Sessions (sessions
The sessions
endpoint provides information about the application’s HTTP sessions that are managed by Spring Session.
Retrieving Sessions
To retrieve the sessions, make a GET
request to /actuator/sessions
, as shown in the following curl-based example:
$ curl 'http://localhost:8080/actuator/sessions?username=alice' -i -X GET
The preceding examples retrieves all of the sessions for the user whose username is alice
The resulting response is similar to the following:
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 789
"sessions" : [ {
"id" : "d6b7fc0b-5ca0-4e02-ab58-7654880bd9d7",
"attributeNames" : [ ],
"creationTime" : "2025-04-24T10:38:11.050570727Z",
"lastAccessedTime" : "2025-04-24T12:37:59.050571418Z",
"maxInactiveInterval" : 1800,
"expired" : false
"id" : "4db5efcc-99cb-4d05-a52c-b49acfbb7ea9",
"creationTime" : "2025-04-24T07:38:11.050565207Z",
"lastAccessedTime" : "2025-04-24T12:37:34.050567972Z",
"expired" : false
"id" : "38e90293-983f-42fa-b150-ef04f56ecd20",
"creationTime" : "2025-04-24T00:38:11.049601420Z",
"lastAccessedTime" : "2025-04-24T12:37:26.049607511Z",
"expired" : false
Query Parameters
The endpoint uses query parameters to limit the sessions that it returns. The following table shows the single required query parameter:
Parameter | Description |
Name of the user. |
Response Structure
The response contains details of the matching sessions. The following table describes the structure of the response:
Path | Type | Description |
Sessions for the given username. |
ID of the session. |
Names of the attributes stored in the session. |
Timestamp of when the session was created. |
Timestamp of when the session was last accessed. |
Maximum permitted period of inactivity, in seconds, before the session will expire. |
Whether the session has expired. |
Retrieving a Single Session
To retrieve a single session, make a GET
request to /actuator/sessions/{id}
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X GET
The preceding example retrieves the session with the id
of 4db5efcc-99cb-4d05-a52c-b49acfbb7ea9
HTTP/1.1 200 OK
Content-Length: 208
{"id":"4db5efcc-99cb-4d05-a52c-b49acfbb7ea9","attributeNames":[],"creationTime":"2025-04-24T07:38:11.050565207Z","lastAccessedTime":"2025-04-24T12:37:34.050567972Z","maxInactiveInterval":1800,"expired":false}
Response Structure
The response contains details of the requested session. The following table describes the structure of the response:
Deleting a Session
To delete a session, make a DELETE
$ curl 'http://localhost:8080/actuator/sessions/4db5efcc-99cb-4d05-a52c-b49acfbb7ea9' -i -X DELETE
The preceding example deletes the session with the id
