与 Servlet X.509 身份验证类似,反应式 x509 身份验证过滤器允许从客户端提供的证书中提取身份验证令牌。
以下示例显示了反应式 x509 安全配置:
Java
Kotlin
public SecurityWebFilterChain securityWebFilterChain(ServerHttpSecurity http) {
http
.x509(withDefaults())
.authorizeExchange(exchanges -> exchanges
.anyExchange().permitAll()
return http.build();
fun securityWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
return http {
x509 { }
authorizeExchange {
在上述配置中,如果既未提供也不提供,则使用默认值。默认主体提取器是 ,它从客户端提供的证书中提取 CN(公用名)字段。缺省身份验证管理器是 ,它执行用户帐户验证,检查具有提取者名称的用户帐户是否存在,并且该帐户未被锁定、禁用或过期。principalExtractor
authenticationManager
SubjectDnX509PrincipalExtractor
ReactivePreAuthenticatedAuthenticationManager
principalExtractor
以下示例演示了如何重写这些默认值:
Java
Kotlin
SubjectDnX509PrincipalExtractor principalExtractor =
new SubjectDnX509PrincipalExtractor();
principalExtractor.setSubjectDnRegex("OU=(.*?)(?:,|$)");
ReactiveAuthenticationManager authenticationManager = authentication -> {
authentication.setAuthenticated("Trusted Org Unit".equals(authentication.getName()));
return Mono.just(authentication);
http
.x509(x509 -> x509
.principalExtractor(principalExtractor)
.authenticationManager(authenticationManager)
fun securityWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain? {
val customPrincipalExtractor = SubjectDnX509PrincipalExtractor()
customPrincipalExtractor.setSubjectDnRegex("OU=(.*?)(?:,|$)")
val customAuthenticationManager = ReactiveAuthenticationManager { authentication: Authentication ->
authentication.isAuthenticated = "Trusted Org Unit" == authentication.name
return http {
x509 {
principalExtractor = customPrincipalExtractor
authenticationManager = customAuthenticationManager
authorizeExchange {
在前面的示例中,从客户端证书的 OU 字段(而不是 CN)中提取用户名,并且根本不执行帐户查找。相反,如果提供的证书颁发给名为“受信任的组织单位”的 OU,则会对请求进行身份验证。ReactiveUserDetailsService
有关将 Netty 和/或命令行工具配置为使用双向 TLS 并启用 X.509 身份验证的示例,请参阅 github.com/spring-projects/spring-security-samples/tree/main/servlet/java-configuration/authentication/x509。WebClient
curl
