映射 (mappings)
mappingsendpoint 提供有关应用程序的请求映射的信息。spring-doc.cadn.net.cn
检索映射
要检索映射,请创建一个GETrequest 添加到/actuator/mappings,如以下基于 curl 的示例所示:spring-doc.cadn.net.cn
$ curl 'http://localhost:40287/actuator/mappings' -i -X GET \
    -H 'accept-encoding: gzip' \
    -H 'user-agent: ReactorNetty/1.2.5' \
    -H 'accept: */*'
生成的响应类似于以下内容:spring-doc.cadn.net.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Transfer-Encoding: chunked
Date: Thu, 24 Apr 2025 12:38:22 GMT
Content-Length: 5314
  "contexts" : {
    "application" : {
      "mappings" : {
        "dispatcherServlets" : {
          "dispatcherServlet" : [ {
            "handler" : "Actuator root web endpoint",
            "predicate" : "{GET [/actuator], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
            "details" : {
              "handlerMethod" : {
                "className" : "org.springframework.boot.actuate.endpoint.web.servlet.WebMvcEndpointHandlerMapping.WebMvcLinksHandler",
                "name" : "links",
                "descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljakarta/servlet/http/HttpServletResponse;)Ljava/util/Map;"
              "requestMappingConditions" : {
                "consumes" : [ ],
                "headers" : [ ],
                "methods" : [ "GET" ],
                "params" : [ ],
                "patterns" : [ "/actuator" ],
                "produces" : [ {
                  "mediaType" : "application/vnd.spring-boot.actuator.v3+json",
                  "negated" : false
                  "mediaType" : "application/vnd.spring-boot.actuator.v2+json",
                  "negated" : false
                  "mediaType" : "application/json",
                  "negated" : false
            "handler" : "Actuator web endpoint 'mappings'",
            "predicate" : "{GET [/actuator/mappings], produces [application/vnd.spring-boot.actuator.v3+json || application/vnd.spring-boot.actuator.v2+json || application/json]}",
            "details" : {
              "handlerMethod" : {
                "className" : "org.springframework.boot.actuate.endpoint.web.servlet.AbstractWebMvcEndpointHandlerMapping.OperationHandler",
                "name" : "handle",
                "descriptor" : "(Ljakarta/servlet/http/HttpServletRequest;Ljava/util/Map;)Ljava/lang/Object;"
                "consumes" : [ ],
                "headers" : [ ],
                "params" : [ ],
                "patterns" : [ "/actuator/mappings" ],
                "produces" : [ {
                  "negated" : false
                  "negated" : false
                  "negated" : false
            "handler" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests$ExampleController#example()",
            "predicate" : "{POST [/], params [a!=alpha], headers [X-Custom=Foo], consumes [application/json || !application/xml], produces [text/plain]}",
            "details" : {
              "handlerMethod" : {
                "className" : "org.springframework.boot.actuate.autoconfigure.web.mappings.MappingsEndpointServletDocumentationTests.ExampleController",
                "name" : "example",
                "descriptor" : "()Ljava/lang/String;"
                "consumes" : [ {
                  "negated" : false
                  "mediaType" : "application/xml",
                  "negated" : true
                "headers" : [ {
                  "name" : "X-Custom",
                  "value" : "Foo",
                  "negated" : false
                "methods" : [ "POST" ],
                "params" : [ {
                  "name" : "a",
                  "value" : "alpha",
                  "negated" : true
                "patterns" : [ "/" ],
                "produces" : [ {
                  "mediaType" : "text/plain",
                  "negated" : false
            "handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/webjars/]]",
            "predicate" : "/webjars/**"
            "handler" : "ResourceHttpRequestHandler [classpath [META-INF/resources/], classpath [resources/], classpath [static/], classpath [public/], ServletContext [/]]",
            "predicate" : "/**"
        "servletFilters" : [ {
          "servletNameMappings" : [ ],
          "urlPatternMappings" : [ "/*" ],
          "name" : "requestContextFilter",
          "className" : "org.springframework.boot.web.servlet.filter.OrderedRequestContextFilter"
          "name" : "formContentFilter",
          "className" : "org.springframework.boot.web.servlet.filter.OrderedFormContentFilter"
        "servlets" : [ {
          "mappings" : [ "/" ],
          "name" : "dispatcherServlet",
          "className" : "org.springframework.web.servlet.DispatcherServlet"
响应结构
响应包含应用程序映射的详细信息。 在响应中找到的项目取决于 Web 应用程序的类型(响应式或基于 Servlet)。 下表描述了响应的常见元素的结构:spring-doc.cadn.net.cn
路径 类型 描述
contextsspring-doc.cadn.net.cn
Objectspring-doc.cadn.net.cn
以 id 为键的应用程序上下文。spring-doc.cadn.net.cn
contexts.*.mappingsspring-doc.cadn.net.cn
上下文中的映射,按 mapping type 键控。spring-doc.cadn.net.cn
contexts.*.mappings.dispatcherServletsspring-doc.cadn.net.cn
Dispatcher Servlet 映射(如果有)。spring-doc.cadn.net.cn
contexts.*.mappings.servletFiltersspring-doc.cadn.net.cn
Arrayspring-doc.cadn.net.cn
Servlet 过滤器映射(如果有)。spring-doc.cadn.net.cn
contexts.*.mappings.servletsspring-doc.cadn.net.cn
contexts.*.mappings.dispatcherHandlersspring-doc.cadn.net.cn
Dispatcher 处理程序映射(如果有)。spring-doc.cadn.net.cn
contexts.*.parentIdspring-doc.cadn.net.cn
Stringspring-doc.cadn.net.cn
父应用程序上下文的 ID(如果有)。spring-doc.cadn.net.cn
可以在contexts.*.mappings在以下各节中进行了介绍。spring-doc.cadn.net.cn
Dispatcher Servlet 响应结构
使用 Spring MVC 时,响应包含任何DispatcherServlet请求映射contexts.*.mappings.dispatcherServlets. 下表描述了响应的这一部分的结构:spring-doc.cadn.net.cn
路径 类型 描述
*spring-doc.cadn.net.cn
Dispatcher Servlet 映射(如果有),按 Dispatcher Servlet Bean 名称进行键控。spring-doc.cadn.net.cn
*.[].detailsspring-doc.cadn.net.cn
有关映射的其他特定于实现的详细信息。自选。spring-doc.cadn.net.cn
*.[].handlerspring-doc.cadn.net.cn
映射的处理程序。spring-doc.cadn.net.cn
*.[].predicatespring-doc.cadn.net.cn
映射的谓词。spring-doc.cadn.net.cn
*.[].details.handlerMethodspring-doc.cadn.net.cn
将处理对此映射的请求的方法(如果有)的详细信息。spring-doc.cadn.net.cn
*.[].details.handlerMethod.classNamespring-doc.cadn.net.cn
Variesspring-doc.cadn.net.cn
方法类的完全限定名称。spring-doc.cadn.net.cn
*.[].details.handlerMethod.namespring-doc.cadn.net.cn
方法的名称。spring-doc.cadn.net.cn
*.[].details.handlerMethod.descriptorspring-doc.cadn.net.cn
Java 语言规范中指定的方法的描述符。spring-doc.cadn.net.cn
*.[].details.requestMappingConditionsspring-doc.cadn.net.cn
请求映射条件的详细信息。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.consumesspring-doc.cadn.net.cn
consumes 条件的详细信息spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.consumes.[].mediaTypespring-doc.cadn.net.cn
使用的媒体类型。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.consumes.[].negatedspring-doc.cadn.net.cn
媒体类型是否为否定。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.headersspring-doc.cadn.net.cn
headers 条件的详细信息。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.headers.[].namespring-doc.cadn.net.cn
标头的名称。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.headers.[].valuespring-doc.cadn.net.cn
标头的必需值(如果有)。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.headers.[].negatedspring-doc.cadn.net.cn
该值是否为反值。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.methodsspring-doc.cadn.net.cn
已处理的 HTTP 方法。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.paramsspring-doc.cadn.net.cn
params 条件的详细信息。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.params.[].namespring-doc.cadn.net.cn
参数的名称。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.params.[].valuespring-doc.cadn.net.cn
参数的必需值(如果有)。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.params.[].negatedspring-doc.cadn.net.cn
*.[].details.requestMappingConditions.patternsspring-doc.cadn.net.cn
标识映射处理的路径的模式。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.producesspring-doc.cadn.net.cn
produce 条件的详细信息。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.produces.[].mediaTypespring-doc.cadn.net.cn
生成的媒体类型。spring-doc.cadn.net.cn
*.[].details.requestMappingConditions.produces.[].negatedspring-doc.cadn.net.cn
Servlet 响应结构
使用 Servlet 堆栈时,响应包含任何Servlet映射contexts.*.mappings.servlets. 下表描述了响应的这一部分的结构:spring-doc.cadn.net.cn
路径 类型 描述
[].mappingsspring-doc.cadn.net.cn
Servlet 的映射。spring-doc.cadn.net.cn
Servlet 的名称。spring-doc.cadn.net.cn
[].classNamespring-doc.cadn.net.cn
Servlet 的类名spring-doc.cadn.net.cn
Servlet 过滤器响应结构
使用 Servlet 堆栈时,响应包含任何Filter映射contexts.*.mappings.servletFilters. 下表描述了响应的这一部分的结构:spring-doc.cadn.net.cn
路径 类型 描述
[].servletNameMappingsspring-doc.cadn.net.cn
过滤器映射到的 Servlet 的名称。spring-doc.cadn.net.cn
[].urlPatternMappingsspring-doc.cadn.net.cn
过滤器映射到的 URL 模式。spring-doc.cadn.net.cn
筛选器的名称。spring-doc.cadn.net.cn
过滤器的类名spring-doc.cadn.net.cn
Dispatcher 处理程序响应结构
使用 Spring WebFlux 时,响应包含任何DispatcherHandler请求映射contexts.*.mappings.dispatcherHandlers. 下表描述了响应的这一部分的结构:spring-doc.cadn.net.cn
路径 类型 描述
调度程序处理程序映射(如果有),以调度程序处理程序 Bean 名称为键。spring-doc.cadn.net.cn
*.[].details.handlerFunctionspring-doc.cadn.net.cn
将处理对此映射的请求的函数(如果有)的详细信息。spring-doc.cadn.net.cn
*.[].details.handlerFunction.classNamespring-doc.cadn.net.cn
函数类的完全限定名称。spring-doc.cadn.net.cn
