Testcontainers
Spring AI provides Spring Boot auto-configuration for establishing a connection to a model service or vector store running via Testcontainers. To enable it, add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
   <artifactId>spring-ai-spring-boot-testcontainers</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-spring-boot-testcontainers'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Service Connections
The following service connection factories are provided in the spring-ai-spring-boot-testcontainers module:spring-doc.cn
Connection Details Matched on
AwsOpenSearchConnectionDetailsspring-doc.cn
Containers of type LocalStackContainerspring-doc.cn
ChromaConnectionDetailsspring-doc.cn
Containers of type ChromaDBContainerspring-doc.cn
MilvusServiceClientConnectionDetailsspring-doc.cn
Containers of type MilvusContainerspring-doc.cn
MongoConnectionDetailsspring-doc.cn
Containers of type MongoDBAtlasLocalContainerspring-doc.cn
OllamaConnectionDetailsspring-doc.cn
Containers of type OllamaContainerspring-doc.cn
Containers of type OpensearchContainerspring-doc.cn
QdrantConnectionDetailsspring-doc.cn
Containers of type QdrantContainerspring-doc.cn
TypesenseConnectionDetailsspring-doc.cn
Containers of type TypesenseContainerspring-doc.cn
WeaviateConnectionDetailsspring-doc.cn
Containers of type WeaviateContainerspring-doc.cn
