OpenSearch
This section walks you through setting up OpenSearchVectorStore to store document embeddings and perform similarity searches.spring-doc.cn
OpenSearch is an open-source search and analytics engine originally forked from Elasticsearch, distributed under the Apache License 2.0. It enhances AI application development by simplifying the integration and management of AI-generated assets. OpenSearch supports vector, lexical, and hybrid search capabilities, leveraging advanced vector database functionalities to facilitate low-latency queries and similarity searches as detailed on the vector database page.spring-doc.cn
The OpenSearch k-NN functionality allows users to query vector embeddings from large datasets. An embedding is a numerical representation of a data object, such as text, image, audio, or document. Embeddings can be stored in the index and queried using various similarity functions.spring-doc.cn
Prerequisites
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Spring AI provides Spring Boot auto-configuration for the OpenSearch Vector Store. To enable it, add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-vector-store-opensearch</artifactId>
</dependency>
or to your Gradle build.gradle build file:spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-vector-store-opensearch'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
For Amazon OpenSearch Service, use these dependencies instead:spring-doc.cn
<dependency>
</dependency>
or for Gradle:spring-doc.cn
dependencies {
Please have a look at the list of configuration parameters for the vector store to learn about the default values and configuration options.spring-doc.cn
Additionally, you will need a configured EmbeddingModel bean. Refer to the EmbeddingModel section for more information.spring-doc.cn
Now you can auto-wire the OpenSearchVectorStore as a vector store in your application:spring-doc.cn
@Autowired VectorStore vectorStore;
List<Document> documents = List.of(
    new Document("Spring AI rocks!! Spring AI rocks!! Spring AI rocks!!", Map.of("meta1", "meta1")),
    new Document("The World is Big and Salvation Lurks Around the Corner"),
    new Document("You walk forward facing the past and you turn back toward the future.", Map.of("meta2", "meta2")));
// Add the documents to OpenSearch
vectorStore.add(documents);
// Retrieve documents similar to a query
List<Document> results = vectorStore.similaritySearch(SearchRequest.builder().query("Spring").topK(5).build());
Configuration Properties
To connect to OpenSearch and use the OpenSearchVectorStore, you need to provide access details for your instance. A simple configuration can be provided via Spring Boot’s application.yml:spring-doc.cn
spring:
  ai:
    vectorstore:
      opensearch:
        uris: <opensearch instance URIs>
        username: <opensearch username>
        password: <opensearch password>
        index-name: spring-ai-document-index
        initialize-schema: true
        similarity-function: cosinesimil
        read-timeout: <time to wait for response>
        connect-timeout: <time to wait until connection established>
        ssl-bundle: <name of SSL bundle>
        aws:  # Only for Amazon OpenSearch Service
          host: <aws opensearch host>
          service-name: <aws service name>
          access-key: <aws access key>
          secret-key: <aws secret key>
          region: <aws region>
Properties starting with spring.ai.vectorstore.opensearch.* are used to configure the OpenSearchVectorStore:spring-doc.cn
Property Description Default Value
spring.ai.vectorstore.opensearch.urisspring-doc.cn
URIs of the OpenSearch cluster endpointsspring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.usernamespring-doc.cn
Username for accessing the OpenSearch clusterspring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.passwordspring-doc.cn
Password for the specified usernamespring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.index-namespring-doc.cn
Name of the index to store vectorsspring-doc.cn
spring-ai-document-indexspring-doc.cn
spring.ai.vectorstore.opensearch.initialize-schemaspring-doc.cn
Whether to initialize the required schemaspring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.opensearch.similarity-functionspring-doc.cn
The similarity function to usespring-doc.cn
cosinesimilspring-doc.cn
spring.ai.vectorstore.opensearch.read-timeoutspring-doc.cn
Time to wait for response from the opposite endpoint. 0 - infinity.spring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.connect-timeoutspring-doc.cn
Time to wait until connection established. 0 - infinity.spring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.ssl-bundlespring-doc.cn
Name of the SSL Bundle to use in case of SSL connectionspring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.aws.hostspring-doc.cn
Hostname of the OpenSearch instancespring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.aws.service-namespring-doc.cn
AWS service namespring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.aws.access-keyspring-doc.cn
AWS access keyspring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.aws.secret-keyspring-doc.cn
AWS secret keyspring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.opensearch.aws.regionspring-doc.cn
AWS regionspring-doc.cn
-spring-doc.cn
You can control whether the AWS-specific OpenSearch auto-configuration is enabled using the spring.ai.vectorstore.opensearch.aws.enabled property.spring-doc.cn
  • If this property is set to false, the non-AWS OpenSearch configuration is activated, even if AWS SDK classes are present on the classpath. This allows you to use self-managed or third-party OpenSearch clusters in environments where AWS SDKs are present for other services.spring-doc.cn
  • If AWS SDK classes are not present, the non-AWS configuration is always used.spring-doc.cn
  • If AWS SDK classes are present and the property is not set or set to true, the AWS-specific configuration is used by default.spring-doc.cn
This fallback logic ensures that users have explicit control over the type of OpenSearch integration, preventing accidental activation of AWS-specific logic when not desired.spring-doc.cn
The following similarity functions are available:spring-doc.cn
  • cosinesimil - Default, suitable for most use cases. Measures cosine similarity between vectors.spring-doc.cn
  • l1 - Manhattan distance between vectors.spring-doc.cn
  • l2 - Euclidean distance between vectors.spring-doc.cn
  • linf - Chebyshev distance between vectors.spring-doc.cn
Manual Configuration
Instead of using the Spring Boot auto-configuration, you can manually configure the OpenSearch vector store. For this you need to add the spring-ai-opensearch-store to your project:spring-doc.cn
<dependency>
    <artifactId>spring-ai-opensearch-store</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-opensearch-store'
Create an OpenSearch client bean:spring-doc.cn
public OpenSearchClient openSearchClient() {
    RestClient restClient = RestClient.builder(
        HttpHost.create("http://localhost:9200"))
    return new OpenSearchClient(new RestClientTransport(
        restClient, new JacksonJsonpMapper()));
Then create the OpenSearchVectorStore bean using the builder pattern:spring-doc.cn
public VectorStore vectorStore(OpenSearchClient openSearchClient, EmbeddingModel embeddingModel) {
    return OpenSearchVectorStore.builder(openSearchClient, embeddingModel)
        .index("custom-index")                // Optional: defaults to "spring-ai-document-index"
        .similarityFunction("l2")             // Optional: defaults to "cosinesimil"
        .initializeSchema(true)               // Optional: defaults to false
        .batchingStrategy(new TokenCountBatchingStrategy()) // Optional: defaults to TokenCountBatchingStrategy
// This can be any EmbeddingModel implementation
public EmbeddingModel embeddingModel() {
    return new OpenAiEmbeddingModel(new OpenAiApi(System.getenv("OPENAI_API_KEY")));
Metadata Filtering
You can leverage the generic, portable metadata filters with OpenSearch as well.spring-doc.cn
For example, you can use either the text expression language:spring-doc.cn
        .query("The World")
        .topK(TOP_K)
        .similarityThreshold(SIMILARITY_THRESHOLD)
        .filterExpression("author in ['john', 'jill'] && 'article_type' == 'blog'").build());
or programmatically using the Filter.Expression DSL:spring-doc.cn
FilterExpressionBuilder b = new FilterExpressionBuilder();
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("author", "john", "jill"),
        b.eq("article_type", "blog")).build()).build());
Those (portable) filter expressions get automatically converted into the proprietary OpenSearch Query string query.
For example, this portable filter expression:spring-doc.cn
is converted into the proprietary OpenSearch filter format:spring-doc.cn
(metadata.author:john OR jill) AND metadata.article_type:blog
Accessing the Native Client
The OpenSearch Vector Store implementation provides access to the underlying native OpenSearch client (OpenSearchClient) through the getNativeClient() method:spring-doc.cn
OpenSearchVectorStore vectorStore = context.getBean(OpenSearchVectorStore.class);
Optional<OpenSearchClient> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    OpenSearchClient client = nativeClient.get();
    // Use the native client for OpenSearch-specific operations
The native client gives you access to OpenSearch-specific features and operations that might not be exposed through the VectorStore interface.spring-doc.cn
