MCP Server Boot Starter
The Spring AI MCP (Model Context Protocol) Server Boot Starter provides auto-configuration for setting up an MCP server in Spring Boot applications. It enables seamless integration of MCP server capabilities with Spring Boot’s auto-configuration system.spring-doc.cn
The MCP Server Boot Starter offers:spring-doc.cn
Starters
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Choose one of the following starters based on your transport requirements:spring-doc.cn
Standard MCP Server
Full MCP Server features support with STDIO server transport.spring-doc.cn
<dependency>
    <artifactId>spring-ai-mcp-server-spring-boot-starter</artifactId>
</dependency>
The starter activates the McpServerAutoConfiguration auto-configuration responsible for:spring-doc.cn
WebMVC Server Transport
Full MCP Server features support with SSE (Server-Sent Events) server transport based on Spring MVC and an optional STDIO transport.spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-mcp-server-webmvc</artifactId>
</dependency>
The starter activates the McpWebMvcServerAutoConfiguration and McpServerAutoConfiguration auto-configurations to provide:spring-doc.cn
  • HTTP-based transport using Spring MVC (WebMvcSseServerTransportProvider)spring-doc.cn
  • Automatically configured SSE endpointsspring-doc.cn
  • Optional STDIO transport (enabled by setting spring.ai.mcp.server.stdio=true)spring-doc.cn
  • Included spring-boot-starter-web and mcp-spring-webmvc dependenciesspring-doc.cn
WebFlux Server Transport
Full MCP Server features support with SSE (Server-Sent Events) server transport based on Spring WebFlux and an optional STDIO transport.spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-mcp-server-webflux</artifactId>
</dependency>
The starter activates the McpWebFluxServerAutoConfiguration and McpServerAutoConfiguration auto-configurations to provide:spring-doc.cn
  • Reactive transport using Spring WebFlux (WebFluxSseServerTransportProvider)spring-doc.cn
  • Automatically configured reactive SSE endpointsspring-doc.cn
  • Included spring-boot-starter-webflux and mcp-spring-webflux dependenciesspring-doc.cn
Configuration Properties
All properties are prefixed with spring.ai.mcp.server:spring-doc.cn
Property Description Default
enabledspring-doc.cn
Enable/disable the MCP serverspring-doc.cn
truespring-doc.cn
stdiospring-doc.cn
Enable/disable stdio transportspring-doc.cn
falsespring-doc.cn
namespring-doc.cn
Server name for identificationspring-doc.cn
mcp-serverspring-doc.cn
versionspring-doc.cn
Server versionspring-doc.cn
1.0.0spring-doc.cn
typespring-doc.cn
Server type (SYNC/ASYNC)spring-doc.cn
SYNCspring-doc.cn
resource-change-notificationspring-doc.cn
Enable resource change notificationsspring-doc.cn
truespring-doc.cn
prompt-change-notificationspring-doc.cn
Enable prompt change notificationsspring-doc.cn
truespring-doc.cn
tool-change-notificationspring-doc.cn
Enable tool change notificationsspring-doc.cn
truespring-doc.cn
tool-response-mime-typespring-doc.cn
(optional) response MIME type per tool name. For example spring.ai.mcp.server.tool-response-mime-type.generateImage=image/png will associate the image/png mime type with the generateImage() tool namespring-doc.cn
-spring-doc.cn
sse-message-endpointspring-doc.cn
Custom SSE Message endpoint path for web transport to be used by the client to send messagesspring-doc.cn
/mcp/messagespring-doc.cn
sse-endpointspring-doc.cn
Custom SSE endpoint path for web transportspring-doc.cn
/ssespring-doc.cn
base-urlspring-doc.cn
Optional URL prefix. For example base-url=/api/v1 means that the client should access the sse endpont at /api/v1 + sse-endpoint and the message endpoint is /api/v1 + sse-message-endpointspring-doc.cn
-spring-doc.cn
Sync/Async Server Types
  • Synchronous Server - The default server type implemented using McpSyncServer. It is designed for straightforward request-response patterns in your applications. To enable this server type, set spring.ai.mcp.server.type=SYNC in your configuration. When activated, it automatically handles the configuration of synchronous tool specifications.spring-doc.cn
  • Asynchronous Server - The asynchronous server implementation uses McpAsyncServer and is optimized for non-blocking operations. To enable this server type, configure your application with spring.ai.mcp.server.type=ASYNC. This server type automatically sets up asynchronous tool specifications with built-in Project Reactor support.spring-doc.cn
Transport Options
The MCP Server supports three transport mechanisms, each with its dedicated starter:spring-doc.cn
  • Standard Input/Output (STDIO) - spring-ai-starter-mcp-serverspring-doc.cn
  • Spring MVC (Server-Sent Events) - spring-ai-starter-mcp-server-webmvcspring-doc.cn
  • Spring WebFlux (Reactive SSE) - spring-ai-starter-mcp-server-webfluxspring-doc.cn
Features and Capabilities
The MCP Server Boot Starter allows servers to expose tools, resources, and prompts to clients. It automatically converts custom capability handlers registered as Spring beans to sync/async specifications based on server type:spring-doc.cn
Tools
Allows servers to expose tools that can be invoked by language models. The MCP Server Boot Starter provides:spring-doc.cn
  • Change notification supportspring-doc.cn
  • Tools are automatically converted to sync/async specifications based on server typespring-doc.cn
  • Automatic tool specification through Spring beans:spring-doc.cn
public ToolCallbackProvider myTools(...) {
    List<ToolCallback> tools = ...
    return ToolCallbackProvider.from(tools);
or using the low-level API:spring-doc.cn
public List<McpServerFeatures.SyncToolSpecification> myTools(...) {
    List<McpServerFeatures.SyncToolSpecification> tools = ...
    return tools;
Resource Management
Provides a standardized way for servers to expose resources to clients.spring-doc.cn
public List<McpServerFeatures.SyncResourceSpecification> myResources(...) {
    var systemInfoResource = new McpSchema.Resource(...);
    var resourceSpecification = new McpServerFeatures.SyncResourceSpecification(systemInfoResource, (exchange, request) -> {
        try {
            var systemInfo = Map.of(...);
            String jsonContent = new ObjectMapper().writeValueAsString(systemInfo);
            return new McpSchema.ReadResourceResult(
                    List.of(new McpSchema.TextResourceContents(request.uri(), "application/json", jsonContent)));
        catch (Exception e) {
            throw new RuntimeException("Failed to generate system info", e);
    return List.of(resourceSpecification);
Prompt Management
Provides a standardized way for servers to expose prompt templates to clients.spring-doc.cn
public List<McpServerFeatures.SyncPromptSpecification> myPrompts() {
    var prompt = new McpSchema.Prompt("greeting", "A friendly greeting prompt",
        List.of(new McpSchema.PromptArgument("name", "The name to greet", true)));
    var promptSpecification = new McpServerFeatures.SyncPromptSpecification(prompt, (exchange, getPromptRequest) -> {
        String nameArgument = (String) getPromptRequest.arguments().get("name");
        if (nameArgument == null) { nameArgument = "friend"; }
        var userMessage = new PromptMessage(Role.USER, new TextContent("Hello " + nameArgument + "! How can I assist you today?"));
        return new GetPromptResult("A personalized greeting message", List.of(userMessage));
    return List.of(promptSpecification);
Root Change Consumers
When roots change, clients that support listChanged send a Root Change notification.spring-doc.cn
public BiConsumer<McpSyncServerExchange, List<McpSchema.Root>> rootsChangeHandler() {
    return (exchange, roots) -> {
        logger.info("Registering root resources: {}", roots);
Usage Examples
Standard STDIO Server Configuration
# Using spring-ai-starter-mcp-server
spring:
  ai:
    mcp:
      server:
        version: 1.0.0
        type: SYNC
WebMVC Server Configuration
# Using spring-ai-starter-mcp-server-webmvc
spring:
  ai:
    mcp:
      server:
        version: 1.0.0
        type: SYNC
        sse-message-endpoint: /mcp/messages
WebFlux Server Configuration
# Using spring-ai-starter-mcp-server-webflux
spring:
  ai:
    mcp:
      server:
        version: 1.0.0
        type: ASYNC  # Recommended for reactive applications
Creating a Spring Boot Application with MCP Server
@Service
public class WeatherService {
    @Tool(description = "Get weather information by city name")
    public String getWeather(String cityName) {
        // Implementation
@SpringBootApplication
public class McpServerApplication {
    private static final Logger logger = LoggerFactory.getLogger(McpServerApplication.class);
        SpringApplication.run(McpServerApplication.class, args);
	public ToolCallbackProvider weatherTools(WeatherService weatherService) {
		return MethodToolCallbackProvider.builder().toolObjects(weatherService).build();
The auto-configuration will automatically register the tool callbacks as MCP tools. You can have multiple beans producing ToolCallbacks. The auto-configuration will merge them.spring-doc.cn
Example Applications
