. CycloneDX SBOMs can be auto-detected, but other formats can be manually configured, too.spring-doc.cn
The sbom actuator endpoint will then expose an SBOM called "application", which describes the contents of your application.spring-doc.cn
To automatically generate a CycloneDX SBOM at project build time, please see the Generate a CycloneDX SBOM section.
Other SBOM formats
If you want to publish an SBOM in a different format, there are some configuration properties which you can use.spring-doc.cn
The configuration property management.endpoint.sbom.application.location sets the location for the application SBOM. For example, setting this to classpath:sbom.json will use the contents of the /sbom.json resource on the classpath.spring-doc.cn
The media type for SBOMs in CycloneDX, SPDX and Syft format is detected automatically. To override the auto-detected media type, use the configuration property management.endpoint.sbom.application.media-type.spring-doc.cn
Additional SBOMs
The actuator endpoint can handle multiple SBOMs. To add SBOMs, use the configuration property management.endpoint.sbom.additional, as shown in this example:spring-doc.cn
management.endpoint.sbom.additional.system.location=optional:file:/system.spdx.json
management.endpoint.sbom.additional.system.media-type=application/spdx+json
management:
  endpoint:
    sbom:
      additional:
        system:
          media-type: "application/spdx+json"
This will add an SBOM called "system", which is stored in /system.spdx.json. The optional: prefix can be used to prevent a startup failure if the file doesn’t exist.spring-doc.cn
