SAP HANA Cloud
Prerequisites
You need a SAP HANA Cloud vector engine account - Refer SAP HANA Cloud vector engine - provision a trial account guide to create a trial account.
If required, an API key for the EmbeddingModel to generate the embeddings stored by the vector store.
Auto-configuration
Spring AI does not provide a dedicated module for SAP Hana vector store.
Users are expected to provide their own configuration in the applications using the standard vector store module for SAP Hana vector store in Spring AI - spring-ai-hanadb-store
Refer to the Dependency Management section to add the Spring AI BOM to your build file. |
Please have a look at the list of HanaCloudVectorStore Properties for the vector store to learn about the default values and configuration options.
Refer to the Artifact Repositories section to add Maven Central and/or Snapshot Repositories to your build file. |
Additionally, you will need a configured EmbeddingModel
bean. Refer to the EmbeddingModel section for more information.
You can use the following properties in your Spring Boot configuration to customize the SAP Hana vector store.
It uses spring.datasource.
properties to configure the Hana datasource and the spring.ai.vectorstore.hanadb.
properties to configure the Hana vector store.
Property | Description | Default value |
Driver class name |
com.sap.db.jdbc.Driver |
Hana Datasource URL |
Hana datasource username |
Hana datasource password |
TODO |
TODO |
whether to initialize the required schema |
Build a Sample RAG application
Shows how to setup a project that uses SAP Hana Cloud as the vector DB and leverage OpenAI to implement RAG pattern
Create a table
CRICKET_WORLD_CUP
in SAP Hana DB:
CREATE TABLE CRICKET_WORLD_CUP ( _ID VARCHAR2(255) PRIMARY KEY, CONTENT CLOB, EMBEDDING REAL_VECTOR(1536) )
Add the following dependencies in your
pom.xml
You may set the property spring-ai-version
as <spring-ai-version>1.0.0-SNAPSHOT</spring-ai-version>
<dependencyManagement>
<dependencies>
<dependency>
<artifactId>spring-ai-bom</artifactId>
<version>${spring-ai-version}</version>
<type>pom</type>
<scope>import</scope>
</dependency>
</dependencies>
</dependencyManagement>
<dependency>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
<dependency>
<artifactId>spring-ai-pdf-document-reader</artifactId>
</dependency>
<dependency>
<artifactId>spring-ai-starter-model-openai</artifactId>
</dependency>
<dependency>
<artifactId>spring-ai-starter-vector-store-hana</artifactId>
</dependency>
<dependency>
<groupId>org.projectlombok</groupId>
<artifactId>lombok</artifactId>
<version>1.18.30</version>
<scope>provided</scope>
</dependency>
Add the following properties in
application.properties
file:
spring.ai.openai.api-key=${OPENAI_API_KEY} spring.ai.openai.embedding.options.model=text-embedding-ada-002 spring.datasource.driver-class-name=com.sap.db.jdbc.Driver spring.datasource.url=${HANA_DATASOURCE_URL} spring.datasource.username=${HANA_DATASOURCE_USERNAME} spring.datasource.password=${HANA_DATASOURCE_PASSWORD} spring.ai.vectorstore.hanadb.tableName=CRICKET_WORLD_CUP spring.ai.vectorstore.hanadb.topK=3
Create an Entity
class named CricketWorldCup
that extends from HanaVectorEntity
package com.interviewpedia.spring.ai.hana;
import jakarta.persistence.Column;
import jakarta.persistence.Entity;
import jakarta.persistence.Table;
import lombok.Data;
import lombok.NoArgsConstructor;
import lombok.extern.jackson.Jacksonized;
import org.springframework.ai.vectorstore.hanadb.HanaVectorEntity;
@Entity
@Table(name = "CRICKET_WORLD_CUP")
@Data
@Jacksonized
@NoArgsConstructor
public class CricketWorldCup extends HanaVectorEntity {
@Column(name = "content")
private String content;
Create a
Repository
namedCricketWorldCupRepository
that implementsHanaVectorRepository
interface:
import jakarta.persistence.EntityManager;
import jakarta.persistence.PersistenceContext;
import jakarta.transaction.Transactional;
import org.springframework.ai.vectorstore.hanadb.HanaVectorRepository;
import org.springframework.stereotype.Repository;
import java.util.List;
@Repository
public class CricketWorldCupRepository implements HanaVectorRepository<CricketWorldCup> {
@PersistenceContext
private EntityManager entityManager;
@Transactional
public void save(String tableName, String id, String embedding, String content) {
String sql = String.format("""
INSERT INTO %s (_ID, EMBEDDING, CONTENT)
VALUES(:_id, TO_REAL_VECTOR(:embedding), :content)
""", tableName);
this.entityManager.createNativeQuery(sql)
.setParameter("_id", id)
.setParameter("embedding", embedding)
.setParameter("content", content)
.executeUpdate();
@Transactional
public int deleteEmbeddingsById(String tableName, List<String> idList) {
DELETE FROM %s WHERE _ID IN (:ids)
""", tableName);
return this.entityManager.createNativeQuery(sql)
.setParameter("ids", idList)
.executeUpdate();
@Transactional
public int deleteAllEmbeddings(String tableName) {
DELETE FROM %s
""", tableName);
return this.entityManager.createNativeQuery(sql).executeUpdate();
public List<CricketWorldCup> cosineSimilaritySearch(String tableName, int topK, String queryEmbedding) {
SELECT TOP :topK * FROM %s
ORDER BY COSINE_SIMILARITY(EMBEDDING, TO_REAL_VECTOR(:queryEmbedding)) DESC
""", tableName);
return this.entityManager.createNativeQuery(sql, CricketWorldCup.class)
.setParameter("topK", topK)
.setParameter("queryEmbedding", queryEmbedding)
.getResultList();
Now, create a REST Controller class
CricketWorldCupHanaController
, and autowireChatModel
andVectorStore
as dependencies In this controller class, create the following REST endpoints:-
/ai/hana-vector-store/cricket-world-cup/purge-embeddings
- to purge all the embeddings from the Vector Store -
/ai/hana-vector-store/cricket-world-cup/upload
- to upload the Cricket_World_Cup.pdf so that its data gets stored in SAP Hana Cloud Vector DB as embeddings -
- to implementRAG
using Cosine_Similarity in SAP Hana DB
import lombok.extern.slf4j.Slf4j;
import org.springframework.ai.chat.model.ChatModel;
import org.springframework.ai.chat.messages.UserMessage;
import org.springframework.ai.chat.prompt.Prompt;
import org.springframework.ai.chat.prompt.SystemPromptTemplate;
import org.springframework.ai.document.Document;
import org.springframework.ai.reader.pdf.PagePdfDocumentReader;
import org.springframework.ai.transformer.splitter.TokenTextSplitter;
import org.springframework.ai.vectorstore.hanadb.HanaCloudVectorStore;
import org.springframework.ai.vectorstore.VectorStore;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.core.io.Resource;
import org.springframework.http.ResponseEntity;
import org.springframework.web.bind.annotation.GetMapping;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestParam;
import org.springframework.web.bind.annotation.RestController;
import org.springframework.web.multipart.MultipartFile;
import java.io.IOException;
import java.util.Map;
import java.util.function.Function;
import java.util.function.Supplier;
import java.util.stream.Collectors;
@RestController
@Slf4j
public class CricketWorldCupHanaController {
private final VectorStore hanaCloudVectorStore;
private final ChatModel chatModel;
@Autowired
public CricketWorldCupHanaController(ChatModel chatModel, VectorStore hanaCloudVectorStore) {
this.chatModel = chatModel;
this.hanaCloudVectorStore = hanaCloudVectorStore;
@PostMapping("/ai/hana-vector-store/cricket-world-cup/purge-embeddings")
public ResponseEntity<String> purgeEmbeddings() {
int deleteCount = ((HanaCloudVectorStore) this.hanaCloudVectorStore).purgeEmbeddings();
log.info("{} embeddings purged from CRICKET_WORLD_CUP table in Hana DB", deleteCount);
return ResponseEntity.ok().body(String.format("%d embeddings purged from CRICKET_WORLD_CUP table in Hana DB", deleteCount));
@PostMapping("/ai/hana-vector-store/cricket-world-cup/upload")
public ResponseEntity<String> handleFileUpload(@RequestParam("pdf") MultipartFile file) throws IOException {
Resource pdf = file.getResource();
Supplier<List<Document>> reader = new PagePdfDocumentReader(pdf);
Function<List<Document>, List<Document>> splitter = new TokenTextSplitter();
List<Document> documents = splitter.apply(reader.get());
log.info("{} documents created from pdf file: {}", documents.size(), pdf.getFilename());
this.hanaCloudVectorStore.accept(documents);
return ResponseEntity.ok().body(String.format("%d documents created from pdf file: %s",
documents.size(), pdf.getFilename()));
@GetMapping("/ai/hana-vector-store/cricket-world-cup")
public Map<String, String> hanaVectorStoreSearch(@RequestParam(value = "message") String message) {
var documents = this.hanaCloudVectorStore.similaritySearch(message);
var inlined = documents.stream().map(Document::getText).collect(Collectors.joining(System.lineSeparator()));
var similarDocsMessage = new SystemPromptTemplate("Based on the following: {documents}")
.createMessage(Map.of("documents", inlined));
var userMessage = new UserMessage(message);
Prompt prompt = new Prompt(List.of(similarDocsMessage, userMessage));
String generation = this.chatModel.call(prompt).getResult().getOutput().getContent();
log.info("Generation: {}", generation);
return Map.of("generation", generation);
Since HanaDB vector store support does not provide the autoconfiguration module, you also need to provide the vector store bean in your application, as shown below, as an example.
public VectorStore hanaCloudVectorStore(CricketWorldCupRepository cricketWorldCupRepository,
EmbeddingModel embeddingModel) {
return HanaCloudVectorStore.builder(cricketWorldCupRepository, embeddingModel)
.tableName("CRICKET_WORLD_CUP")
.topK(1)
Use a
contextual
pdf file from wikipedia
Upload this PDF file using the file-upload REST endpoint that we created in the previous step.
