MariaDB Vector Store
This section walks you through setting up MariaDBVectorStore to store document embeddings and perform similarity searches.spring-doc.cn
MariaDB Vector is part of MariaDB 11.7 and enables storing and searching over machine learning-generated embeddings. It provides efficient vector similarity search capabilities using vector indexes, supporting both cosine similarity and Euclidean distance metrics.spring-doc.cn
Prerequisites
Auto-Configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Spring AI provides Spring Boot auto-configuration for the MariaDB Vector Store. To enable it, add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-vector-store-mariadb</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-vector-store-mariadb'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
The vector store implementation can initialize the required schema for you, but you must opt-in by specifying the initializeSchema boolean in the appropriate constructor or by setting …​initialize-schema=true in the application.properties file.spring-doc.cn
This is a breaking change! In earlier versions of Spring AI, this schema initialization happened by default.
Additionally, you will need a configured EmbeddingModel bean. Refer to the EmbeddingModel section for more information.spring-doc.cn
For example, to use the OpenAI EmbeddingModel, add the following dependency:spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-model-openai</artifactId>
</dependency>
Refer to the Artifact Repositories section to add Maven Central and/or Snapshot Repositories to your build file.
Now you can auto-wire the MariaDBVectorStore in your application:spring-doc.cn
@Autowired VectorStore vectorStore;
List<Document> documents = List.of(
    new Document("Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!!", Map.of("meta1", "meta1")),
    new Document("The World is Big and Salvation Lurks Around the Corner"),
    new Document("You walk forward facing the past and you turn back toward the future.", Map.of("meta2", "meta2")));
// Add the documents to MariaDB
vectorStore.add(documents);
// Retrieve documents similar to a query
List<Document> results = vectorStore.similaritySearch(SearchRequest.builder().query("Spring").topK(5).build());
Configuration Properties
To connect to MariaDB and use the MariaDBVectorStore, you need to provide access details for your instance. A simple configuration can be provided via Spring Boot’s application.yml:spring-doc.cn
spring:
  datasource:
    url: jdbc:mariadb://localhost/db
    username: myUser
    password: myPassword
  ai:
    vectorstore:
      mariadb:
        initialize-schema: true
        distance-type: COSINE
        dimensions: 1536
If you run MariaDB Vector as a Spring Boot dev service via Docker Compose or Testcontainers, you don’t need to configure URL, username and password since they are autoconfigured by Spring Boot.
Properties starting with spring.ai.vectorstore.mariadb.* are used to configure the MariaDBVectorStore:spring-doc.cn
Property Description Default Value
spring.ai.vectorstore.mariadb.initialize-schemaspring-doc.cn
Whether to initialize the required schemaspring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.mariadb.distance-typespring-doc.cn
Search distance type. Use COSINE (default) or EUCLIDEAN. If vectors are normalized to length 1, you can use EUCLIDEAN for best performance.spring-doc.cn
COSINEspring-doc.cn
spring.ai.vectorstore.mariadb.dimensionsspring-doc.cn
Embeddings dimension. If not specified explicitly, will retrieve dimensions from the provided EmbeddingModel.spring-doc.cn
1536spring-doc.cn
spring.ai.vectorstore.mariadb.remove-existing-vector-store-tablespring-doc.cn
Deletes the existing vector store table on startup.spring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.mariadb.schema-namespring-doc.cn
Vector store schema namespring-doc.cn
nullspring-doc.cn
spring.ai.vectorstore.mariadb.table-namespring-doc.cn
Vector store table namespring-doc.cn
vector_storespring-doc.cn
spring.ai.vectorstore.mariadb.schema-validationspring-doc.cn
Enables schema and table name validation to ensure they are valid and existing objects.spring-doc.cn
falsespring-doc.cn
If you configure a custom schema and/or table name, consider enabling schema validation by setting spring.ai.vectorstore.mariadb.schema-validation=true. This ensures the correctness of the names and reduces the risk of SQL injection attacks.
Manual Configuration
Instead of using the Spring Boot auto-configuration, you can manually configure the MariaDB vector store. For this you need to add the following dependencies to your project:spring-doc.cn
<dependency>
    <artifactId>spring-boot-starter-jdbc</artifactId>
</dependency>
<dependency>
    <groupId>org.mariadb.jdbc</groupId>
    <artifactId>mariadb-java-client</artifactId>
    <scope>runtime</scope>
</dependency>
<dependency>
    <artifactId>spring-ai-mariadb-store</artifactId>
</dependency>
Then create the MariaDBVectorStore bean using the builder pattern:spring-doc.cn
public VectorStore vectorStore(JdbcTemplate jdbcTemplate, EmbeddingModel embeddingModel) {
    return MariaDBVectorStore.builder(jdbcTemplate, embeddingModel)
        .dimensions(1536)                      // Optional: defaults to 1536
        .distanceType(MariaDBDistanceType.COSINE) // Optional: defaults to COSINE
        .schemaName("mydb")                    // Optional: defaults to null
        .vectorTableName("custom_vectors")     // Optional: defaults to "vector_store"
        .contentFieldName("text")             // Optional: defaults to "content"
        .embeddingFieldName("embedding")      // Optional: defaults to "embedding"
        .idFieldName("doc_id")                // Optional: defaults to "id"
        .metadataFieldName("meta")           // Optional: defaults to "metadata"
        .initializeSchema(true)               // Optional: defaults to false
        .schemaValidation(true)              // Optional: defaults to false
        .removeExistingVectorStoreTable(false) // Optional: defaults to false
        .maxDocumentBatchSize(10000)         // Optional: defaults to 10000
// This can be any EmbeddingModel implementation
public EmbeddingModel embeddingModel() {
    return new OpenAiEmbeddingModel(new OpenAiApi(System.getenv("OPENAI_API_KEY")));
Metadata Filtering
You can leverage the generic, portable metadata filters with MariaDB Vector store.spring-doc.cn
For example, you can use either the text expression language:spring-doc.cn
        .query("The World")
        .topK(TOP_K)
        .similarityThreshold(SIMILARITY_THRESHOLD)
        .filterExpression("author in ['john', 'jill'] && article_type == 'blog'").build());
or programmatically using the Filter.Expression DSL:spring-doc.cn
FilterExpressionBuilder b = new FilterExpressionBuilder();
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("author", "john", "jill"),
        b.eq("article_type", "blog")).build()).build());
These filter expressions are automatically converted into the equivalent MariaDB JSON path expressions.
Accessing the Native Client
The MariaDB Vector Store implementation provides access to the underlying native JDBC client (JdbcTemplate) through the getNativeClient() method:spring-doc.cn
MariaDBVectorStore vectorStore = context.getBean(MariaDBVectorStore.class);
Optional<JdbcTemplate> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    JdbcTemplate jdbc = nativeClient.get();
    // Use the native client for MariaDB-specific operations
The native client gives you access to MariaDB-specific features and operations that might not be exposed through the VectorStore interface.spring-doc.cn
