For the latest stable version, please use Spring Security 6.4.1! |
Secure Object Implementations
This section covers how Spring Security handles Secure Object implementations.
AOP Alliance (MethodInvocation) Security Interceptor
Prior to Spring Security 2.0, securing MethodInvocation
instances needed a lot of boiler plate configuration.
Now the recommended approach for method security is to use namespace configuration.
This way, the method security infrastructure beans are configured automatically for you, so you need not know about the implementation classes.
We provide only a quick overview of the classes that are involved here.
Method security is enforced by using a MethodSecurityInterceptor
, which secures MethodInvocation
instances.
Depending on the configuration approach, an interceptor may be specific to a single bean or shared between multiple beans.
The interceptor uses a MethodSecurityMetadataSource
instance to obtain the configuration attributes that apply to a particular method invocation.
MapBasedMethodSecurityMetadataSource
is used to store configuration attributes keyed by method names (which can be wildcarded) and will be used internally when the attributes are defined in the application context using the <intercept-methods>
or <protect-point>
elements.
Other implementations are used to handle annotation-based configuration.
Explicit MethodSecurityInterceptor Configuration
You can configure a MethodSecurityInterceptor
directly in your application context for use with one of Spring AOP’s proxying mechanisms:
<bean id="bankManagerSecurity" class=
"org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor">
<property name="authenticationManager" ref="authenticationManager"/>
<property name="accessDecisionManager" ref="accessDecisionManager"/>
<property name="afterInvocationManager" ref="afterInvocationManager"/>
<property name="securityMetadataSource">
<sec:method-security-metadata-source>
<sec:protect method="com.mycompany.BankManager.delete*" access="ROLE_SUPERVISOR"/>
<sec:protect method="com.mycompany.BankManager.getBalance" access="ROLE_TELLER,ROLE_SUPERVISOR"/>
</sec:method-security-metadata-source>
</property>
</bean>
AspectJ (JoinPoint) Security Interceptor
The AspectJ security interceptor is very similar to the AOP Alliance security interceptor discussed in the previous section. We discuss only the differences in this section.
The AspectJ interceptor is named AspectJSecurityInterceptor
Unlike the AOP Alliance security interceptor, which relies on the Spring application context to weave in the security interceptor through proxying, the AspectJSecurityInterceptor
is woven in through the AspectJ compiler.
It would not be uncommon to use both types of security interceptors in the same application, with AspectJSecurityInterceptor
being used for domain object instance security and the AOP Alliance MethodSecurityInterceptor
being used for services layer security.
We first consider how the AspectJSecurityInterceptor
is configured in the Spring application context:
"org.springframework.security.access.intercept.aspectj.AspectJMethodSecurityInterceptor">
</property>
</bean>
The two interceptors can share the same securityMetadataSource
, as the SecurityMetadataSource
works with java.lang.reflect.Method
instances rather than an AOP library-specific class.
Your access decisions have access to the relevant AOP library-specific invocation (MethodInvocation
or JoinPoint
) and can consider a range of additional criteria (such as method arguments) when making access decisions.
Next, you need to define an AspectJ aspect
, as the following example shows:
package org.springframework.security.samples.aspectj;
import org.springframework.security.access.intercept.aspectj.AspectJSecurityInterceptor;
import org.springframework.security.access.intercept.aspectj.AspectJCallback;
import org.springframework.beans.factory.InitializingBean;
public aspect DomainObjectInstanceSecurityAspect implements InitializingBean {
private AspectJSecurityInterceptor securityInterceptor;
pointcut domainObjectInstanceExecution(): target(PersistableEntity)
&& execution(public * *(..)) && !within(DomainObjectInstanceSecurityAspect);
Object around(): domainObjectInstanceExecution() {
if (this.securityInterceptor == null) {
return proceed();
AspectJCallback callback = new AspectJCallback() {
public Object proceedWithObject() {
return proceed();
return this.securityInterceptor.invoke(thisJoinPoint, callback);
public AspectJSecurityInterceptor getSecurityInterceptor() {
return securityInterceptor;
public void setSecurityInterceptor(AspectJSecurityInterceptor securityInterceptor) {
this.securityInterceptor = securityInterceptor;
public void afterPropertiesSet() throws Exception {
throw new IllegalArgumentException("securityInterceptor required");
In the preceding example, the security interceptor is applied to every instance of PersistableEntity
, which is an abstract class not shown (you can use any other class or pointcut
expression you like).
For those curious, AspectJCallback
is needed because the proceed();
statement has special meaning only within an around()
body.
The AspectJSecurityInterceptor
calls this anonymous AspectJCallback
class when it wants the target object to continue.
You need to configure Spring to load the aspect and wire it with the AspectJSecurityInterceptor
The following example shows a bean declaration that achieves this:
<bean id="domainObjectInstanceSecurityAspect"
class="security.samples.aspectj.DomainObjectInstanceSecurityAspect"
factory-method="aspectOf">
<property name="securityInterceptor" ref="bankManagerSecurity"/>
</bean>
Now you can create your beans from anywhere within your application, using whatever means you think fit (e.g. new Person();
), and they have the security interceptor applied.
