For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Username/Password Authentication
One of the most common ways to authenticate a user is by validating a username and password. Spring Security provides comprehensive support for authenticating with a username and password.spring-doc.cn
You can configure username and password authentication using the following:spring-doc.cn
Simple Username/Password Example
@EnableWebSecurity
public class SecurityConfig {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		http
			.authorizeHttpRequests((authorize) -> authorize
				.anyRequest().authenticated()
			.httpBasic(Customizer.withDefaults())
			.formLogin(Customizer.withDefaults());
		return http.build();
	public UserDetailsService userDetailsService() {
		UserDetails userDetails = User.withDefaultPasswordEncoder()
			.username("user")
			.password("password")
			.roles("USER")
		return new InMemoryUserDetailsManager(userDetails);
<http>
	<intercept-url pattern="/**" access="authenticated"/>
	<form-login />
	<http-basic />
	<user-service>
		<user name="user"
			password="{noop}password"
			authorities="ROLE_USER" />
	</user-service>
</http>
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
	fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
		http {
			authorizeHttpRequests {
			formLogin { }
			httpBasic { }
		return http.build()
	fun userDetailsService(): UserDetailsService {
		val user = User.withDefaultPasswordEncoder()
			.username("user")
			.roles("USER")
			.build()
		return InMemoryUserDetailsManager(user)
The preceding configuration automatically registers an in-memory UserDetailsService with the SecurityFilterChain, registers the DaoAuthenticationProvider with the default AuthenticationManager, and enables Form Login and HTTP Basic authentication.spring-doc.cn
To learn more about username/password authentication, consider the following use cases:spring-doc.cn
Publish an AuthenticationManager bean
A fairly common requirement is publishing an AuthenticationManager bean to allow for custom authentication, such as in a @Service or Spring MVC @Controller. For example, you may want to authenticate users via a REST API instead of using Form Login.spring-doc.cn
You can publish such an AuthenticationManager for custom authentication scenarios using the following configuration:spring-doc.cn
Publish AuthenticationManager bean for Custom Authentication
@EnableWebSecurity
		http
				.requestMatchers("/login").permitAll()
	public AuthenticationManager authenticationManager(
			UserDetailsService userDetailsService,
			PasswordEncoder passwordEncoder) {
		DaoAuthenticationProvider authenticationProvider = new DaoAuthenticationProvider();
		authenticationProvider.setUserDetailsService(userDetailsService);
		authenticationProvider.setPasswordEncoder(passwordEncoder);
		return new ProviderManager(authenticationProvider);
			.username("user")
			.roles("USER")
	public PasswordEncoder passwordEncoder() {
		return PasswordEncoderFactories.createDelegatingPasswordEncoder();
<http>
	<intercept-url pattern="/login" access="permitAll"/>
	<bean id="authenticationManager"
			class="org.springframework.security.authentication.ProviderManager">
		<constructor-arg>
			<bean class="org.springframework.security.authentication.dao.DaoAuthenticationProvider">
				<property name="userDetailsService" ref="userDetailsService" />
				<property name="passwordEncoder" ref="passwordEncoder" />
			</bean>
		</constructor-arg>
	</bean>
	<user-service id="userDetailsService">
		<user name="user"
	</user-service>
	<bean id="passwordEncoder"
    	    class="org.springframework.security.crypto.factory.PasswordEncoderFactories" factory-method="createDelegatingPasswordEncoder"/>
</http>
@EnableWebSecurity
		http {
		return http.build()
	fun authenticationManager(
			userDetailsService: UserDetailsService,
			passwordEncoder: PasswordEncoder): AuthenticationManager {
		val authenticationProvider = DaoAuthenticationProvider()
		return ProviderManager(authenticationProvider)
			.username("user")
			.roles("USER")
			.build()
	fun passwordEncoder(): PasswordEncoder {
With the preceding configuration in place, you can create a @RestController that uses the AuthenticationManager as follows:spring-doc.cn
Create a @RestController for Authentication
@RestController
public class LoginController {
	private final AuthenticationManager authenticationManager;
	public LoginController(AuthenticationManager authenticationManager) {
		this.authenticationManager = authenticationManager;
	@PostMapping("/login")
	public ResponseEntity<Void> login(@RequestBody LoginRequest loginRequest) {
		Authentication authenticationRequest =
			UsernamePasswordAuthenticationToken.unauthenticated(loginRequest.username(), loginRequest.password());
		Authentication authenticationResponse =
			this.authenticationManager.authenticate(authenticationRequest);
	public record LoginRequest(String username, String password) {
@RestController
class LoginController(val authenticationManager: AuthenticationManager) {
	fun login(@RequestBody loginRequest: LoginRequest): ResponseEntity<Void> {
		val authenticationRequest =
				loginRequest.username, loginRequest.password)
		val authenticationResponse =
	data class LoginRequest(val username: String, val password: String)
In this example, it is your responsibility to save the authenticated user in the SecurityContextRepository if needed. For example, if using the HttpSession to persist the SecurityContext between requests, you can use HttpSessionSecurityContextRepository.spring-doc.cn
Customize the AuthenticationManager
Normally, Spring Security builds an AuthenticationManager internally composed of a DaoAuthenticationProvider for username/password authentication. In certain cases, it may still be desired to customize the instance of AuthenticationManager used by Spring Security. For example, you may need to simply disable credential erasure for cached users.spring-doc.cn
The recommended way to do this is to simply publish your own AuthenticationManager bean, and Spring Security will use it. You can publish an AuthenticationManager using the following configuration:spring-doc.cn
Publish AuthenticationManager bean for Spring Security
@EnableWebSecurity
		http
		ProviderManager providerManager = new ProviderManager(authenticationProvider);
		providerManager.setEraseCredentialsAfterAuthentication(false);
		return providerManager;
			.username("user")
			.roles("USER")
<http>
	<form-login />
	<http-basic />
		<constructor-arg>
			</bean>
		</constructor-arg>
	</bean>
		<user name="user"
	</user-service>
</http>
@EnableWebSecurity
		http {
			formLogin { }
			httpBasic { }
		return http.build()
		val providerManager = ProviderManager(authenticationProvider)
		providerManager.eraseCredentialsAfterAuthentication = false
			.username("user")
			.roles("USER")
			.build()
Alternatively, you can take advantage of the fact that the AuthenticationManagerBuilder used to build Spring Security’s global AuthenticationManager is published as a bean. You can configure the builder as follows:spring-doc.cn
Configure global AuthenticationManagerBuilder
@EnableWebSecurity
        // Return a UserDetailsService that caches users
    @Autowired
    public void configure(AuthenticationManagerBuilder builder) {
        builder.eraseCredentials(false);
@EnableWebSecurity
		return http.build()
	@Autowired
	fun configure(builder: AuthenticationManagerBuilder) {
