此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.4.3spring-doc.cadn.net.cn
跨站点请求伪造 (CSRF)
在最终用户可以登录的应用程序中,重要的是要考虑如何防止跨站点请求伪造 (CSRF)。spring-doc.cadn.net.cn
默认情况下, Spring Security 可以防止针对不安全的 HTTP 方法(例如 POST 请求)的 CSRF 攻击,因此不需要额外的代码。 您可以使用以下内容显式指定默认配置:spring-doc.cadn.net.cn
配置 CSRF 保护
@EnableWebSecurity
public class SecurityConfig {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		http
			.csrf(Customizer.withDefaults());
		return http.build();
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
    open fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
        http {
            csrf { }
        return http.build()
<http>
	<csrf/>
</http>
To learn more about CSRF protection for your application, consider the following use cases:spring-doc.cadn.net.cn
Understanding CSRF Protection’s Components
CSRF protection is provided by several components that are composed within the CsrfFilter:spring-doc.cadn.net.cn
csrf
Figure 1. CsrfFilter Components
CSRF protection is divided into two parts:spring-doc.cadn.net.cn
  1. Make the CsrfToken available to the application by delegating to the CsrfTokenRequestHandler.spring-doc.cadn.net.cn
  2. Determine if the request requires CSRF protection, load and validate the token, and handle AccessDeniedException.spring-doc.cadn.net.cn
csrf processing
Figure 2. CsrfFilter Processing
Migrating to Spring Security 6
When migrating from Spring Security 5 to 6, there are a few changes that may impact your application. The following is an overview of the aspects of CSRF protection that have changed in Spring Security 6:spring-doc.cadn.net.cn
The changes in Spring Security 6 require additional configuration for single-page applications, and as such you may find the Single-Page Applications section particularly useful.spring-doc.cadn.net.cn
See the Exploit Protection section of the Migration chapter for more information on migrating a Spring Security 5 application.spring-doc.cadn.net.cn
Persisting the CsrfToken
The CsrfToken is persisted using a CsrfTokenRepository.spring-doc.cadn.net.cn
By default, the HttpSessionCsrfTokenRepository is used for storing tokens in a session. Spring Security also provides the CookieCsrfTokenRepository for storing tokens in a cookie. You can also specify your own implementation to store tokens wherever you like.spring-doc.cadn.net.cn
Using the HttpSessionCsrfTokenRepository
By default, Spring Security stores the expected CSRF token in the HttpSession by using HttpSessionCsrfTokenRepository, so no additional code is necessary.spring-doc.cadn.net.cn
The HttpSessionCsrfTokenRepository reads the token from a session (whether in-memory, cache, or database). If you need to access the session attribute directly, please first configure the session attribute name using HttpSessionCsrfTokenRepository#setSessionAttributeName.spring-doc.cadn.net.cn
You can specify the default configuration explicitly using the following configuration:spring-doc.cadn.net.cn
Configure HttpSessionCsrfTokenRepository
@EnableWebSecurity
		http
			.csrf((csrf) -> csrf
				.csrfTokenRepository(new HttpSessionCsrfTokenRepository())
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRepository = HttpSessionCsrfTokenRepository()
        return http.build()
<http>
	<csrf token-repository-ref="tokenRepository"/>
</http>
<b:bean id="tokenRepository"
	class="org.springframework.security.web.csrf.HttpSessionCsrfTokenRepository"/>
You can persist the CsrfToken in a cookie to support a JavaScript-based application using the CookieCsrfTokenRepository.spring-doc.cadn.net.cn
The CookieCsrfTokenRepository writes to a cookie named XSRF-TOKEN and reads it from an HTTP request header named X-XSRF-TOKEN or the request parameter _csrf by default. These defaults come from Angular and its predecessor AngularJS.spring-doc.cadn.net.cn
See the Cross-Site Request Forgery (XSRF) protection guide and the HttpClientXsrfModule for more recent information on this topic.spring-doc.cadn.net.cn
You can configure the CookieCsrfTokenRepository using the following configuration:spring-doc.cadn.net.cn
The example explicitly sets HttpOnly to false. This is necessary to let JavaScript frameworks (such as Angular) read it. If you do not need the ability to read the cookie with JavaScript directly, we recommend omitting HttpOnly (by using new CookieCsrfTokenRepository() instead) to improve security.spring-doc.cadn.net.cn
Customizing the CsrfTokenRepository
There can be cases where you want to implement a custom CsrfTokenRepository.spring-doc.cadn.net.cn
Once you’ve implemented the CsrfTokenRepository interface, you can configure Spring Security to use it with the following configuration:spring-doc.cadn.net.cn
Configure Custom CsrfTokenRepository
@EnableWebSecurity
		http
				.csrfTokenRepository(new CustomCsrfTokenRepository())
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRepository = CustomCsrfTokenRepository()
        return http.build()
<http>
</http>
	class="example.CustomCsrfTokenRepository"/>
Handling the CsrfToken
The CsrfToken is made available to an application using a CsrfTokenRequestHandler. This component is also responsible for resolving the CsrfToken from HTTP headers or request parameters.spring-doc.cadn.net.cn
By default, the XorCsrfTokenRequestAttributeHandler is used for providing BREACH protection of the CsrfToken. Spring Security also provides the CsrfTokenRequestAttributeHandler for opting out of BREACH protection. You can also specify your own implementation to customize the strategy for handling and resolving tokens.spring-doc.cadn.net.cn
Using the XorCsrfTokenRequestAttributeHandler (BREACH)
The XorCsrfTokenRequestAttributeHandler makes the CsrfToken available as an HttpServletRequest attribute called _csrf, and additionally provides protection for BREACH.spring-doc.cadn.net.cn
The CsrfToken is also made available as a request attribute using the name CsrfToken.class.getName(). This name is not configurable, but the name _csrf can be changed using XorCsrfTokenRequestAttributeHandler#setCsrfRequestAttributeName.spring-doc.cadn.net.cn
This implementation also resolves the token value from the request as either a request header (one of X-CSRF-TOKEN or X-XSRF-TOKEN by default) or a request parameter (_csrf by default).spring-doc.cadn.net.cn
BREACH protection is provided by encoding randomness into the CSRF token value to ensure the returned CsrfToken changes on every request. When the token is later resolved as a header value or request parameter, it is decoded to obtain the raw token which is then compared to the persisted CsrfToken.spring-doc.cadn.net.cn
Spring Security protects the CSRF token from a BREACH attack by default, so no additional code is necessary. You can specify the default configuration explicitly using the following configuration:spring-doc.cadn.net.cn
Configure BREACH protection
@EnableWebSecurity
		http
				.csrfTokenRequestHandler(new XorCsrfTokenRequestAttributeHandler())
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRequestHandler = XorCsrfTokenRequestAttributeHandler()
        return http.build()
<http>
	<csrf request-handler-ref="requestHandler"/>
</http>
<b:bean id="requestHandler"
	class="org.springframework.security.web.csrf.XorCsrfTokenRequestAttributeHandler"/>
Using the CsrfTokenRequestAttributeHandler
The CsrfTokenRequestAttributeHandler makes the CsrfToken available as an HttpServletRequest attribute called _csrf.spring-doc.cadn.net.cn
The CsrfToken is also made available as a request attribute using the name CsrfToken.class.getName(). This name is not configurable, but the name _csrf can be changed using CsrfTokenRequestAttributeHandler#setCsrfRequestAttributeName.spring-doc.cadn.net.cn
The primary use of CsrfTokenRequestAttributeHandler is to opt-out of BREACH protection of the CsrfToken, which can be configured using the following configuration:spring-doc.cadn.net.cn
Opt-out of BREACH protection
@EnableWebSecurity
		http
				.csrfTokenRequestHandler(new CsrfTokenRequestAttributeHandler())
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRequestHandler = CsrfTokenRequestAttributeHandler()
        return http.build()
<http>
</http>
	class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler"/>
Customizing the CsrfTokenRequestHandler
You can implement the CsrfTokenRequestHandler interface to customize the strategy for handling and resolving tokens.spring-doc.cadn.net.cn
The CsrfTokenRequestHandler interface is a @FunctionalInterface that can be implemented using a lambda expression to customize request handling. You will need to implement the full interface to customize how tokens are resolved from the request. See Configure CSRF for Single-Page Application for an example that uses delegation to implement a custom strategy for handling and resolving tokens.spring-doc.cadn.net.cn
Once you’ve implemented the CsrfTokenRequestHandler interface, you can configure Spring Security to use it with the following configuration:spring-doc.cadn.net.cn
Configure Custom CsrfTokenRequestHandler
@EnableWebSecurity
		http
				.csrfTokenRequestHandler(new CustomCsrfTokenRequestHandler())
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRequestHandler = CustomCsrfTokenRequestHandler()
        return http.build()
<http>
</http>
	class="example.CustomCsrfTokenRequestHandler"/>
Deferred Loading of the CsrfToken
By default, Spring Security defers loading of the CsrfToken until it is needed.spring-doc.cadn.net.cn
The CsrfToken is needed whenever a request is made with an unsafe HTTP method, such as a POST. Additionally, it is needed by any request that renders the token to the response, such as a web page with a <form> tag that includes a hidden <input> for the CSRF token.spring-doc.cadn.net.cn
Because Spring Security also stores the CsrfToken in the HttpSession by default, deferred CSRF tokens can improve performance by not requiring the session to be loaded on every request.spring-doc.cadn.net.cn
In the event that you want to opt-out of deferred tokens and cause the CsrfToken to be loaded on every request, you can do so with the following configuration:spring-doc.cadn.net.cn
Opt-out of Deferred CSRF Tokens
@EnableWebSecurity
		XorCsrfTokenRequestAttributeHandler requestHandler = new XorCsrfTokenRequestAttributeHandler();
		// set the name of the attribute the CsrfToken will be populated on
		requestHandler.setCsrfRequestAttributeName(null);
		http
				.csrfTokenRequestHandler(requestHandler)
@EnableWebSecurity
        val requestHandler = XorCsrfTokenRequestAttributeHandler()
        http {
            csrf {
                csrfTokenRequestHandler = requestHandler
        return http.build()
<http>
</http>
	class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler">
	<b:property name="csrfRequestAttributeName">
		<b:null/>
	</b:property>
</b:bean>
By setting the csrfRequestAttributeName to null, the CsrfToken must first be loaded to determine what attribute name to use. This causes the CsrfToken to be loaded on every request.spring-doc.cadn.net.cn
Integrating with CSRF Protection
For the synchronizer token pattern to protect against CSRF attacks, we must include the actual CSRF token in the HTTP request. This must be included in a part of the request (a form parameter, an HTTP header, or other part) that is not automatically included in the HTTP request by the browser.spring-doc.cadn.net.cn
The following sections describe the various ways a frontend or client application can integrate with a CSRF-protected backend application:spring-doc.cadn.net.cn
HTML Forms
To submit an HTML form, the CSRF token must be included in the form as a hidden input. For example, the rendered HTML might look like:spring-doc.cadn.net.cn
CSRF Token in HTML Form
<input type="hidden"
	name="_csrf"
	value="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
The following view technologies automatically include the actual CSRF token in a form that has an unsafe HTTP method, such as a POST:spring-doc.cadn.net.cn
If these options are not available, you can take advantage of the fact that the CsrfToken is exposed as an HttpServletRequest attribute named _csrf. The following example does this with a JSP:spring-doc.cadn.net.cn
CSRF Token in HTML Form with Request Attribute
<c:url var="logoutUrl" value="/logout"/>
<form action="${logoutUrl}"
	method="post">
<input type="submit"
	value="Log out" />
	name="${_csrf.parameterName}"
	value="${_csrf.token}"/>
</form>
JavaScript Applications
JavaScript applications typically use JSON instead of HTML. If you use JSON, you can submit the CSRF token within an HTTP request header instead of a request parameter.spring-doc.cadn.net.cn
In order to obtain the CSRF token, you can configure Spring Security to store the expected CSRF token in a cookie. By storing the expected token in a cookie, JavaScript frameworks such as Angular can automatically include the actual CSRF token as an HTTP request header.spring-doc.cadn.net.cn
There are special considerations for BREACH protection and deferred tokens when integrating a single-page application (SPA) with Spring Security’s CSRF protection. A full configuration example is provided in the next section.spring-doc.cadn.net.cn
You can read about different types of JavaScript applications in the following sections:spring-doc.cadn.net.cn
There are special considerations for integrating a single-page application (SPA) with Spring Security’s CSRF protection.spring-doc.cadn.net.cn
Recall that Spring Security provides BREACH protection of the CsrfToken by default. When storing the expected CSRF token in a cookie, JavaScript applications will only have access to the plain token value and will not have access to the encoded value. A customized request handler for resolving the actual token value will need to be provided.spring-doc.cadn.net.cn
In addition, the cookie storing the CSRF token will be cleared upon authentication success and logout success. Spring Security defers loading a new CSRF token by default, and additional work is required to return a fresh cookie.spring-doc.cadn.net.cn
Refreshing the token after authentication success and logout success is required because the CsrfAuthenticationStrategy and CsrfLogoutHandler will clear the previous token. The client application will not be able to perform an unsafe HTTP request, such as a POST, without obtaining a fresh token.spring-doc.cadn.net.cn
In order to easily integrate a single-page application with Spring Security, the following configuration can be used:spring-doc.cadn.net.cn
@EnableWebSecurity
		http
				.csrfTokenRepository(CookieCsrfTokenRepository.withHttpOnlyFalse())   (1)
				.csrfTokenRequestHandler(new SpaCsrfTokenRequestHandler())            (2)
final class SpaCsrfTokenRequestHandler implements CsrfTokenRequestHandler {
	private final CsrfTokenRequestHandler plain = new CsrfTokenRequestAttributeHandler();
	private final CsrfTokenRequestHandler xor = new XorCsrfTokenRequestAttributeHandler();
	public void handle(HttpServletRequest request, HttpServletResponse response, Supplier<CsrfToken> csrfToken) {
		 * Always use XorCsrfTokenRequestAttributeHandler to provide BREACH protection of
		 * the CsrfToken when it is rendered in the response body.
		this.xor.handle(request, response, csrfToken);
		 * Render the token value to a cookie by causing the deferred token to be loaded.
		csrfToken.get();
	public String resolveCsrfTokenValue(HttpServletRequest request, CsrfToken csrfToken) {
		String headerValue = request.getHeader(csrfToken.getHeaderName());
		 * If the request contains a request header, use CsrfTokenRequestAttributeHandler
		 * to resolve the CsrfToken. This applies when a single-page application includes
		 * the header value automatically, which was obtained via a cookie containing the
		 * raw CsrfToken.
		 * In all other cases (e.g. if the request contains a request parameter), use
		 * XorCsrfTokenRequestAttributeHandler to resolve the CsrfToken. This applies
		 * when a server-side rendered form includes the _csrf request parameter as a
		 * hidden input.
		return (StringUtils.hasText(headerValue) ? this.plain : this.xor).resolveCsrfTokenValue(request, csrfToken);
@EnableWebSecurity
        http {
            csrf {
                csrfTokenRepository = CookieCsrfTokenRepository.withHttpOnlyFalse()   (1)
                csrfTokenRequestHandler = SpaCsrfTokenRequestHandler()                (2)
        return http.build()
class SpaCsrfTokenRequestHandler : CsrfTokenRequestHandler {
    private val plain: CsrfTokenRequestHandler = CsrfTokenRequestAttributeHandler()
    private val xor: CsrfTokenRequestHandler = XorCsrfTokenRequestAttributeHandler()
    override fun handle(request: HttpServletRequest, response: HttpServletResponse, csrfToken: Supplier<CsrfToken>) {
        csrfToken.get()
    override fun resolveCsrfTokenValue(request: HttpServletRequest, csrfToken: CsrfToken): String? {
        val headerValue = request.getHeader(csrfToken.headerName)
         * raw CsrfToken.
        return if (StringUtils.hasText(headerValue)) {
            plain
        } else {
             * hidden input.
            xor
        }.resolveCsrfTokenValue(request, csrfToken)
<http>
	<csrf
		token-repository-ref="tokenRepository"                                        (1)
		request-handler-ref="requestHandler"/>                                        (2)
</http>
	class="org.springframework.security.web.csrf.CookieCsrfTokenRepository"
	p:cookieHttpOnly="false"/>
	class="example.SpaCsrfTokenRequestHandler"/>
1 Configure CookieCsrfTokenRepository with HttpOnly set to false so the cookie can be read by the JavaScript application.
2 Configure a custom CsrfTokenRequestHandler that resolves the CSRF token based on whether it is an HTTP request header (X-XSRF-TOKEN) or request parameter (_csrf). This implementation also causes the deferred CsrfToken to be loaded on every request, which will return a new cookie if needed.
Multi-Page Applications
For multi-page applications where JavaScript is loaded on each page, an alternative to exposing the CSRF token in a cookie is to include the CSRF token within your meta tags. The HTML might look something like this:spring-doc.cadn.net.cn
CSRF Token in HTML Meta Tag
<html>
<head>
	<meta name="_csrf" content="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
	<meta name="_csrf_header" content="X-CSRF-TOKEN"/>
</head>
</html>
In order to include the CSRF token in the request, you can take advantage of the fact that the CsrfToken is exposed as an HttpServletRequest attribute named _csrf. The following example does this with a JSP:spring-doc.cadn.net.cn
CSRF Token in HTML Meta Tag with Request Attribute
<html>
<head>
	<meta name="_csrf" content="${_csrf.token}"/>
	<!-- default header name is X-CSRF-TOKEN -->
	<meta name="_csrf_header" content="${_csrf.headerName}"/>
</head>
</html>
Once the meta tags contain the CSRF token, the JavaScript code can read the meta tags and include the CSRF token as a header. If you use jQuery, you can do this with the following code:spring-doc.cadn.net.cn
Include CSRF Token in AJAX Request
$(function () {
	var token = $("meta[name='_csrf']").attr("content");
	var header = $("meta[name='_csrf_header']").attr("content");
	$(document).ajaxSend(function(e, xhr, options) {
		xhr.setRequestHeader(header, token);
Other JavaScript Applications
Another option for JavaScript applications is to include the CSRF token in an HTTP response header.spring-doc.cadn.net.cn
One way to achieve this is through the use of a @ControllerAdvice with the CsrfTokenArgumentResolver. The following is an example of @ControllerAdvice that applies to all controller endpoints in the application:spring-doc.cadn.net.cn
CSRF Token in HTTP Response Header
@ControllerAdvice
public class CsrfControllerAdvice {
	@ModelAttribute
	public void getCsrfToken(HttpServletResponse response, CsrfToken csrfToken) {
		response.setHeader(csrfToken.getHeaderName(), csrfToken.getToken());
@ControllerAdvice
	@ModelAttribute
	fun getCsrfToken(response: HttpServletResponse, csrfToken: CsrfToken) {
		response.setHeader(csrfToken.headerName, csrfToken.token)
Because this @ControllerAdvice applies to all endpoints in the application, it will cause the CSRF token to be loaded on every request, which can negate the benefits of deferred tokens when using the HttpSessionCsrfTokenRepository. However, this is not usually an issue when using the CookieCsrfTokenRepository.spring-doc.cadn.net.cn
It is important to remember that controller endpoints and controller advice are called after the Spring Security filter chain. This means that this @ControllerAdvice will only be applied if the request passes through the filter chain to your application. See the configuration for single-page applications for an example of adding a filter to the filter chain for earlier access to the HttpServletResponse.spring-doc.cadn.net.cn
The CSRF token will now be available in a response header (X-CSRF-TOKEN or X-XSRF-TOKEN by default) for any custom endpoints the controller advice applies to. Any request to the backend can be used to obtain the token from the response, and a subsequent request can include the token in a request header with the same name.spring-doc.cadn.net.cn
Mobile Applications
Like JavaScript applications, mobile applications typically use JSON instead of HTML. A backend application that does not serve browser traffic may choose to disable CSRF. In that case, no additional work is required.spring-doc.cadn.net.cn
However, a backend application that also serves browser traffic and therefore still requires CSRF protection may continue to store the CsrfToken in the session instead of in a cookie.spring-doc.cadn.net.cn
In this case, a typical pattern for integrating with the backend is to expose a /csrf endpoint to allow the frontend (mobile or browser client) to request a CSRF token on demand. The benefit of using this pattern is that the CSRF token can continue to be deferred and only needs to be loaded from the session when a request requires CSRF protection. The use of a custom endpoint also means the client application can request that a new token be generated on demand (if necessary) by issuing an explicit request.spring-doc.cadn.net.cn
This pattern can be used for any type of application that requires CSRF protection, not just mobile applications. While this approach isn’t typically required in those cases, it is another option for integrating with a CSRF-protected backend.spring-doc.cadn.net.cn
The following is an example of the /csrf endpoint that makes use of the CsrfTokenArgumentResolver:spring-doc.cadn.net.cn
The /csrf endpoint
@RestController
public class CsrfController {
    @GetMapping("/csrf")
    public CsrfToken csrf(CsrfToken csrfToken) {
        return csrfToken;
@RestController
    fun csrf(csrfToken: CsrfToken): CsrfToken {
        return csrfToken
You may consider adding .requestMatchers("/csrf").permitAll() if the endpoint above is required prior to authenticating with the server.spring-doc.cadn.net.cn
This endpoint should be called to obtain a CSRF token when the application is launched or initialized (e.g. at load time), and also after authentication success and logout success.spring-doc.cadn.net.cn
Once you’ve obtained the CSRF token, you will need to include it as an HTTP request header (one of X-CSRF-TOKEN or X-XSRF-TOKEN by default) yourself.spring-doc.cadn.net.cn
Handle AccessDeniedException
To handle an AccessDeniedException such as InvalidCsrfTokenException, you can configure Spring Security to handle these exceptions in any way you like. For example, you can configure a custom access denied page using the following configuration:spring-doc.cadn.net.cn
Configure AccessDeniedHandler
@EnableWebSecurity
		http
			.exceptionHandling((exceptionHandling) -> exceptionHandling
				.accessDeniedPage("/access-denied")
@EnableWebSecurity
        http {
            exceptionHandling {
                accessDeniedPage = "/access-denied"
        return http.build()
<http>
	<access-denied-handler error-page="/access-denied"/>
</http>
CSRF Testing
You can use Spring Security’s testing support and CsrfRequestPostProcessor to test CSRF protection, like this:spring-doc.cadn.net.cn
Test CSRF Protection
import static org.springframework.security.test.web.servlet.request.SecurityMockMvcRequestPostProcessors.*;
import static org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*;
import static org.springframework.test.web.servlet.request.MockMvcRequestBuilders.*;
import static org.springframework.test.web.servlet.result.MockMvcResultMatchers.*;
@ExtendWith(SpringExtension.class)
@ContextConfiguration(classes = SecurityConfig.class)
@WebAppConfiguration
public class CsrfTests {
	private MockMvc mockMvc;
	@BeforeEach
	public void setUp(WebApplicationContext applicationContext) {
		this.mockMvc = MockMvcBuilders.webAppContextSetup(applicationContext)
			.apply(springSecurity())
	@Test
	public void loginWhenValidCsrfTokenThenSuccess() throws Exception {
		this.mockMvc.perform(post("/login").with(csrf())
				.accept(MediaType.TEXT_HTML)
				.param("username", "user")
				.param("password", "password"))
			.andExpect(status().is3xxRedirection())
			.andExpect(header().string(HttpHeaders.LOCATION, "/"));
	@Test
	public void loginWhenInvalidCsrfTokenThenForbidden() throws Exception {
		this.mockMvc.perform(post("/login").with(csrf().useInvalidToken())
			.andExpect(status().isForbidden());
	@Test
	public void loginWhenMissingCsrfTokenThenForbidden() throws Exception {
	@Test
	@WithMockUser
	public void logoutWhenValidCsrfTokenThenSuccess() throws Exception {
		this.mockMvc.perform(post("/logout").with(csrf())
				.accept(MediaType.TEXT_HTML))
			.andExpect(header().string(HttpHeaders.LOCATION, "/login?logout"));
import org.springframework.security.test.web.servlet.request.SecurityMockMvcRequestPostProcessors.*
import org.springframework.security.test.web.servlet.setup.SecurityMockMvcConfigurers.*
import org.springframework.test.web.servlet.request.MockMvcRequestBuilders.*
import org.springframework.test.web.servlet.result.MockMvcResultMatchers.*
@ExtendWith(SpringExtension::class)
@ContextConfiguration(classes = [SecurityConfig::class])
class CsrfTests {
	private lateinit var mockMvc: MockMvc
	@BeforeEach
	fun setUp(applicationContext: WebApplicationContext) {
			.apply<DefaultMockMvcBuilder>(springSecurity())
			.build()
	@Test
	fun loginWhenValidCsrfTokenThenSuccess() {
			.andExpect(status().is3xxRedirection)
	@Test
	fun loginWhenInvalidCsrfTokenThenForbidden() {
			.andExpect(status().isForbidden)
	@Test
	fun loginWhenMissingCsrfTokenThenForbidden() {
	@Test
	@WithMockUser
	@Throws(Exception::class)
	fun logoutWhenValidCsrfTokenThenSuccess() {
Disable CSRF Protection
By default, CSRF protection is enabled, which affects integrating with the backend and testing your application. Before disabling CSRF protection, consider whether it makes sense for your application.spring-doc.cadn.net.cn
You can also consider whether only certain endpoints do not require CSRF protection and configure an ignoring rule, as in the following example:spring-doc.cadn.net.cn
Ignoring Requests
@EnableWebSecurity
        http
                .ignoringRequestMatchers("/api/*")
@EnableWebSecurity
        http {
            csrf {
        return http.build()
<http>
	<csrf request-matcher-ref="csrfMatcher"/>
</http>
<b:bean id="csrfMatcher"
    class="org.springframework.security.web.util.matcher.AndRequestMatcher">
    <b:constructor-arg value="#{T(org.springframework.security.web.csrf.CsrfFilter).DEFAULT_CSRF_MATCHER}"/>
    <b:constructor-arg>
        <b:bean class="org.springframework.security.web.util.matcher.NegatedRequestMatcher">
            <b:bean class="org.springframework.security.web.util.matcher.AntPathRequestMatcher">
                <b:constructor-arg value="/api/*"/>
            </b:bean>
        </b:bean>
    </b:constructor-arg>
</b:bean>
If you need to disable CSRF protection, you can do so using the following configuration:spring-doc.cadn.net.cn
Disable CSRF
@EnableWebSecurity
		http
			.csrf((csrf) -> csrf.disable());
@EnableWebSecurity
        http {
            csrf {
                disable()
        return http.build()
<http>
	<csrf disabled="true"/>
</http>
CSRF Considerations
There are a few special considerations when implementing protection against CSRF attacks. This section discusses those considerations as they pertain to servlet environments. See CSRF Considerations for a more general discussion.spring-doc.cadn.net.cn
Logging In
It is important to require CSRF for log in requests to protect against forging log in attempts. Spring Security’s servlet support does this out of the box.spring-doc.cadn.net.cn
Logging Out
It is important to require CSRF for log out requests to protect against forging logout attempts. If CSRF protection is enabled (the default), Spring Security’s LogoutFilter will only process HTTP POST requests. This ensures that logging out requires a CSRF token and that a malicious user cannot forcibly log your users out.spring-doc.cadn.net.cn
The easiest approach is to use a form to log the user out. If you really want a link, you can use JavaScript to have the link perform a POST (maybe on a hidden form). For browsers with JavaScript that is disabled, you can optionally have the link take the user to a log out confirmation page that performs the POST.spring-doc.cadn.net.cn
If you really want to use HTTP GET with logout, you can do so. However, remember that this is generally not recommended. For example, the following logs out when the /logout URL is requested with any HTTP method:spring-doc.cadn.net.cn
Log Out with Any HTTP Method
@EnableWebSecurity
		http
			.logout((logout) -> logout
				.logoutRequestMatcher(new AntPathRequestMatcher("/logout"))
@EnableWebSecurity
        http {
            logout {
                logoutRequestMatcher = AntPathRequestMatcher("/logout")
        return http.build()
See the Logout chapter for more information.spring-doc.cadn.net.cn
CSRF and Session Timeouts
By default, Spring Security stores the CSRF token in the HttpSession using the HttpSessionCsrfTokenRepository. This can lead to a situation where the session expires, leaving no CSRF token to validate against.spring-doc.cadn.net.cn
We have already discussed general solutions to session timeouts. This section discusses the specifics of CSRF timeouts as it pertains to the servlet support.spring-doc.cadn.net.cn
You can change the storage of the CSRF token to be in a cookie. For details, see the Using the CookieCsrfTokenRepository section.spring-doc.cadn.net.cn
If a token does expire, you might want to customize how it is handled by specifying a custom AccessDeniedHandler. The custom AccessDeniedHandler can process the InvalidCsrfTokenException any way you like.spring-doc.cadn.net.cn
Multipart (file upload)
We have already discussed how protecting multipart requests (file uploads) from CSRF attacks causes a chicken and the egg problem. When JavaScript is available, we recommend including the CSRF token in an HTTP request header to side-step the issue.spring-doc.cadn.net.cn
If JavaScript is not available, the following sections discuss options for placing the CSRF token in the body and url within a servlet application.spring-doc.cadn.net.cn
You can find more information about using multipart forms with Spring in the Multipart Resolver section of the Spring reference and the MultipartFilter javadoc.spring-doc.cadn.net.cn
Place CSRF Token in the Body
We have already discussed the tradeoffs of placing the CSRF token in the body. In this section, we discuss how to configure Spring Security to read the CSRF from the body.spring-doc.cadn.net.cn
To read the CSRF token from the body, the MultipartFilter is specified before the Spring Security filter. Specifying the MultipartFilter before the Spring Security filter means that there is no authorization for invoking the MultipartFilter, which means anyone can place temporary files on your server. However, only authorized users can submit a file that is processed by your application. In general, this is the recommended approach because the temporary file upload should have a negligible impact on most servers.spring-doc.cadn.net.cn
Configure MultipartFilter
public class SecurityApplicationInitializer extends AbstractSecurityWebApplicationInitializer {
	protected void beforeSpringSecurityFilterChain(ServletContext servletContext) {
		insertFilters(servletContext, new MultipartFilter());
class SecurityApplicationInitializer : AbstractSecurityWebApplicationInitializer() {
    override fun beforeSpringSecurityFilterChain(servletContext: ServletContext?) {
        insertFilters(servletContext, MultipartFilter())
<filter>
	<filter-name>MultipartFilter</filter-name>
	<filter-class>org.springframework.web.multipart.support.MultipartFilter</filter-class>
</filter>
<filter>
	<filter-name>springSecurityFilterChain</filter-name>
	<filter-class>org.springframework.web.filter.DelegatingFilterProxy</filter-class>
</filter>
<filter-mapping>
	<url-pattern>/*</url-pattern>
</filter-mapping>
<filter-mapping>
</filter-mapping>
To ensure that MultipartFilter is specified before the Spring Security filter with XML configuration, you can ensure the <filter-mapping> element of the MultipartFilter is placed before the springSecurityFilterChain within the web.xml file.spring-doc.cadn.net.cn
Include a CSRF Token in a URL
If letting unauthorized users upload temporary files is not acceptable, an alternative is to place the MultipartFilter after the Spring Security filter and include the CSRF as a query parameter in the action attribute of the form. Since the CsrfToken is exposed as an HttpServletRequest attribute named _csrf, we can use that to create an action with the CSRF token in it. The following example does this with a JSP:spring-doc.cadn.net.cn
CSRF Token in Action
<form method="post"
	action="./upload?${_csrf.parameterName}=${_csrf.token}"
	enctype="multipart/form-data">
HiddenHttpMethodFilter
We have already discussed the trade-offs of placing the CSRF token in the body.spring-doc.cadn.net.cn
In Spring’s Servlet support, overriding the HTTP method is done by using HiddenHttpMethodFilter. You can find more information in the HTTP Method Conversion section of the reference documentation.spring-doc.cadn.net.cn
Further Reading
Now that you have reviewed CSRF protection, consider learning more about exploit protection including secure headers and the HTTP firewall or move on to learning how to test your application.spring-doc.cadn.net.cn
