Liquibase (liquibase
The liquibase
endpoint provides information about database change sets applied by Liquibase.
Retrieving the Changes
To retrieve the changes, make a GET
request to /actuator/liquibase
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/liquibase' -i -X GET
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 721
"contexts" : {
"application" : {
"liquibaseBeans" : {
"liquibase" : {
"changeSets" : [ {
"author" : "marceloverdijk",
"changeLog" : "org/springframework/boot/actuate/autoconfigure/liquibase/db.changelog-master.yaml",
"comments" : "",
"contexts" : [ ],
"dateExecuted" : "2025-04-24T12:37:58.146Z",
"deploymentId" : "5498278061",
"description" : "createTable tableName=customer",
"execType" : "EXECUTED",
"id" : "1",
"labels" : [ ],
"checksum" : "9:d3589feb2baad02e15540750499ba311",
"orderExecuted" : 1
Response Structure
The response contains details of the application’s Liquibase change sets. The following table describes the structure of the response:
Path | Type | Description |
Application contexts keyed by id |
Change sets made by the Liquibase beans, keyed by bean name. |
Author of the change set. |
Change log that contains the change set. |
Comments on the change set. |
Contexts of the change set. |
Timestamp of when the change set was executed. |
ID of the deployment that ran the change set. |
Description of the change set. |
Execution type of the change set ( |
ID of the change set. |
Labels associated with the change set. |
Checksum of the change set. |
Order of the execution of the change set. |
Tag associated with the change set, if any. |
Id of the parent application context, if any. |
