For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
RSocket Security
Spring Security’s RSocket support relies on a SocketAcceptorInterceptor. The main entry point into security is in PayloadSocketAcceptorInterceptor, which adapts the RSocket APIs to allow intercepting a PayloadExchange with PayloadInterceptor implementations.spring-doc.cn
The following example shows a minimal RSocket Security configuration:spring-doc.cn
Minimal RSocket Security Configuration
You can find a minimal RSocket Security configuration below:spring-doc.cn
@EnableRSocketSecurity
public class HelloRSocketSecurityConfig {
	public MapReactiveUserDetailsService userDetailsService() {
		UserDetails user = User.withDefaultPasswordEncoder()
			.username("user")
			.password("user")
			.roles("USER")
		return new MapReactiveUserDetailsService(user);
open class HelloRSocketSecurityConfig {
    open fun userDetailsService(): MapReactiveUserDetailsService {
        val user = User.withDefaultPasswordEncoder()
            .username("user")
            .password("user")
            .roles("USER")
            .build()
        return MapReactiveUserDetailsService(user)
This configuration enables simple authentication and sets up rsocket-authorization to require an authenticated user for any request.spring-doc.cn
Adding SecuritySocketAcceptorInterceptor
For Spring Security to work, we need to apply SecuritySocketAcceptorInterceptor to the ServerRSocketFactory. Doing so connects our PayloadSocketAcceptorInterceptor with the RSocket infrastructure. In a Spring Boot application, you can do this automatically by using RSocketSecurityAutoConfiguration with the following code:spring-doc.cn
RSocketServerCustomizer springSecurityRSocketSecurity(SecuritySocketAcceptorInterceptor interceptor) {
    return (server) -> server.interceptors((registry) -> registry.forSocketAcceptor(interceptor));
fun springSecurityRSocketSecurity(interceptor: SecuritySocketAcceptorInterceptor): RSocketServerCustomizer {
    return RSocketServerCustomizer { server ->
        server.interceptors { registry ->
RSocket Authentication
RSocket authentication is performed with AuthenticationPayloadInterceptor, which acts as a controller to invoke a ReactiveAuthenticationManager instance.spring-doc.cn
Authentication at Setup versus Request Time
Generally, authentication can occur at setup time or at request time or both.spring-doc.cn
Authentication at setup time makes sense in a few scenarios. A common scenarios is when a single user (such as a mobile connection) uses an RSocket connection. In this case, only a single user uses the connection, so authentication can be done once at connection time.spring-doc.cn
In a scenario where the RSocket connection is shared, it makes sense to send credentials on each request. For example, a web application that connects to an RSocket server as a downstream service would make a single connection that all users use. In this case, if the RSocket server needs to perform authorization based on the web application’s users credentials, authentication for each request makes sense.spring-doc.cn
In some scenarios, authentication at both setup and for each request makes sense. Consider a web application, as described previously. If we need to restrict the connection to the web application itself, we can provide a credential with a SETUP authority at connection time. Then each user can have different authorities but not the SETUP authority. This means that individual users can make requests but not make additional connections.spring-doc.cn
Simple Authentication
Spring Security has support for the Simple Authentication Metadata Extension.spring-doc.cn
Basic Authentication evolved into Simple Authentication and is only supported for backward compatibility. See RSocketSecurity.basicAuthentication(Customizer) for setting it up.spring-doc.cn
The RSocket receiver can decode the credentials by using AuthenticationPayloadExchangeConverter, which is automatically setup by using the simpleAuthentication portion of the DSL. The following example shows an explicit configuration:spring-doc.cn
PayloadSocketAcceptorInterceptor rsocketInterceptor(RSocketSecurity rsocket) {
	rsocket
		.authorizePayload(authorize ->
			authorize
					.anyRequest().authenticated()
					.anyExchange().permitAll()
		.simpleAuthentication(Customizer.withDefaults());
	return rsocket.build();
open fun rsocketInterceptor(rsocket: RSocketSecurity): PayloadSocketAcceptorInterceptor {
    rsocket
        .authorizePayload { authorize -> authorize
        .simpleAuthentication(withDefaults())
The RSocket sender can send credentials by using SimpleAuthenticationEncoder, which you can add to Spring’s RSocketStrategies.spring-doc.cn
RSocketStrategies.Builder strategies = ...;
strategies.encoder(new SimpleAuthenticationEncoder());
var strategies: RSocketStrategies.Builder = ...
strategies.encoder(SimpleAuthenticationEncoder())
You can then use it to send a username and password to the receiver in the setup:spring-doc.cn
MimeType authenticationMimeType =
	MimeTypeUtils.parseMimeType(WellKnownMimeType.MESSAGE_RSOCKET_AUTHENTICATION.getString());
UsernamePasswordMetadata credentials = new UsernamePasswordMetadata("user", "password");
Mono<RSocketRequester> requester = RSocketRequester.builder()
	.setupMetadata(credentials, authenticationMimeType)
	.rsocketStrategies(strategies.build())
	.connectTcp(host, port);
val authenticationMimeType: MimeType =
    MimeTypeUtils.parseMimeType(WellKnownMimeType.MESSAGE_RSOCKET_AUTHENTICATION.string)
val credentials = UsernamePasswordMetadata("user", "password")
val requester: Mono<RSocketRequester> = RSocketRequester.builder()
Alternatively or additionally, a username and password can be sent in a request.spring-doc.cn
Mono<RSocketRequester> requester;
public Mono<AirportLocation> findRadar(String code) {
	return this.requester.flatMap(req ->
		req.route("find.radar.{code}", code)
			.metadata(credentials, authenticationMimeType)
			.retrieveMono(AirportLocation.class)
import org.springframework.messaging.rsocket.retrieveMono
var requester: Mono<RSocketRequester>? = null
var credentials = UsernamePasswordMetadata("user", "password")
open fun findRadar(code: String): Mono<AirportLocation> {
    return requester!!.flatMap { req ->
            .retrieveMono<AirportLocation>()
JWT
Spring Security has support for the Bearer Token Authentication Metadata Extension. The support comes in the form of authenticating a JWT (determining that the JWT is valid) and then using the JWT to make authorization decisions.spring-doc.cn
The RSocket receiver can decode the credentials by using BearerPayloadExchangeConverter, which is automatically setup by using the jwt portion of the DSL. The following listing shows an example configuration:spring-doc.cn
	rsocket
			authorize
		.jwt(Customizer.withDefaults());
    rsocket
        .jwt(withDefaults())
The configuration above relies on the existence of a ReactiveJwtDecoder @Bean being present. An example of creating one from the issuer can be found below:spring-doc.cn
ReactiveJwtDecoder jwtDecoder() {
	return ReactiveJwtDecoders
		.fromIssuerLocation("https://example.com/auth/realms/demo");
fun jwtDecoder(): ReactiveJwtDecoder {
The RSocket sender does not need to do anything special to send the token, because the value is a simple String. The following example sends the token at setup time:spring-doc.cn
BearerTokenMetadata token = ...;
	.setupMetadata(token, authenticationMimeType)
val token: BearerTokenMetadata = ...
val requester = RSocketRequester.builder()
Alternatively or additionally, you can send the token in a request:spring-doc.cn
	        .metadata(token, authenticationMimeType)
    return this.requester!!.flatMap { req ->
RSocket Authorization
RSocket authorization is performed with AuthorizationPayloadInterceptor, which acts as a controller to invoke a ReactiveAuthorizationManager instance. You can use the DSL to set up authorization rules based upon the PayloadExchange. The following listing shows an example configuration:spring-doc.cn
rsocket
	.authorizePayload(authz ->
		authz
			.setup().hasRole("SETUP") (1)
			.route("fetch.profile.me").authenticated() (2)
			.matcher(payloadExchange -> isMatch(payloadExchange)) (3)
				.hasRole("CUSTOM")
			.route("fetch.profile.{username}") (4)
				.access((authentication, context) -> checkFriends(authentication, context))
			.anyRequest().authenticated() (5)
			.anyExchange().permitAll() (6)
rsocket
    .authorizePayload { authz ->
        authz
            .matcher { payloadExchange -> isMatch(payloadExchange) } (3)
            .hasRole("CUSTOM")
            .access { authentication, context -> checkFriends(authentication, context) }
    } (6)
1 Setting up a connection requires the ROLE_SETUP authority.
2 If the route is fetch.profile.me, authorization only requires the user to be authenticated.
3 In this rule, we set up a custom matcher, where authorization requires the user to have the ROLE_CUSTOM authority.
4 This rule uses custom authorization. The matcher expresses a variable with a name of username that is made available in the context. A custom authorization rule is exposed in the checkFriends method.
5 This rule ensures that a request that does not already have a rule requires the user to be authenticated. A request is where the metadata is included. It would not include additional payloads.
6 This rule ensures that any exchange that does not already have a rule is allowed for anyone. In this example, it means that payloads that have no metadata also have no authorization rules.
Note that authorization rules are performed in order. Only the first authorization rule that matches is invoked.spring-doc.cn
