Getting Started
To get started with the plugin it needs to be applied to your project.spring-doc.cn
The plugin is published to Gradle’s plugin portal and can be applied using the plugins block:spring-doc.cn
plugins {
	id 'org.springframework.boot' version '3.4.5'
plugins {
	id("org.springframework.boot") version "3.4.5"
Applied in isolation the plugin makes few changes to a project. Instead, the plugin detects when certain other plugins are applied and reacts accordingly. For example, when the java plugin is applied a task for building an executable jar is automatically configured. A typical Spring Boot project will apply the groovy, java, or org.jetbrains.kotlin.jvm plugin as a minimum and also use the io.spring.dependency-management plugin or Gradle’s native bom support for dependency management. For example:spring-doc.cn
plugins {
	id 'java'
apply plugin: 'io.spring.dependency-management'
plugins {
	java
apply(plugin = "io.spring.dependency-management")
To learn more about how the Spring Boot plugin behaves when other plugins are applied please see the section on reacting to other plugins.spring-doc.cn
