Model Context Protocol (MCP)
The Model Context Protocol (MCP) is a standardized protocol that enables AI models to interact with external tools and resources in a structured way. It supports multiple transport mechanisms to provide flexibility across different environments.spring-doc.cn
The MCP Java SDK provides a Java implementation of the Model Context Protocol, enabling standardized interaction with AI models and tools through both synchronous and asynchronous communication patterns.spring-doc.cn
Spring AI MCP extends the MCP Java SDK with Spring Boot integration, providing both client and server starters. Bootstrap your AI applications with MCP support using Spring Initializer.spring-doc.cn
MCP Java SDK Architecture
This section provides an overview for the MCP Java SDK architecture. For the Spring AI MCP integration, refer to the Spring AI MCP Boot Starters documentation.
The Java MCP implementation follows a three-layer architecture:spring-doc.cn
MCP Stack Architecture
  • Client/Server Layer: The McpClient handles client-side operations while the McpServer manages server-side protocol operations. Both utilize McpSession for communication management.spring-doc.cn
  • Session Layer (McpSession): Manages communication patterns and state through the DefaultMcpSession implementation.spring-doc.cn
  • Transport Layer (McpTransport): Handles JSON-RPC message serialization and deserialization with support for multiple transport implementations.spring-doc.cn
MCP Client
The MCP Client is a key component in the Model Context Protocol (MCP) architecture, responsible for establishing and managing connections with MCP servers. It implements the client-side of the protocol, handling:spring-doc.cn
Java MCP Client Architecture
MCP Server
The MCP Server is a foundational component in the Model Context Protocol (MCP) architecture that provides tools, resources, and capabilities to clients. It implements the server-side of the protocol, responsible for:spring-doc.cn
Java MCP Server Architecture
For detailed implementation guidance, using the low-level MCP Client/Server APIs, refer to the MCP Java SDK documentation. For simplified setup using Spring Boot, use the MCP Boot Starters described below.spring-doc.cn
Spring AI MCP Integration
Spring AI provides MCP integration through the following Spring Boot starters:spring-doc.cn
Client Starters
  • spring-ai-mcp-client-spring-boot-starter - Core starter providing STDIO and HTTP-based SSE supportspring-doc.cn
  • spring-ai-mcp-client-webflux-spring-boot-starter - WebFlux-based SSE transport implementationspring-doc.cn
Server Starters
  • spring-ai-mcp-server-spring-boot-starter - Core server with STDIO transport supportspring-doc.cn
  • spring-ai-mcp-server-webmvc-spring-boot-starter - Spring MVC-based SSE transport implementationspring-doc.cn
  • spring-ai-mcp-server-webflux-spring-boot-starter - WebFlux-based SSE transport implementationspring-doc.cn
