For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Authorization Grant Support
This section describes Spring Security’s support for authorization grants.spring-doc.cn
Authorization Code
See the OAuth 2.0 Authorization Framework for further details on the Authorization Code grant.spring-doc.cn
Obtaining Authorization
See the Authorization Request/Response protocol flow for the Authorization Code grant.spring-doc.cn
Initiating the Authorization Request
The OAuth2AuthorizationRequestRedirectFilter uses an OAuth2AuthorizationRequestResolver to resolve an OAuth2AuthorizationRequest and initiate the Authorization Code grant flow by redirecting the end-user’s user-agent to the Authorization Server’s Authorization Endpoint.spring-doc.cn
The primary role of the OAuth2AuthorizationRequestResolver is to resolve an OAuth2AuthorizationRequest from the provided web request. The default implementation DefaultOAuth2AuthorizationRequestResolver matches on the (default) path /oauth2/authorization/{registrationId}, extracting the registrationId, and using it to build the OAuth2AuthorizationRequest for the associated ClientRegistration.spring-doc.cn
Consider the following Spring Boot 2.x properties for an OAuth 2.0 Client registration:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            client-id: okta-client-id
            authorization-grant-type: authorization_code
            redirect-uri: "{baseUrl}/authorized/okta"
            scope: read, write
        provider:
          okta:
            authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize
            token-uri: https://dev-1234.oktapreview.com/oauth2/v1/token
Given the preceding properties, a request with the base path /oauth2/authorization/okta initiates the Authorization Request redirect by the OAuth2AuthorizationRequestRedirectFilter and ultimately starts the Authorization Code grant flow.spring-doc.cn
The AuthorizationCodeOAuth2AuthorizedClientProvider is an implementation of OAuth2AuthorizedClientProvider for the Authorization Code grant, which also initiates the Authorization Request redirect by the OAuth2AuthorizationRequestRedirectFilter.spring-doc.cn
If the OAuth 2.0 Client is a Public Client, configure the OAuth 2.0 Client registration as follows:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            client-authentication-method: none
Public Clients are supported by using Proof Key for Code Exchange (PKCE). If the client is running in an untrusted environment (such as a native application or web browser-based application) and is therefore incapable of maintaining the confidentiality of its credentials, PKCE is automatically used when the following conditions are true:spring-doc.cn
  1. client-secret is omitted (or empty)spring-doc.cn
  2. client-authentication-method is set to none (ClientAuthenticationMethod.NONE)spring-doc.cn
If the OAuth 2.0 Provider supports PKCE for Confidential Clients, you may (optionally) configure it using DefaultOAuth2AuthorizationRequestResolver.setAuthorizationRequestCustomizer(OAuth2AuthorizationRequestCustomizers.withPkce()).
The DefaultOAuth2AuthorizationRequestResolver also supports URI template variables for the redirect-uri by using UriComponentsBuilder.spring-doc.cn
The following configuration uses all the supported URI template variables:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            redirect-uri: "{baseScheme}://{baseHost}{basePort}{basePath}/authorized/{registrationId}"
{baseUrl} resolves to {baseScheme}://{baseHost}{basePort}{basePath}spring-doc.cn
Configuring the redirect-uri with URI template variables is especially useful when the OAuth 2.0 Client is running behind a Proxy Server. Doing so ensures that the X-Forwarded-* headers are used when expanding the redirect-uri.spring-doc.cn
Customizing the Authorization Request
One of the primary use cases an OAuth2AuthorizationRequestResolver can realize is the ability to customize the Authorization Request with additional parameters above the standard parameters defined in the OAuth 2.0 Authorization Framework.spring-doc.cn
For example, OpenID Connect defines additional OAuth 2.0 request parameters for the Authorization Code Flow extending from the standard parameters defined in the OAuth 2.0 Authorization Framework. One of those extended parameters is the prompt parameter.spring-doc.cn
The prompt parameter is optional. Space delimited, case sensitive list of ASCII string values that specifies whether the Authorization Server prompts the End-User for re-authentication and consent. The defined values are: none, login, consent, and select_account.spring-doc.cn
The following example shows how to configure the DefaultOAuth2AuthorizationRequestResolver with a Consumer<OAuth2AuthorizationRequest.Builder> that customizes the Authorization Request for oauth2Login(), by including the request parameter prompt=consent.spring-doc.cn
@EnableWebSecurity
public class OAuth2LoginSecurityConfig {
	@Autowired
	private ClientRegistrationRepository clientRegistrationRepository;
		http
				.anyRequest().authenticated()
			.oauth2Login(oauth2 -> oauth2
				.authorizationEndpoint(authorization -> authorization
					.authorizationRequestResolver(
						authorizationRequestResolver(this.clientRegistrationRepository)
		return http.build();
	private OAuth2AuthorizationRequestResolver authorizationRequestResolver(
			ClientRegistrationRepository clientRegistrationRepository) {
		DefaultOAuth2AuthorizationRequestResolver authorizationRequestResolver =
				new DefaultOAuth2AuthorizationRequestResolver(
						clientRegistrationRepository, "/oauth2/authorization");
		authorizationRequestResolver.setAuthorizationRequestCustomizer(
				authorizationRequestCustomizer());
		return  authorizationRequestResolver;
	private Consumer<OAuth2AuthorizationRequest.Builder> authorizationRequestCustomizer() {
		return customizer -> customizer
					.additionalParameters(params -> params.put("prompt", "consent"));
@EnableWebSecurity
class SecurityConfig {
    @Autowired
    private lateinit var customClientRegistrationRepository: ClientRegistrationRepository
        http {
            authorizeRequests {
            oauth2Login {
                authorizationEndpoint {
                    authorizationRequestResolver = authorizationRequestResolver(customClientRegistrationRepository)
        return http.build()
    private fun authorizationRequestResolver(
            clientRegistrationRepository: ClientRegistrationRepository?): OAuth2AuthorizationRequestResolver? {
        val authorizationRequestResolver = DefaultOAuth2AuthorizationRequestResolver(
    private fun authorizationRequestCustomizer(): Consumer<OAuth2AuthorizationRequest.Builder> {
        return Consumer { customizer ->
            customizer
                    .additionalParameters { params -> params["prompt"] = "consent" }
For the simple use case where the additional request parameter is always the same for a specific provider, you can add it directly in the authorization-uri property.spring-doc.cn
For example, if the value for the request parameter prompt is always consent for the provider okta, you can configure it as follows:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        provider:
          okta:
            authorization-uri: https://dev-1234.oktapreview.com/oauth2/v1/authorize?prompt=consent
The preceding example shows the common use case of adding a custom parameter on top of the standard parameters. Alternatively, if your requirements are more advanced, you can take full control in building the Authorization Request URI by overriding the OAuth2AuthorizationRequest.authorizationRequestUri property.spring-doc.cn
OAuth2AuthorizationRequest.Builder.build() constructs the OAuth2AuthorizationRequest.authorizationRequestUri, which represents the Authorization Request URI including all query parameters using the application/x-www-form-urlencoded format.spring-doc.cn
The following example shows a variation of authorizationRequestCustomizer() from the preceding example and instead overrides the OAuth2AuthorizationRequest.authorizationRequestUri property:spring-doc.cn
				.authorizationRequestUri(uriBuilder -> uriBuilder
					.queryParam("prompt", "consent").build());
    return Consumer { customizer: OAuth2AuthorizationRequest.Builder ->
        customizer
                .authorizationRequestUri { uriBuilder: UriBuilder ->
                    uriBuilder
Storing the Authorization Request
The AuthorizationRequestRepository is responsible for the persistence of the OAuth2AuthorizationRequest from the time the Authorization Request is initiated to the time the Authorization Response is received (the callback).spring-doc.cn
The OAuth2AuthorizationRequest is used to correlate and validate the Authorization Response.spring-doc.cn
The default implementation of AuthorizationRequestRepository is HttpSessionOAuth2AuthorizationRequestRepository, which stores the OAuth2AuthorizationRequest in the HttpSession.spring-doc.cn
If you have a custom implementation of AuthorizationRequestRepository, you can configure it as follows:spring-doc.cn
AuthorizationRequestRepository Configuration
@EnableWebSecurity
public class OAuth2ClientSecurityConfig {
		http
			.oauth2Client(oauth2 -> oauth2
				.authorizationCodeGrant(codeGrant -> codeGrant
					.authorizationRequestRepository(this.authorizationRequestRepository())
                .authorizationEndpoint(endpoint -> endpoint
            ).build();
    public AuthorizationRequestRepository<OAuth2AuthorizationRequest> authorizationRequestRepository() {
        return new CustomOAuth2AuthorizationRequestRepository();
@EnableWebSecurity
        http {
            oauth2Client {
                authorizationCodeGrant {
                    authorizationRequestRepository = authorizationRequestRepository()
        return http.build()
<http>
	<oauth2-client>
		<authorization-code-grant authorization-request-repository-ref="authorizationRequestRepository"/>
	</oauth2-client>
</http>
Requesting an Access Token
See the Access Token Request/Response protocol flow for the Authorization Code grant.spring-doc.cn
The default implementation of OAuth2AccessTokenResponseClient for the Authorization Code grant is DefaultAuthorizationCodeTokenResponseClient, which uses a RestOperations instance to exchange an authorization code for an access token at the Authorization Server’s Token Endpoint.spring-doc.cn
The DefaultAuthorizationCodeTokenResponseClient is flexible, as it lets you customize the pre-processing of the Token Request and/or post-handling of the Token Response.spring-doc.cn
Customizing the Access Token Request
If you need to customize the pre-processing of the Token Request, you can provide DefaultAuthorizationCodeTokenResponseClient.setRequestEntityConverter() with a custom Converter<OAuth2AuthorizationCodeGrantRequest, RequestEntity<?>>. The default implementation (OAuth2AuthorizationCodeGrantRequestEntityConverter) builds a RequestEntity representation of a standard OAuth 2.0 Access Token Request. However, providing a custom Converter would let you extend the standard Token Request and add custom parameter(s).spring-doc.cn
To customize only the parameters of the request, you can provide OAuth2AuthorizationCodeGrantRequestEntityConverter.setParametersConverter() with a custom Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity directly.spring-doc.cn
If you prefer to only add additional parameters, you can provide OAuth2AuthorizationCodeGrantRequestEntityConverter.addParametersConverter() with a custom Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter.spring-doc.cn
The custom Converter must return a valid RequestEntity representation of an OAuth 2.0 Access Token Request that is understood by the intended OAuth 2.0 Provider.spring-doc.cn
Customizing the Access Token Response
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultAuthorizationCodeTokenResponseClient.setRestOperations() with a custom configured RestOperations. The default RestOperations is configured as follows:spring-doc.cn
RestTemplate restTemplate = new RestTemplate(Arrays.asList(
		new FormHttpMessageConverter(),
		new OAuth2AccessTokenResponseHttpMessageConverter()));
restTemplate.setErrorHandler(new OAuth2ErrorResponseErrorHandler());
val restTemplate = RestTemplate(listOf(
restTemplate.errorHandler = OAuth2ErrorResponseErrorHandler()
Spring MVC FormHttpMessageConverter is required, as it is used when sending the OAuth 2.0 Access Token Request.spring-doc.cn
OAuth2AccessTokenResponseHttpMessageConverter is an HttpMessageConverter for an OAuth 2.0 Access Token Response. You can provide OAuth2AccessTokenResponseHttpMessageConverter.setAccessTokenResponseConverter() with a custom Converter<Map<String, Object>, OAuth2AccessTokenResponse> that is used for converting the OAuth 2.0 Access Token Response parameters to an OAuth2AccessTokenResponse.spring-doc.cn
OAuth2ErrorResponseErrorHandler is a ResponseErrorHandler that can handle an OAuth 2.0 Error, such as 400 Bad Request. It uses an OAuth2ErrorHttpMessageConverter for converting the OAuth 2.0 Error parameters to an OAuth2Error.spring-doc.cn
Whether you customize DefaultAuthorizationCodeTokenResponseClient or provide your own implementation of OAuth2AccessTokenResponseClient, you need to configure it as follows:spring-doc.cn
Access Token Response Configuration
@EnableWebSecurity
		http
					.accessTokenResponseClient(this.accessTokenResponseClient())
@EnableWebSecurity
        http {
            oauth2Client {
                    accessTokenResponseClient = accessTokenResponseClient()
        return http.build()
<http>
	<oauth2-client>
		<authorization-code-grant access-token-response-client-ref="accessTokenResponseClient"/>
	</oauth2-client>
</http>
Refresh Token
See the OAuth 2.0 Authorization Framework for further details on the Refresh Token.spring-doc.cn
Refreshing an Access Token
See the Access Token Request/Response protocol flow for the Refresh Token grant.spring-doc.cn
The default implementation of OAuth2AccessTokenResponseClient for the Refresh Token grant is DefaultRefreshTokenTokenResponseClient, which uses a RestOperations when refreshing an access token at the Authorization Server’s Token Endpoint.spring-doc.cn
The DefaultRefreshTokenTokenResponseClient is flexible, as it lets you customize the pre-processing of the Token Request or post-handling of the Token Response.spring-doc.cn
If you need to customize the pre-processing of the Token Request, you can provide DefaultRefreshTokenTokenResponseClient.setRequestEntityConverter() with a custom Converter<OAuth2RefreshTokenGrantRequest, RequestEntity<?>>. The default implementation (OAuth2RefreshTokenGrantRequestEntityConverter) builds a RequestEntity representation of a standard OAuth 2.0 Access Token Request. However, providing a custom Converter would let you extend the standard Token Request and add custom parameter(s).spring-doc.cn
To customize only the parameters of the request, you can provide OAuth2RefreshTokenGrantRequestEntityConverter.setParametersConverter() with a custom Converter<OAuth2RefreshTokenGrantRequest, MultiValueMap<String, String>> to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity directly.spring-doc.cn
If you prefer to only add additional parameters, you can provide OAuth2RefreshTokenGrantRequestEntityConverter.addParametersConverter() with a custom Converter<OAuth2RefreshTokenGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter.spring-doc.cn
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultRefreshTokenTokenResponseClient.setRestOperations() with a custom configured RestOperations. The default RestOperations is configured as follows:spring-doc.cn
OAuth2AccessTokenResponseHttpMessageConverter is a HttpMessageConverter for an OAuth 2.0 Access Token Response. You can provide OAuth2AccessTokenResponseHttpMessageConverter.setAccessTokenResponseConverter() with a custom Converter<Map<String, Object>, OAuth2AccessTokenResponse> that is used for converting the OAuth 2.0 Access Token Response parameters to an OAuth2AccessTokenResponse.spring-doc.cn
Whether you customize DefaultRefreshTokenTokenResponseClient or provide your own implementation of OAuth2AccessTokenResponseClient, you need to configure it as follows:spring-doc.cn
// Customize
OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> refreshTokenTokenResponseClient = ...
OAuth2AuthorizedClientProvider authorizedClientProvider =
		OAuth2AuthorizedClientProviderBuilder.builder()
				.authorizationCode()
				.refreshToken(configurer -> configurer.accessTokenResponseClient(refreshTokenTokenResponseClient))
authorizedClientManager.setAuthorizedClientProvider(authorizedClientProvider);
// Customize
val refreshTokenTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> = ...
val authorizedClientProvider = OAuth2AuthorizedClientProviderBuilder.builder()
        .refreshToken { it.accessTokenResponseClient(refreshTokenTokenResponseClient) }
        .build()
OAuth2AuthorizedClientProviderBuilder.builder().refreshToken() configures a RefreshTokenOAuth2AuthorizedClientProvider, which is an implementation of an OAuth2AuthorizedClientProvider for the Refresh Token grant.spring-doc.cn
The OAuth2RefreshToken can optionally be returned in the Access Token Response for the authorization_code and password grant types. If the OAuth2AuthorizedClient.getRefreshToken() is available and the OAuth2AuthorizedClient.getAccessToken() is expired, it is automatically refreshed by the RefreshTokenOAuth2AuthorizedClientProvider.spring-doc.cn
Client Credentials
Please refer to the OAuth 2.0 Authorization Framework for further details on the Client Credentials grant.
See the OAuth 2.0 Authorization Framework for further details on the Client Credentials grant.spring-doc.cn
The default implementation of OAuth2AccessTokenResponseClient for the Client Credentials grant is DefaultClientCredentialsTokenResponseClient, which uses a RestOperations when requesting an access token at the Authorization Server’s Token Endpoint.spring-doc.cn
The DefaultClientCredentialsTokenResponseClient is flexible, as it lets you customize the pre-processing of the Token Request or post-handling of the Token Response.spring-doc.cn
If you need to customize the pre-processing of the Token Request, you can provide DefaultClientCredentialsTokenResponseClient.setRequestEntityConverter() with a custom Converter<OAuth2ClientCredentialsGrantRequest, RequestEntity<?>>. The default implementation (OAuth2ClientCredentialsGrantRequestEntityConverter) builds a RequestEntity representation of a standard OAuth 2.0 Access Token Request. However, providing a custom Converter would let you extend the standard Token Request and add custom parameter(s).spring-doc.cn
To customize only the parameters of the request, you can provide OAuth2ClientCredentialsGrantRequestEntityConverter.setParametersConverter() with a custom Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity directly.spring-doc.cn
If you prefer to only add additional parameters, you can provide OAuth2ClientCredentialsGrantRequestEntityConverter.addParametersConverter() with a custom Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter.spring-doc.cn
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultClientCredentialsTokenResponseClient.setRestOperations() with a custom configured RestOperations. The default RestOperations is configured as follows:spring-doc.cn
OAuth2ErrorResponseErrorHandler is a ResponseErrorHandler that can handle an OAuth 2.0 Error, such as 400 Bad Request. It uses an OAuth2ErrorHttpMessageConverter to convert the OAuth 2.0 Error parameters to an OAuth2Error.spring-doc.cn
Whether you customize DefaultClientCredentialsTokenResponseClient or provide your own implementation of OAuth2AccessTokenResponseClient, you need to configure it as follows:spring-doc.cn
// Customize
OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> clientCredentialsTokenResponseClient = ...
				.clientCredentials(configurer -> configurer.accessTokenResponseClient(clientCredentialsTokenResponseClient))
// Customize
val clientCredentialsTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> = ...
        .clientCredentials { it.accessTokenResponseClient(clientCredentialsTokenResponseClient) }
        .build()
OAuth2AuthorizedClientProviderBuilder.builder().clientCredentials() configures a ClientCredentialsOAuth2AuthorizedClientProvider, which is an implementation of an OAuth2AuthorizedClientProvider for the Client Credentials grant.spring-doc.cn
Using the Access Token
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            authorization-grant-type: client_credentials
            scope: read, write
        provider:
          okta:
Further consider the following OAuth2AuthorizedClientManager @Bean:spring-doc.cn
public OAuth2AuthorizedClientManager authorizedClientManager(
		ClientRegistrationRepository clientRegistrationRepository,
		OAuth2AuthorizedClientRepository authorizedClientRepository) {
	DefaultOAuth2AuthorizedClientManager authorizedClientManager =
			new DefaultOAuth2AuthorizedClientManager(
					clientRegistrationRepository, authorizedClientRepository);
	return authorizedClientManager;
fun authorizedClientManager(
        clientRegistrationRepository: ClientRegistrationRepository,
        authorizedClientRepository: OAuth2AuthorizedClientRepository): OAuth2AuthorizedClientManager {
            .build()
    val authorizedClientManager = DefaultOAuth2AuthorizedClientManager(
Given the preceding properties and bean, you can obtain the OAuth2AccessToken as follows:spring-doc.cn
@Controller
	@Autowired
	private OAuth2AuthorizedClientManager authorizedClientManager;
	@GetMapping("/")
	public String index(Authentication authentication,
						HttpServletRequest servletRequest,
						HttpServletResponse servletResponse) {
		OAuth2AuthorizeRequest authorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
				.principal(authentication)
				.attributes(attrs -> {
					attrs.put(HttpServletRequest.class.getName(), servletRequest);
					attrs.put(HttpServletResponse.class.getName(), servletResponse);
		OAuth2AuthorizedClient authorizedClient = this.authorizedClientManager.authorize(authorizeRequest);
		OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
		return "index";
    @Autowired
    private lateinit var authorizedClientManager: OAuth2AuthorizedClientManager
    @GetMapping("/")
    fun index(authentication: Authentication?,
              servletRequest: HttpServletRequest,
              servletResponse: HttpServletResponse): String {
        val authorizeRequest: OAuth2AuthorizeRequest = OAuth2AuthorizeRequest.withClientRegistrationId("okta")
                .attributes(Consumer { attrs: MutableMap<String, Any> ->
                    attrs[HttpServletRequest::class.java.name] = servletRequest
                    attrs[HttpServletResponse::class.java.name] = servletResponse
                .build()
        val authorizedClient = authorizedClientManager.authorize(authorizeRequest)
        val accessToken: OAuth2AccessToken = authorizedClient.accessToken
        return "index"
HttpServletRequest and HttpServletResponse are both OPTIONAL attributes. If not provided, they default to ServletRequestAttributes by using RequestContextHolder.getRequestAttributes().spring-doc.cn
Resource Owner Password Credentials
See the OAuth 2.0 Authorization Framework for further details on the Resource Owner Password Credentials grant.spring-doc.cn
See the Access Token Request/Response protocol flow for the Resource Owner Password Credentials grant.spring-doc.cn
The default implementation of OAuth2AccessTokenResponseClient for the Resource Owner Password Credentials grant is DefaultPasswordTokenResponseClient, which uses a RestOperations when requesting an access token at the Authorization Server’s Token Endpoint.spring-doc.cn
The DefaultPasswordTokenResponseClient is flexible, as it lets you customize the pre-processing of the Token Request or post-handling of the Token Response.spring-doc.cn
If you need to customize the pre-processing of the Token Request, you can provide DefaultPasswordTokenResponseClient.setRequestEntityConverter() with a custom Converter<OAuth2PasswordGrantRequest, RequestEntity<?>>. The default implementation (OAuth2PasswordGrantRequestEntityConverter) builds a RequestEntity representation of a standard OAuth 2.0 Access Token Request. However, providing a custom Converter would let you extend the standard Token Request and add custom parameter(s).spring-doc.cn
To customize only the parameters of the request, you can provide OAuth2PasswordGrantRequestEntityConverter.setParametersConverter() with a custom Converter<OAuth2PasswordGrantRequest, MultiValueMap<String, String>> to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity directly.spring-doc.cn
If you prefer to only add additional parameters, you can provide OAuth2PasswordGrantRequestEntityConverter.addParametersConverter() with a custom Converter<OAuth2PasswordGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter.spring-doc.cn
On the other end, if you need to customize the post-handling of the Token Response, you need to provide DefaultPasswordTokenResponseClient.setRestOperations() with a custom configured RestOperations. The default RestOperations is configured as follows:spring-doc.cn
OAuth2AccessTokenResponseHttpMessageConverter is a HttpMessageConverter for an OAuth 2.0 Access Token Response. You can provide OAuth2AccessTokenResponseHttpMessageConverter.setTokenResponseConverter() with a custom Converter<Map<String, String>, OAuth2AccessTokenResponse> that is used to convert the OAuth 2.0 Access Token Response parameters to an OAuth2AccessTokenResponse.spring-doc.cn
Whether you customize DefaultPasswordTokenResponseClient or provide your own implementation of OAuth2AccessTokenResponseClient, you need to configure it as follows:spring-doc.cn
// Customize
OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> passwordTokenResponseClient = ...
				.password(configurer -> configurer.accessTokenResponseClient(passwordTokenResponseClient))
				.refreshToken()
val passwordTokenResponseClient: OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> = ...
        .password { it.accessTokenResponseClient(passwordTokenResponseClient) }
        .refreshToken()
        .build()
OAuth2AuthorizedClientProviderBuilder.builder().password() configures a PasswordOAuth2AuthorizedClientProvider, which is an implementation of an OAuth2AuthorizedClientProvider for the Resource Owner Password Credentials grant.spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            authorization-grant-type: password
            scope: read, write
        provider:
          okta:
Further consider the OAuth2AuthorizedClientManager @Bean:spring-doc.cn
					.password()
					.refreshToken()
	// Assuming the `username` and `password` are supplied as `HttpServletRequest` parameters,
	// map the `HttpServletRequest` parameters to `OAuth2AuthorizationContext.getAttributes()`
	authorizedClientManager.setContextAttributesMapper(contextAttributesMapper());
private Function<OAuth2AuthorizeRequest, Map<String, Object>> contextAttributesMapper() {
	return authorizeRequest -> {
		Map<String, Object> contextAttributes = Collections.emptyMap();
		HttpServletRequest servletRequest = authorizeRequest.getAttribute(HttpServletRequest.class.getName());
		String username = servletRequest.getParameter(OAuth2ParameterNames.USERNAME);
		String password = servletRequest.getParameter(OAuth2ParameterNames.PASSWORD);
		if (StringUtils.hasText(username) && StringUtils.hasText(password)) {
			contextAttributes = new HashMap<>();
			// `PasswordOAuth2AuthorizedClientProvider` requires both attributes
			contextAttributes.put(OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME, username);
			contextAttributes.put(OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME, password);
		return contextAttributes;
            .password()
            .refreshToken()
            .build()
private fun contextAttributesMapper(): Function<OAuth2AuthorizeRequest, MutableMap<String, Any>> {
    return Function { authorizeRequest ->
        var contextAttributes: MutableMap<String, Any> = mutableMapOf()
        val servletRequest: HttpServletRequest = authorizeRequest.getAttribute(HttpServletRequest::class.java.name)
        val username = servletRequest.getParameter(OAuth2ParameterNames.USERNAME)
        val password = servletRequest.getParameter(OAuth2ParameterNames.PASSWORD)
            contextAttributes = hashMapOf()
            contextAttributes[OAuth2AuthorizationContext.USERNAME_ATTRIBUTE_NAME] = username
            contextAttributes[OAuth2AuthorizationContext.PASSWORD_ATTRIBUTE_NAME] = password
        contextAttributes
@Controller
	@Autowired
	@GetMapping("/")
		return "index";
@Controller
    @Autowired
    @GetMapping("/")
                    it[HttpServletRequest::class.java.name] = servletRequest
                    it[HttpServletResponse::class.java.name] = servletResponse
                .build()
        return "index"
HttpServletRequest and HttpServletResponse are both OPTIONAL attributes. If not provided, they default to ServletRequestAttributes using RequestContextHolder.getRequestAttributes().spring-doc.cn
JWT Bearer
Please refer to JSON Web Token (JWT) Profile for OAuth 2.0 Client Authentication and Authorization Grants for further details on the JWT Bearer grant.spring-doc.cn
Please refer to the Access Token Request/Response protocol flow for the JWT Bearer grant.spring-doc.cn
The default implementation of OAuth2AccessTokenResponseClient for the JWT Bearer grant is DefaultJwtBearerTokenResponseClient, which uses a RestOperations when requesting an access token at the Authorization Server’s Token Endpoint.spring-doc.cn
The DefaultJwtBearerTokenResponseClient is quite flexible as it allows you to customize the pre-processing of the Token Request and/or post-handling of the Token Response.spring-doc.cn
If you need to customize the pre-processing of the Token Request, you can provide DefaultJwtBearerTokenResponseClient.setRequestEntityConverter() with a custom Converter<JwtBearerGrantRequest, RequestEntity<?>>. The default implementation JwtBearerGrantRequestEntityConverter builds a RequestEntity representation of a OAuth 2.0 Access Token Request. However, providing a custom Converter, would allow you to extend the Token Request and add custom parameter(s).spring-doc.cn
To customize only the parameters of the request, you can provide JwtBearerGrantRequestEntityConverter.setParametersConverter() with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>> to completely override the parameters sent with the request. This is often simpler than constructing a RequestEntity directly.spring-doc.cn
If you prefer to only add additional parameters, you can provide JwtBearerGrantRequestEntityConverter.addParametersConverter() with a custom Converter<JwtBearerGrantRequest, MultiValueMap<String, String>> which constructs an aggregate Converter.
On the other end, if you need to customize the post-handling of the Token Response, you will need to provide DefaultJwtBearerTokenResponseClient.setRestOperations() with a custom configured RestOperations. The default RestOperations is configured as follows:spring-doc.cn
Spring MVC FormHttpMessageConverter is required as it’s used when sending the OAuth 2.0 Access Token Request.spring-doc.cn
OAuth2ErrorResponseErrorHandler is a ResponseErrorHandler that can handle an OAuth 2.0 Error, eg. 400 Bad Request. It uses an OAuth2ErrorHttpMessageConverter for converting the OAuth 2.0 Error parameters to an OAuth2Error.spring-doc.cn
Whether you customize DefaultJwtBearerTokenResponseClient or provide your own implementation of OAuth2AccessTokenResponseClient, you’ll need to configure it as shown in the following example:spring-doc.cn
// Customize
OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> jwtBearerTokenResponseClient = ...
JwtBearerOAuth2AuthorizedClientProvider jwtBearerAuthorizedClientProvider = new JwtBearerOAuth2AuthorizedClientProvider();
jwtBearerAuthorizedClientProvider.setAccessTokenResponseClient(jwtBearerTokenResponseClient);
				.provider(jwtBearerAuthorizedClientProvider)
// Customize
val jwtBearerTokenResponseClient: OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> = ...
val jwtBearerAuthorizedClientProvider = JwtBearerOAuth2AuthorizedClientProvider()
        .build()
Given the following Spring Boot 2.x properties for an OAuth 2.0 Client registration:spring-doc.cn
spring:
  security:
    oauth2:
      client:
        registration:
          okta:
            authorization-grant-type: urn:ietf:params:oauth:grant-type:jwt-bearer
            scope: read
        provider:
          okta:
…​and the OAuth2AuthorizedClientManager @Bean:spring-doc.cn
            .build()
You may obtain the OAuth2AccessToken as follows:spring-doc.cn
@RestController
public class OAuth2ResourceServerController {
	@Autowired
	@GetMapping("/resource")
	public String resource(JwtAuthenticationToken jwtAuthentication) {
				.principal(jwtAuthentication)
    @Autowired
    fun resource(jwtAuthentication: JwtAuthenticationToken?): String {
                .build()
JwtBearerOAuth2AuthorizedClientProvider resolves the Jwt assertion via OAuth2AuthorizationContext.getPrincipal().getPrincipal() by default, hence the use of JwtAuthenticationToken in the preceding example.
If you need to resolve the Jwt assertion from a different source, you can provide JwtBearerOAuth2AuthorizedClientProvider.setJwtAssertionResolver() with a custom Function<OAuth2AuthorizationContext, Jwt>.
