OpenAI Transcriptions
Prerequisites
You will need to create an API key with OpenAI to access ChatGPT models. Create an account at OpenAI signup page and generate the token on the API Keys page. The Spring AI project defines a configuration property named spring.ai.openai.api-key that you should set to the value of the API Key obtained from openai.com. Exporting an environment variable is one way to set that configuration property:spring-doc.cn
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the OpenAI Transcription Client. To enable it add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-openai-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-openai-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Transcription Properties
Connection Properties
The prefix spring.ai.openai is used as the property prefix that lets you connect to OpenAI.spring-doc.cn
Propertyspring-doc.cn
Descriptionspring-doc.cn
Defaultspring-doc.cn
spring.ai.openai.base-urlspring-doc.cn
The URL to connect tospring-doc.cn
api.openai.comspring-doc.cn
spring.ai.openai.api-keyspring-doc.cn
The API Keyspring-doc.cn
-spring-doc.cn
spring.ai.openai.organization-idspring-doc.cn
Optionally you can specify which organization used for an API request.spring-doc.cn
-spring-doc.cn
spring.ai.openai.project-idspring-doc.cn
Optionally, you can specify which project is used for an API request.spring-doc.cn
-spring-doc.cn
For users that belong to multiple organizations (or are accessing their projects through their legacy user API key), optionally, you can specify which organization and project is used for an API request. Usage from these API requests will count as usage for the specified organization and project.
Configuration Properties
The prefix spring.ai.openai.audio.transcription is used as the property prefix that lets you configure the retry mechanism for the OpenAI transcription model.spring-doc.cn
Property Description Default
spring.ai.openai.audio.transcription.base-urlspring-doc.cn
spring.ai.openai.audio.transcription.api-keyspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.transcription.organization-idspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.transcription.project-idspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.transcription.options.modelspring-doc.cn
ID of the model to use. Only whisper-1 (which is powered by our open source Whisper V2 model) is currently available.spring-doc.cn
whisper-1spring-doc.cn
spring.ai.openai.audio.transcription.options.response-formatspring-doc.cn
The format of the transcript output, in one of these options: json, text, srt, verbose_json, or vtt.spring-doc.cn
jsonspring-doc.cn
spring.ai.openai.audio.transcription.options.promptspring-doc.cn
An optional text to guide the model’s style or continue a previous audio segment. The prompt should match the audio language.spring-doc.cn
spring.ai.openai.audio.transcription.options.languagespring-doc.cn
The language of the input audio. Supplying the input language in ISO-639-1 format will improve accuracy and latency.spring-doc.cn
spring.ai.openai.audio.transcription.options.temperaturespring-doc.cn
The sampling temperature, between 0 and 1. Higher values like 0.8 will make the output more random, while lower values like 0.2 will make it more focused and deterministic. If set to 0, the model will use log probability to automatically increase the temperature until certain thresholds are hit.spring-doc.cn
0spring-doc.cn
spring.ai.openai.audio.transcription.options.timestamp_granularitiesspring-doc.cn
The timestamp granularities to populate for this transcription. response_format must be set verbose_json to use timestamp granularities. Either or both of these options are supported: word, or segment. Note: There is no additional latency for segment timestamps, but generating word timestamps incurs additional latency.spring-doc.cn
segmentspring-doc.cn
You can override the common spring.ai.openai.base-url, spring.ai.openai.api-key, spring.ai.openai.organization-id and spring.ai.openai.project-id properties. The spring.ai.openai.audio.transcription.base-url, spring.ai.openai.audio.transcription.api-key, spring.ai.openai.audio.transcription.organization-id and spring.ai.openai.audio.transcription.project-id properties if set take precedence over the common properties. This is useful if you want to use different OpenAI accounts for different models and different model endpoints.
All properties prefixed with spring.ai.openai.transcription.options can be overridden at runtime.
Runtime Options
The OpenAiAudioTranscriptionOptions class provides the options to use when making a transcription. On start-up, the options specified by spring.ai.openai.audio.transcription are used but you can override these at runtime.spring-doc.cn
For example:spring-doc.cn
OpenAiAudioApi.TranscriptResponseFormat responseFormat = OpenAiAudioApi.TranscriptResponseFormat.VTT;
OpenAiAudioTranscriptionOptions transcriptionOptions = OpenAiAudioTranscriptionOptions.builder()
    .language("en")
    .prompt("Ask not this, but ask that")
    .temperature(0f)
    .responseFormat(this.responseFormat)
AudioTranscriptionPrompt transcriptionRequest = new AudioTranscriptionPrompt(audioFile, this.transcriptionOptions);
AudioTranscriptionResponse response = openAiTranscriptionModel.call(this.transcriptionRequest);
Manual Configuration
Add the spring-ai-openai dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-openai</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-openai'
Next, create a OpenAiAudioTranscriptionModelspring-doc.cn
var openAiAudioApi = new OpenAiAudioApi(System.getenv("OPENAI_API_KEY"));
var openAiAudioTranscriptionModel = new OpenAiAudioTranscriptionModel(this.openAiAudioApi);
var transcriptionOptions = OpenAiAudioTranscriptionOptions.builder()
    .responseFormat(TranscriptResponseFormat.TEXT)
    .temperature(0f)
var audioFile = new FileSystemResource("/path/to/your/resource/speech/jfk.flac");
AudioTranscriptionPrompt transcriptionRequest = new AudioTranscriptionPrompt(this.audioFile, this.transcriptionOptions);
Example Code
