对于每个成功或失败的身份验证,将分别触发 或 。AuthenticationSuccessEventAuthenticationFailureEvent
若要侦听这些事件,必须首先发布 . Spring Security 可以很好地实现此目的:AuthenticationEventPublisherDefaultAuthenticationEventPublisher
  • Java
  • Kotlin
public AuthenticationEventPublisher authenticationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new DefaultAuthenticationEventPublisher(applicationEventPublisher);
fun authenticationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthenticationEventPublisher {
    return DefaultAuthenticationEventPublisher(applicationEventPublisher)
然后,您可以使用 Spring 的支持:@EventListener
  • Java
  • Kotlin
@Component
public class AuthenticationEvents {
	@EventListener
    public void onSuccess(AuthenticationSuccessEvent success) {
    @EventListener
    public void onFailure(AbstractAuthenticationFailureEvent failures) {
@Component
    @EventListener
    fun onSuccess(success: AuthenticationSuccessEvent?) {
    @EventListener
    fun onFailure(failures: AbstractAuthenticationFailureEvent?) {
虽然与 和 类似,但它们很好,因为它们可以独立于 servlet API 使用。AuthenticationSuccessHandlerAuthenticationFailureHandler
添加异常映射
默认情况下,为以下事件发布 an:DefaultAuthenticationEventPublisherAuthenticationFailureEvent
例外
事件
BadCredentialsException
AuthenticationFailureBadCredentialsEvent
UsernameNotFoundException
AccountExpiredException
AuthenticationFailureExpiredEvent
ProviderNotFoundException
AuthenticationFailureProviderNotFoundEvent
DisabledException
AuthenticationFailureDisabledEvent
LockedException
AuthenticationFailureLockedEvent
AuthenticationServiceException
AuthenticationFailureServiceExceptionEvent
CredentialsExpiredException
AuthenticationFailureCredentialsExpiredEvent
InvalidBearerTokenException
发布者执行完全匹配,这意味着这些异常的子类不会生成事件。Exception
为此,您可能希望通过以下方法向发布者提供其他映射:setAdditionalExceptionMappings
  • Java
  • Kotlin
    Map<Class<? extends AuthenticationException>,
        Class<? extends AbstractAuthenticationFailureEvent>> mapping =
            Collections.singletonMap(FooException.class, FooEvent.class);
    AuthenticationEventPublisher authenticationEventPublisher =
    authenticationEventPublisher.setAdditionalExceptionMappings(mapping);
    return authenticationEventPublisher;
    val mapping: Map<Class<out AuthenticationException>, Class<out AbstractAuthenticationFailureEvent>> =
            mapOf(Pair(FooException::class.java, FooEvent::class.java))
    val authenticationEventPublisher = DefaultAuthenticationEventPublisher(applicationEventPublisher)
例外
事件
DisabledException
LockedException
默认事件
您还可以提供一个 catch-all 事件,以便在以下情况下触发:AuthenticationException
  • Java
  • Kotlin
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent
        (GenericAuthenticationFailureEvent.class);
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent(GenericAuthenticationFailureEvent::class.java)
