Spring Security 与 Spring Observability 集成,开箱即用,用于跟踪;尽管配置收集指标也非常简单。
描图
当存在 Bean 时,Spring Security 会为以下内容创建跟踪:ObservationRegistry
  • 过滤链
  • ReactiveAuthenticationManager
  • ReactiveAuthorizationManager
引导集成
例如,考虑一个简单的 Boot 应用程序:
  • Java
  • Kotlin
@SpringBootApplication
public class MyApplication {
	public ReactiveUserDetailsService userDetailsService() {
		return new MapReactiveUserDetailsManager(
				User.withDefaultPasswordEncoder()
						.username("user")
						.password("password")
						.authorities("app")
						.build()
	ObservationRegistryCustomizer<ObservationRegistry> addTextHandler() {
		return (registry) -> registry.observationConfig().observationHandler(new ObservationTextPublisher());
		SpringApplication.run(ListenerSamplesApplication.class, args);
	fun userDetailsService(): ReactiveUserDetailsService {
						.username("user")
						.authorities("app")
						.build()
	fun addTextHandler(): ObservationRegistryCustomizer<ObservationRegistry> {
		return registry: ObservationRegistry -> registry.observationConfig()
				.observationHandler(ObservationTextPublisher());
	fun main(args: Array<String>) {
		runApplication<MyApplication>(*args)
以及相应的请求:
?> http -a user:password :8080
将生成以下输出(为清楚起见,添加了缩进):
START - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@5dfdb78', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.00191856, duration(nanos)=1918560.0, startTimeNanos=101177265022745}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@121549e0']
	START - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='before'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@3932a48c', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=4.65777E-4, duration(nanos)=465777.0, startTimeNanos=101177276300777}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@562db70f']
	STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='before'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@3932a48c', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.003733105, duration(nanos)=3733105.0, startTimeNanos=101177276300777}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@562db70f']
		START - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='UserDetailsRepositoryReactiveAuthenticationManager', authentication.request.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@574ba6cd', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.21015E-4, duration(nanos)=321015.0, startTimeNanos=101177336038417}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@49202cc7']
		STOP - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='UserDetailsRepositoryReactiveAuthenticationManager', authentication.request.type='UsernamePasswordAuthenticationToken', authentication.result.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@574ba6cd', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.37574992, duration(nanos)=3.7574992E8, startTimeNanos=101177336038417}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@49202cc7']
		START - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[object.type='SecurityContextServerWebExchange'], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@6f837332', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=2.65687E-4, duration(nanos)=265687.0, startTimeNanos=101177777941381}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@7f5bc7cb']
		STOP - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[authorization.decision='true', object.type='SecurityContextServerWebExchange'], highCardinalityKeyValues=[authentication.authorities='[app]', authorization.decision.details='AuthorizationDecision [granted=true]'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@6f837332', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.039239047, duration(nanos)=3.9239047E7, startTimeNanos=101177777941381}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@7f5bc7cb']
		START - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@2f33dfae', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.1775E-4, duration(nanos)=317750.0, startTimeNanos=101177821377592}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@63b0d28f']
		STOP - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@2f33dfae', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.219901971, duration(nanos)=2.19901971E8, startTimeNanos=101177821377592}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@63b0d28f']
	START - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='after'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@40b25623', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.25118E-4, duration(nanos)=325118.0, startTimeNanos=101178044824275}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@3b6cec2']
	STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.size='14', filter.section='after'], highCardinalityKeyValues=[request.line='/'], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@40b25623', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.001693146, duration(nanos)=1693146.0, startTimeNanos=101178044824275}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@3b6cec2']
STOP - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.tracing.handler.TracingObservationHandler$TracingContext='io.micrometer.tracing.handler.TracingObservationHandler$TracingContext@5dfdb78', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.784320641, duration(nanos)=7.84320641E8, startTimeNanos=101177265022745}', class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@121549e0']
手动配置
对于非 Spring Boot 应用程序,或者要覆盖现有的 Boot 配置,您可以发布自己的应用程序,Spring Security 仍将选择它。ObservationRegistry
  • Java
  • Kotlin
  • Xml
						.username("user")
						.authorities("app")
						.build()
	ObservationRegistry<ObservationRegistry> observationRegistry() {
		ObservationRegistry registry = ObservationRegistry.create();
		return registry;
						.username("user")
						.authorities("app")
						.build()
	fun observationRegistry(): ObservationRegistry<ObservationRegistry> {
		registry.observationConfig().observationHandler(ObservationTextPublisher())
		return registry
<sec:http auto-config="true" observation-registry-ref="ref">
	<sec:intercept-url pattern="/**" access="authenticated"/>
</sec:http>
<!-- define and configure ObservationRegistry bean -->
禁用可观测性
如果您不需要任何 Spring Security 观察结果,可以在 Spring Boot 应用程序中发布 . 但是,这可能会关闭不仅仅是 Spring Security 的观察。ObservationRegistry.NOOP@Bean
相反,您可以使用如下所示更改提供的内容:ObservationRegistryObservationPredicate
  • Java
  • Kotlin
ObservationRegistryCustomizer<ObservationRegistry> noSpringSecurityObservations() {
	ObservationPredicate predicate = (name, context) -> !name.startsWith("spring.security.");
	return (registry) -> registry.observationConfig().observationPredicate(predicate);
fun noSpringSecurityObservations(): ObservationRegistryCustomizer<ObservationRegistry> {
	ObservationPredicate predicate = (name: String, context: Observation.Context) -> !name.startsWith("spring.security.")
	(registry: ObservationRegistry) -> registry.observationConfig().observationPredicate(predicate)
没有用于禁用具有 XML 支持的观察任务的工具。 相反,只需不设置属性即可。observation-registry-ref
跟踪列表
Spring Security 跟踪每个请求的以下跨度:
  1. spring.security.http.requests- 包装整个筛选器链(包括请求)的跨度
  2. spring.security.http.chains.before- 包裹安全过滤器接收部分的跨度
  3. spring.security.http.chains.after- 包装安全过滤器返回部分的跨度
  4. spring.security.http.secured.requests- 包装现在受保护的应用程序请求的跨度
  5. spring.security.http.unsecured.requests- 包装Spring Security不保护的请求的跨度
  6. spring.security.authentications- 包装身份验证尝试的跨度
  7. spring.security.authorizations- 包装授权尝试的跨度
spring.security.http.chains.before + spring.security.http.secured.requests + spring.security.http.chains.after = spring.security.http.requests spring.security.http.chains.before + spring.security.http.chains.after= Spring Security 的请求部分
