Cohere Embeddings
Provides Bedrock Cohere Embedding model. Integrate generative AI capabilities into essential apps and workflows that improve business outcomes.
The AWS Bedrock Cohere Model Page and Amazon Bedrock User Guide contains detailed information on how to use the AWS hosted model.
Prerequisites
Refer to the Spring AI documentation on Amazon Bedrock for setting up API access.
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Artifact Repositories section to add these repositories to your build system.
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information. |
Add the spring-ai-starter-model-bedrock
dependency to your project’s Maven pom.xml
file:
<dependency>
<artifactId>spring-ai-starter-model-bedrock</artifactId>
</dependency>
or to your Gradle build.gradle
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-starter-model-bedrock'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. |
Enable Cohere Embedding Support
By default the Cohere model is disabled.
To enable it set the spring.ai.model.embedding
property to bedrock-cohere
Exporting environment variable is one way to set this configuration property:
export SPRING_AI_MODEL_EMBEDDING=bedrock-cohere
Embedding Properties
The prefix spring.ai.bedrock.aws
is the property prefix to configure the connection to AWS Bedrock.
Property | Description | Default |
spring.ai.bedrock.aws.region |
AWS region to use. |
us-east-1 |
spring.ai.bedrock.aws.access-key |
AWS access key. |
spring.ai.bedrock.aws.secret-key |
AWS secret key. |
Enabling and disabling of the embedding auto-configurations are now configured via top level properties with the prefix To enable, spring.ai.model.embedding=bedrock-cohere (It is enabled by default) To disable, spring.ai.model.embedding=none (or any value which doesn’t match bedrock-cohere) This change is done to allow configuration of multiple models. |
The prefix spring.ai.bedrock.cohere.embedding
(defined in BedrockCohereEmbeddingProperties
) is the property prefix that configures the embedding model implementation for Cohere.
Property |
Description |
Default |
spring.ai.model.embedding |
Enable or disable support for Cohere |
bedrock-cohere |
spring.ai.bedrock.cohere.embedding.enabled (Removed and no longer valid) |
false |
spring.ai.bedrock.cohere.embedding.model |
The model id to use. See the CohereEmbeddingModel for the supported models. |
cohere.embed-multilingual-v3 |
spring.ai.bedrock.cohere.embedding.options.input-type |
Prepends special tokens to differentiate each type from one another. You should not mix different types together, except when mixing types for search and retrieval. In this case, embed your corpus with the search_document type and embedded queries with type search_query type. |
SEARCH_DOCUMENT |
spring.ai.bedrock.cohere.embedding.options.truncate |
Specifies how the API handles inputs longer than the maximum token length. If you specify LEFT or RIGHT, the model discards the input until the remaining input is exactly the maximum input token length for the model. |
NONE |
When accessing Cohere via Amazon Bedrock, the functionality of truncating is not available. This is an issue with Amazon Bedrock. The Spring AI class BedrockCohereEmbeddingModel will truncate to 2048 character length, which is the maximum supported by the model.
Look at the CohereEmbeddingModel for other model IDs.
Supported values are: cohere.embed-multilingual-v3
and cohere.embed-english-v3
Model ID values can also be found in the AWS Bedrock documentation for base model IDs.
All properties prefixed with spring.ai.bedrock.cohere.embedding.options can be overridden at runtime by adding a request specific Runtime Options to the EmbeddingRequest call.
Runtime Options
The BedrockCohereEmbeddingOptions.java provides model configurations, such as input-type
or truncate
On start-up, the default options can be configured with the BedrockCohereEmbeddingModel(api, options)
constructor or the spring.ai.bedrock.cohere.embedding.options.*
properties.
At runtime you can override the default options by adding new, request-specific, options to the EmbeddingRequest
call.
For example to override the default input type for a specific request:
EmbeddingResponse embeddingResponse = embeddingModel.call(
new EmbeddingRequest(List.of("Hello World", "World is big and salvation is near"),
BedrockCohereEmbeddingOptions.builder()
.withInputType(InputType.SEARCH_DOCUMENT)
.build()));
Sample Controller
Create a new Spring Boot project and add the spring-ai-starter-model-bedrock
to your pom (or gradle) dependencies.
Add a application.properties
file, under the src/main/resources
directory, to enable and configure the Cohere Embedding model:
spring.ai.bedrock.aws.region=eu-central-1
spring.ai.bedrock.aws.access-key=${AWS_ACCESS_KEY_ID}
spring.ai.bedrock.aws.secret-key=${AWS_SECRET_ACCESS_KEY}
spring.ai.bedrock.cohere.embedding.options.input-type=search-document
replace the regions , access-key and secret-key with your AWS credentials.
This will create a BedrockCohereEmbeddingModel
implementation that you can inject into your class.
Here is an example of a simple @Controller
class that uses the chat model for text generations.
@RestController
public class EmbeddingController {
private final EmbeddingModel embeddingModel;
@Autowired
public EmbeddingController(EmbeddingModel embeddingModel) {
this.embeddingModel = embeddingModel;
@GetMapping("/ai/embedding")
public Map embed(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
EmbeddingResponse embeddingResponse = this.embeddingModel.embedForResponse(List.of(message));
return Map.of("embedding", embeddingResponse);
Manual Configuration
The BedrockCohereEmbeddingModel implements the EmbeddingModel
and uses the Low-level CohereEmbeddingBedrockApi Client to connect to the Bedrock Cohere service.
Add the spring-ai-bedrock
file:
<dependency>
<artifactId>spring-ai-bedrock</artifactId>
</dependency>
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-bedrock'
Next, create an BedrockCohereEmbeddingModel and use it for text embeddings:
var cohereEmbeddingApi =new CohereEmbeddingBedrockApi(
CohereEmbeddingModel.COHERE_EMBED_MULTILINGUAL_V1.id(),
EnvironmentVariableCredentialsProvider.create(), Region.US_EAST_1.id(), new ObjectMapper());
var embeddingModel = new BedrockCohereEmbeddingModel(this.cohereEmbeddingApi);
.embedForResponse(List.of("Hello World", "World is big and salvation is near"));
The CohereEmbeddingBedrockApi provides is lightweight Java client on top of AWS Bedrock Cohere Command models.
Following class diagram illustrates the CohereEmbeddingBedrockApi interface and building blocks:
The CohereEmbeddingBedrockApi supports the cohere.embed-english-v3
and cohere.embed-multilingual-v3
models for single and batch embedding computation.
Here is a simple snippet how to use the api programmatically:
CohereEmbeddingBedrockApi api = new CohereEmbeddingBedrockApi(
CohereEmbeddingRequest request = new CohereEmbeddingRequest(
List.of("I like to eat apples", "I like to eat oranges"),
CohereEmbeddingRequest.InputType.search_document,
CohereEmbeddingRequest.Truncate.NONE);
CohereEmbeddingResponse response = this.api.embedding(this.request);
