Azure OpenAI Embeddings
Azure’s OpenAI extends the OpenAI capabilities, offering safe text generation and Embeddings computation models for various task:
Similarity embeddings are good at capturing semantic similarity between two or more pieces of text.
Text search embeddings help measure whether long documents are relevant to a short query.
Code search embeddings are useful for embedding code snippets and embedding natural language search queries.
The Azure OpenAI embeddings rely on cosine similarity
to compute similarity between documents and a query.
Prerequisites
The Azure OpenAI client offers three options to connect: using an Azure API key or using an OpenAI API Key, or using Microsoft Entra ID.
Azure API Key & Endpoint
Obtain your Azure OpenAI endpoint
and api-key
from the Azure OpenAI Service section on the Azure Portal.
Spring AI defines two configuration properties:
spring.ai.azure.openai.api-key
: Set this to the value of theAPI Key
obtained from Azure. -
spring.ai.azure.openai.endpoint
: Set this to the endpoint URL obtained when provisioning your model in Azure.
You can set these configuration properties by exporting environment variables:
export SPRING_AI_AZURE_OPENAI_API_KEY=<INSERT AZURE KEY HERE>
export SPRING_AI_AZURE_OPENAI_ENDPOINT=<INSERT ENDPOINT URL HERE>
OpenAI Key
To authenticate with the OpenAI service (not Azure), provide an OpenAI API key. This will automatically set the endpoint to api.openai.com/v1.
When using this approach, set the spring.ai.azure.openai.chat.options.deployment-name
property to the name of the OpenAI model you wish to use.
export SPRING_AI_AZURE_OPENAI_OPENAI_API_KEY=<INSERT OPENAI KEY HERE>
Microsoft Entra ID
For keyless authentication using Microsoft Entra ID (formerly Azure Active Directory), set only the spring.ai.azure.openai.endpoint
configuration property and not the api-key property mentioned above.
Finding only the endpoint property, your application will evaluate several different options for retrieving credentials and an OpenAIClient
instance will be created using the token credentials.
It is no longer necessary to create a TokenCredential bean; it is configured for you automatically.
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Artifact Repositories section to add these repositories to your build system.
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information. |
Spring AI provides Spring Boot auto-configuration for the Azure OpenAI Embedding Model.
To enable it add the following dependency to your project’s Maven pom.xml
file:
<dependency>
<artifactId>spring-ai-starter-model-azure-openai</artifactId>
</dependency>
or to your Gradle build.gradle
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-starter-model-azure-openai'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. |
Embedding Properties
The prefix spring.ai.azure.openai
is the property prefix to configure the connection to Azure OpenAI.
Property | Description | Default |
spring.ai.azure.openai.api-key |
The Key from Azure AI OpenAI |
spring.ai.azure.openai.endpoint |
The endpoint from the Azure AI OpenAI |
spring.ai.azure.openai.openai-api-key |
(non Azure) OpenAI API key. Used to authenticate with the OpenAI service, instead of Azure OpenAI.
This automatically sets the endpoint to api.openai.com/v1. Use either |
Enabling and disabling of the embedding auto-configurations are now configured via top level properties with the prefix To enable, spring.ai.model.embedding=azure-openai (It is enabled by default) To disable, spring.ai.model.embedding=none (or any value which doesn’t match azure-openai) This change is done to allow configuration of multiple models. |
The prefix spring.ai.azure.openai.embedding
is the property prefix that configures the EmbeddingModel
implementation for Azure OpenAI
spring.ai.azure.openai.embedding.enabled (Removed and no longer valid) |
Enable Azure OpenAI embedding model. |
true |
spring.ai.model.embedding |
azure-openai |
spring.ai.azure.openai.embedding.metadata-mode |
Document content extraction mode |
EMBED |
spring.ai.azure.openai.embedding.options.deployment-name |
This is the value of the 'Deployment Name' as presented in the Azure AI Portal |
text-embedding-ada-002 |
spring.ai.azure.openai.embedding.options.user |
An identifier for the caller or end user of the operation. This may be used for tracking or rate-limiting purposes. |
All properties prefixed with spring.ai.azure.openai.embedding.options can be overridden at runtime by adding a request specific Runtime Options to the EmbeddingRequest call.
Runtime Options
The AzureOpenAiEmbeddingOptions
provides the configuration information for the embedding requests.
offers a builder to create the options.
At start time use the AzureOpenAiEmbeddingModel
constructor to set the default options used for all embedding requests.
At run-time you can override the default options, by passing a AzureOpenAiEmbeddingOptions
instance with your to the EmbeddingRequest
request.
For example to override the default model name for a specific request:
EmbeddingResponse embeddingResponse = embeddingModel.call(
new EmbeddingRequest(List.of("Hello World", "World is big and salvation is near"),
AzureOpenAiEmbeddingOptions.builder()
.model("Different-Embedding-Model-Deployment-Name")
.build()));
Sample Code
This will create a EmbeddingModel
implementation that you can inject into your class.
Here is an example of a simple @Controller
class that uses the EmbeddingModel
implementation.
spring.ai.azure.openai.api-key=YOUR_API_KEY
spring.ai.azure.openai.endpoint=YOUR_ENDPOINT
spring.ai.azure.openai.embedding.options.model=text-embedding-ada-002
@RestController
public class EmbeddingController {
private final EmbeddingModel embeddingModel;
@Autowired
public EmbeddingController(EmbeddingModel embeddingModel) {
this.embeddingModel = embeddingModel;
@GetMapping("/ai/embedding")
public Map embed(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
EmbeddingResponse embeddingResponse = this.embeddingModel.embedForResponse(List.of(message));
return Map.of("embedding", embeddingResponse);
Manual Configuration
If you prefer not to use the Spring Boot auto-configuration, you can manually configure the AzureOpenAiEmbeddingModel
in your application.
For this add the spring-ai-azure-openai
file:
<dependency>
<artifactId>spring-ai-azure-openai</artifactId>
</dependency>
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-azure-openai'
The spring-ai-azure-openai dependency also provide the access to the AzureOpenAiEmbeddingModel . For more information about the AzureOpenAiChatModel refer to the Azure OpenAI Embeddings section.
Next, create an AzureOpenAiEmbeddingModel
instance and use it to compute the similarity between two input texts:
var openAIClient = OpenAIClientBuilder()
.credential(new AzureKeyCredential(System.getenv("AZURE_OPENAI_API_KEY")))
.endpoint(System.getenv("AZURE_OPENAI_ENDPOINT"))
.buildClient();
var embeddingModel = new AzureOpenAiEmbeddingModel(this.openAIClient)
.withDefaultOptions(AzureOpenAiEmbeddingOptions.builder()
.model("text-embedding-ada-002")
.user("user-6")
.build());
.embedForResponse(List.of("Hello World", "World is big and salvation is near"));
the text-embedding-ada-002 is actually the Deployment Name as presented in the Azure AI Portal.
