Integrating with Actuator
Spring Boot Actuator displays build-related information if a META-INF/build-info.properties
file is present.
The build-info
goal generates such file with the coordinates of the project and the build time.
It also allows you to add an arbitrary number of additional properties, as shown in the following example:
<project>
<modelVersion>4.0.0</modelVersion>
<artifactId>build-info</artifactId>
<build>
<plugins>
<plugin>
<executions>
<execution>
<goals>
<goal>build-info</goal>
</goals>
<configuration>
<additionalProperties>
<encoding.source>UTF-8</encoding.source>
<encoding.reporting>UTF-8</encoding.reporting>
<java.version>${java.version}</java.version>
</additionalProperties>
</configuration>
</execution>
</executions>
</plugin>
</plugins>
</build>
</project>
This configuration will generate a build-info.properties
at the expected location with three additional keys.
java.version is expected to be a regular property available in the project.
It will be interpolated as you would expect.
spring-boot:build-info
org.springframework.boot:spring-boot-maven-plugin:3.4.5
Generate a build-info.properties
file based on the content of the current MavenProject
Optional parameters
Name | Type | Default |
Parameter details
Additional properties to store in the build-info.properties
file. Each entry is prefixed by build.
in the generated build-info.properties
Name |
Type |
Default value |
User property |
Since |
excludeInfoProperties
Properties that should be excluded build-info.properties
file. Can be used to exclude the standard group
, artifact
, name
, version
or time
properties as well as items from additionalProperties
Name |
Type |
Default value |
User property |
Since |
outputFile
The location of the generated build-info.properties
file.
Name |
Type |
Default value |
User property |
Since |
skip
Skip the execution.
Name |
Type |
Default value |
User property |
Since |
time
The value used for the build.time
property in a form suitable for Instant#parse(CharSequence)
. Defaults to project.build.outputTimestamp
or session.request.startTime
if the former is not set. To disable the build.time
property entirely, use 'off'
or add it to excludeInfoProperties
Name |
Type |
Default value |
User property |
Since |
